Robert Bowen-Cattry | 05/09/2022 13:08:23 |
![]() 35 forum posts 4 photos | Good afternoon all. My current project requires a 7/32-40 UNS die. All I can seem to find with a Google Search is ME dies, but as I understand the thread angle of these is 55, and the UNS is 60. So the question is, does anyone know a UK based online resoure for UNS dies? Cheers, Bob |
Robert Butler | 05/09/2022 13:19:36 |
511 forum posts 6 photos | Tracy Tools list 7/32" UNS as 24, 28, 32 & 36 TPI NOT 40TPI?? Robert Butler
Edited By Robert Butler on 05/09/2022 13:20:47 Edited By Robert Butler on 05/09/2022 13:22:36 |
JasonB | 05/09/2022 13:38:35 |
![]() 25215 forum posts 3105 photos 1 articles | Might be worth trying #12-40 rather than 7/32-40 as below 1/4" they use a number system. My usual chart does list it under UNS but as you say not many about in teh UK |
Thor 🇳🇴 | 05/09/2022 13:53:27 |
![]() 1766 forum posts 46 photos | #12-40 is listed on eBay. Thor |
Robert Bowen-Cattry | 05/09/2022 14:06:48 |
![]() 35 forum posts 4 photos | Thanks gents. I looked at Tracy Tools but as said they don't list the 7/32-40. A bit wary of the ebay offering as it appears to originate from China. Will look into the 12-40, might have to end up getting one from the States.
Andrew Johnston | 05/09/2022 14:09:32 |
![]() 7061 forum posts 719 photos | There is no mention of 7/32"-40 UNS in any of my professional engineering books. I would agree with JB that 12-40 is the closest listed thread. From a practical point of view it should be easy enough to screwcut. Alternatively the difference in width at the base of the flank between the hypothetical 7/32"-40UNS and 7/32"-40ME is less than a thou. So unless the application requires precision fits a 7/32"-40ME die will be fine. Andrew |
Robert Bowen-Cattry | 05/09/2022 14:25:41 |
![]() 35 forum posts 4 photos | Interesting, thanks Andrew. I'm wanting to make some apertures to fit into a Skinner rifle sight. I was originally going to get the ME die, but some online reading suggested the pitch difference in the threads wouldn't work at all. In terms of the application, it's going in a 7/32-40/12-40 hole on a sight fitted to a .44 magnum rifle. Although there will be significant recoil, if I can get the aperture tightened into the sight it should all be good. |
Michael Gilligan | 05/09/2022 14:41:02 |
![]() 23121 forum posts 1360 photos | This would seem to confirm that 12-40 is Skinner’s thread: **LINK** http://skinnersights.com/apertures_8.html MichaelG. |
Robert Bowen-Cattry | 05/09/2022 14:48:53 |
![]() 35 forum posts 4 photos | Yes, Skinner states 12-40, however online reading suggested the 7/32-40 was more prevalent and would work. |
old mart | 05/09/2022 15:50:06 |
4655 forum posts 304 photos | I notice that 12 size unified is only 0.00275" smaller than 7/32", so if you can get a split die, the size could be matched pretty well. |
Robert Bowen-Cattry | 05/09/2022 16:14:28 |
![]() 35 forum posts 4 photos | Agreed, I think (from what I read online) that's why the 7/32-40 was recommended. Also because other sight makers (Willaims, Lymans, etc) seem to favour this over the 12-40, so I could always make apertures for other club members if required. However I still have the issue of where to get a 7/32-40 UNS die from without importing from the States. To answer my own question, I don't think I will be able to, unless I risk it with the ME equivalent. |
Howard Lewis | 05/09/2022 18:08:30 |
7227 forum posts 21 photos | Zeus Charts list 12-24 ANC as 0.216", 12--28 ANF as 0.216" diameter Since 7/32 is 0.218", If yo use a 12-40 UNS die, you are likely to produce what you want. Being 0.002" underisze will probably be the truncation applied to Unified threads, so you should have no problem. Tracy Tools list 7/32 x 36 UNS and say "Many more sizes not listed" so they can probably supply what you want. I suspect that 7/32 is being quoted as the nearest fractional size to the size 12 Unified threads, so I would turn the blank to 0.216" before using the Dies, since that is the specified OD. Howard |
Robert Bowen-Cattry | 05/09/2022 19:54:13 |
![]() 35 forum posts 4 photos | Good suggestion, I will call Tracy tomorrow. |
bernard towers | 05/09/2022 20:53:57 |
1221 forum posts 161 photos | can’t you screwcut it? |
Robert Bowen-Cattry | 05/09/2022 21:03:23 |
![]() 35 forum posts 4 photos | Possibly. I'm not sure if my lathe (WM180) can cut that thread, and I've never cut a thread that small before. However, I may potentially be making a few apertures so it seems to make sense to go the die route. Work smart and not hard. |
Peter Greene | 05/09/2022 22:45:42 |
865 forum posts 12 photos | Posted by Robert Bowen-Cattry on 05/09/2022 16:14:28:
I've never heard of a 7/32-40 UNS on this side of the pond either..... #12-40 UNS, sure. My guess is that someone, somewhere has "rounded off" the #12 for his own purposes .... possibly to emphasise that it can be die-cut on 7/32 rod. Although, given that UNS is reserved for "Special" threads, I guess people can make what they want, both in dia and tpi as long as they stick to the UN thread form. Getting commercially available dies in that case might be problematic though. |
Michael Gilligan | 06/09/2022 04:37:29 |
![]() 23121 forum posts 1360 photos | Just an aside: I may be wrong [it’s happened before!] but … looking at the modus operandi for these sights, I would be very surprised if the manufacturers cut their threads ‘from scratch’ with a die: It would be preferable to screw-cut it in the lathe [and only use a die for final sizing, if necessary]. MichaelG. . Edited By Michael Gilligan on 06/09/2022 04:44:09 |
Michael Gilligan | 06/09/2022 08:06:55 |
![]() 23121 forum posts 1360 photos | Just had a look for a decent picture of the Skinner item The one at bottom-left of this page: **LINK** is the best I could find https://gunblast.com/SkinnerSights.htm [click the picture for a better size] The next question must be : Being Unified threads … which class of fit is used ? MichaelG. [*] **LINK** http://skinnersights.com/the_shop_9.html
Ref. __ **LINK** https://www.fastenal.com/content/feds/pdf/Article%20-%20Screw%20Threads%20Design.pdf
Edited By Michael Gilligan on 06/09/2022 08:10:53 |
bernard towers | 06/09/2022 19:09:21 |
1221 forum posts 161 photos | If your lathe is metric only cut a 1 mm pitch it will fit especially the number of threads you need, it will be finished before you’ve filled in an online order . |
JasonB | 06/09/2022 19:16:56 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by bernard towers on 06/09/2022 19:09:21:
If your lathe is metric only cut a 1 mm pitch it will fit especially the number of threads you need, it will be finished before you’ve filled in an online order . How does that work Bernard, 40tpi is 0.635mm pitch |
