Peter Cook 6 | 28/06/2022 21:27:38 |
462 forum posts 113 photos | Does anyone know where I might get some Stubb's #12 (4.70mm .01850) silver steel rod. I have acquired a partial staking set and would like to make a few new punches. The holder takes 4.70 diameter punches. 3/16 (4.7625) is too big. New Bergeron punches are 4.70mm, so it must be available.
Edited By Peter Cook 6 on 28/06/2022 21:28:10 |
Nigel Graham 2 | 28/06/2022 21:36:36 |
3293 forum posts 112 photos | The punches are probably ground to size, not necessarily left a stock size. |
HOWARDT | 28/06/2022 21:36:45 |
1081 forum posts 39 photos | Coventry Grinders could possibly supply, centreless ground from 3/16”. