Lubricating Oils
Stewart Davis | 15/08/2022 15:00:07 |
2 forum posts | Hi all, was at our club over the weekend and someone said you should not use car oil for general lubrication, but get specific Lubricating oil. Has anyone else heard that ? |
Jeff Dayman | 15/08/2022 16:20:37 |
2356 forum posts 47 photos | What are you lubricating? Multigrade detergent oils intended for cars are not good for machine tool spindles or ways, or the cylinders of steam models, for example. ISO 32 hydraulic jack oil is great for spindles, way oil is great for machine ways, and thick steam cylinder oil is best for steam cylinders. |
Andrew Johnston | 15/08/2022 16:21:39 |
![]() 7061 forum posts 719 photos | Automotive oils contain additives designed to clear deposits in the engine,and also have specific viscosity characteristics with temperature. For small, lightly used, lathes it probably doesn't matter much, but I prefer to stick with the manufacturers recommendations. Basically straight hydraulic oils for spindle and headstocks, thicker straight oils for feed gearboxes and specific slideway oils for slideways. Andrew |
old mart | 15/08/2022 16:38:28 |
4655 forum posts 304 photos | I have been lubricating the Smart & Brown with 5W30 fully synthetic for years, all the lubrication is oil and total loss, there has been no noticable wear since doing so. Modern oils are light years ahead of the stuff available in the 40's. |
JA | 15/08/2022 16:43:04 |
![]() 1605 forum posts 83 photos | Jeff and Andrew are correct. Automotive oil only wins because you may have half a container of it on the shelf and that it is easier to find a local supplier. It is certainly more expensive. Your local lubricating oil supplier is unlikely to turn away your business. My lathe uses more oil than my old British bikes. JA Very much more expensive if you use synthetic oils. Edited By JA on 15/08/2022 16:45:30 |
noel shelley | 15/08/2022 16:55:23 |
2308 forum posts 33 photos | If the machine being lubricated does not need or can not benefit from modern sythetics it's just a waste of money. Straight mineral oils are ALL oil, multigrades have alsorts of additives that are Not oil ! Noel. |
Stewart Davis | 15/08/2022 17:04:47 |
2 forum posts | Sorry all, I should have been more specific, the conversation was about model steam locos, but could apply to lathe beds etc. I generally use Halfords Classic car 20/50 which I don't think has many if any additives? and its reasonably thick ?? |
Roger Williams 2 | 15/08/2022 17:06:59 |
368 forum posts 7 photos | Old mart, well said mate. I changed the headstock oil on my old DSG using hydraulic oil as specified only because I had a can of it , but modern engine oil like 5/30 syn but be fine and in the gearbox too !.If a bloody great Volvo road grader towing a 6 ton roller with about 10 gallon of 5 /30 syn oil in its gearbox manages , it will certainly be ok in a lathe headstock or gearbox.
Andrew Johnston | 15/08/2022 17:23:32 |
![]() 7061 forum posts 719 photos | Posted by Roger Williams 2 on 15/08/2022 17:06:59:
...modern engine oil like 5/30 syn but be fine... How about putting hydraulic oil in the Volvo? Andrew |
Robert Atkinson 2 | 15/08/2022 18:44:32 |
![]() 1891 forum posts 37 photos | Leaving aside the OP question on steam engine oil, 5W-30 engine oil is significantly different to the ISO 32 hydraulic oil often specified for lathe spindles and some lathe gear boxes. Nuto H32 has a 40 deg C viscosity of 32 cs and a 100 deg of 5.4 sounds pretty close to 5-30 right? Wrong, a typical 5W40 oil (Castrol GTX) is nearly twice as viscous. It is 9.7 at 100 deg and 55 at 40 deg. Just becuase someone has used it with no apparent ill effects does not mean it is OK. Our applications my be non critical but it is generally best to stick with the recommended lubricants. One particular point is the additives in some oils can have adverse effects on copper and copper alloys e.g. bronze bearings. https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/D1CFEDB7F95B365F8025827B0053876F/$File/BPXE-AYJQ74.pdf https://cdn.lubefinder.net/media/attachments/m/o/mobil_nuto_h_series_tds.pdf Robert G8RPI. Edited By Robert Atkinson 2 on 15/08/2022 18:45:08 |
SillyOldDuffer | 15/08/2022 21:17:13 |
10668 forum posts 2415 photos | Whether the grade of oil matters or not varies with the application. Hobby lathes are lightly loaded so the oil is non-critical and any oil is better than no oil. Although ISO32 is a good all purpose workshop oil I tend to splash 20/50 on my kit because it's cheap, handy, reasonably thick, and low on additives. I sometimes treat slides to some way oil, but there's not much advantage unless the machines are being pushed hard. As Way Oil is thick and sticky it resists being squeegeed out by the slides, which is useful on busy machines. Additives can be an issue. One definitely to avoid are EP gear oils, EP is short for extreme pressure, achieved with an additive that attacks copper alloys, which is bad news for any machine with brass or bronze bearings - quite common in tools! Other additives are more likely to waste money than do harm. They're added for various purposes, often associated with hot engines or other automotive needs. They discourage emulsions, foaming, or improve heat performance, including improved cold-start and anti-waxing. It is important to use the right oil whenever a machine is stressed or has a critical function. Aero-engines have a high power to weight ratio and are required to keep people safe in the air for several hours. Also important to use the right oil on light mechanisms like clocks and sewing machines. WD40 and 3in1 are both excellent clock killers - the first removes oil with a burst of temporary lubrication whilst the second gums up and forms a grinding paste by collecting gunge. Lathes aren't delicate, run at lowish RPM in short bursts and don't drop the operator in mid-ocean. Dave
Edited By SillyOldDuffer on 15/08/2022 21:18:24 |
bernard towers | 15/08/2022 22:15:47 |
1221 forum posts 161 photos | As Robert says oils with certain additives have a detrimental effect on bronzes, we run a new Leak compound in the museum boat and we're instructed in no uncertain terms by the maker to only use straight oils because of this very problem. |
Kiwi Bloke | 15/08/2022 22:16:58 |
912 forum posts 3 photos | As above... No-one has yet mentioned that detergent additives in motor oil are there to keep contaminants (including soot, etc., blown past the piston rings) in suspension so that the full-flow oil filter will then sequestrate them. Motor oil is full of other, expensive additives designed to preserve the oil and its designed performance characteristics in the horribly demanding environment of an ic engine. Machine tools are different. They need oils which encourage contaminants to settle out and lie harmlessly in the bottom of the headstock, gearbox, etc. Anti-foaming and anti-corrosion additives are present in the hydraulic oils mostly specified for machine tool use. They are also very slippery. There is no point using anything else - which is also likely to be more expensive. On the other hand, it probably won't hurt, except... I read somewhere that motor oils, because of the hydrophilic detergent content, absorb water, so may paradoxically increase the risk of rusting. In an ic engine, the oil gets hot enough for absorbed water to evaporate away. Engines standing idle for a long time can rust internally significantly, notwithstanding the oil inside. I once had to store an old cast iron surface plate in a very damp garage. I covered it with paper, and soaked the top with synthetic engine oil. It rusted spectacularly. Older and wiser now... |
Kiwi Bloke | 15/08/2022 22:23:01 |
912 forum posts 3 photos | SOD. I also used to warn people to avoid 3-in-1 oil, but I have been challenged by others on this forum recently. The old formulation we all hate was vegetable oil-based. Now it's apparently mineral oil, and doesn't oxidise to a gummy mess. (I'm expecting a cheque from the manufacturers...). However, I see no need to use it, because I have gallons of light hydraulic oil, which is a great general-purpose 'oil can' oil. I believe there are EP additives that don't attack yellow metals, but it's difficult to know what you've got in a can, so your warning is appropriate. Edited By Kiwi Bloke on 15/08/2022 22:25:24 |
Hopper | 15/08/2022 22:27:15 |
![]() 7881 forum posts 397 photos | Most/many modern automotive gear oils are safe to use with copper and yellow metals. Read the packaging to make sure. Most changed the nature of the sulfur additive a few years back to make it compatible. If it says on the label its safe for bronze, copper, yellow metals etc. all is well. But I would not use it on lathe gears, largely because of the stink, and because they are nowhere near EP or Extreme Pressure like a diff or gearbox transmitting 100HP etc. ISTR that 20/50 oil is about the same viscosity as ISO32 hydrualic oil and 90W gear oil, rather surprisingly.
Robert Atkinson 2 | 16/08/2022 10:10:05 |
![]() 1891 forum posts 37 photos | Posted by Kiwi Bloke on 15/08/2022 22:16:58:
As above... No-one has yet mentioned that detergent additives in motor oil are there to keep contaminants (including soot, etc., blown past the piston rings) in suspension so that the full-flow oil filter will then sequestrate them. Motor oil is full of other, expensive additives designed to preserve the oil and its designed performance characteristics in the horribly demanding environment of an ic engine. Machine tools are different. They need oils which encourage contaminants to settle out and lie harmlessly in the bottom of the headstock, gearbox, etc. Anti-foaming and anti-corrosion additives are present in the hydraulic oils mostly specified for machine tool use. They are also very slippery. There is no point using anything else - which is also likely to be more expensive. On the other hand, it probably won't hurt, except... I read somewhere that motor oils, because of the hydrophilic detergent content, absorb water, so may paradoxically increase the risk of rusting. In an ic engine, the oil gets hot enough for absorbed water to evaporate away. Engines standing idle for a long time can rust internally significantly, notwithstanding the oil inside. I once had to store an old cast iron surface plate in a very damp garage. I covered it with paper, and soaked the top with synthetic engine oil. It rusted spectacularly. Older and wiser now... Indeed. for aircraft pistion engines that are not going to be run there is generally a requirement to replace the normal oil with a special inhibiting oil. This note from Shell confirms that detergent "W" oils are an issue in this respect. https://www.shell.com/business-customers/aviation/aeroshell/knowledge-centre/technical-talk/techart09-30071425.html Rust chemistry isthe same in machine tools |
Jon Lawes | 16/08/2022 10:30:05 |
![]() 1078 forum posts | I use Chainsaw oil as it doesn't get flung off. I use that on all my motion including eccentrics, and I use compounded 680 steam oil in my mechanical lubricator. I think engine oil will be just fine for general oiling round.
As an aside, one reason oils and hydraulic fluids absorb water is because its better its held within the oil, even if its in an emulsion, than for droplets of water to remain on ferrous surfaces. This is especially true of brake fluid. Edited By Jon Lawes on 16/08/2022 10:31:39 |
Kiwi Bloke | 16/08/2022 12:08:37 |
912 forum posts 3 photos | In the interests of avoiding possible confusion, note that the discussion has been about hydraulic oil, not hydraulic fluid, i.e. brake fluid. |
Nick Wheeler | 16/08/2022 12:31:53 |
1227 forum posts 101 photos | Swapping from straight to detergent oil is a common killer of old aircraft engines and is far more expensive than the couple of hundred quids worth of oil. Like many here, I lubricate my lightly used and loaded benchtop lathe with oil that I already had - Dextron3 ATF, which is basically hydraulic oil with, unnecessary for the lathe, dye and detergents. When I have to buy oil, it will be the 'correct' stuff, but going by current use that's several years away. The change gears get a squirt of white lithium grease for the same reason. |
Kiwi Bloke | 18/08/2022 01:52:27 |
912 forum posts 3 photos | There are quite a few types of ATF around. Some modern ones are designed for 'lubricated for life' 'boxes, which are effectively hermetically sealed, because the fluids are hygroscopic. Also, the 'slipperyness' of ATF has to be carefully controlled, because of the numerous wet clutches in auto-boxes, which also, as far as I know, don't have plain bearings in them. I don't think these modern ATFs would be ideal for our machine tools, but I don't know about earlier types. Comments about detergents stand. |
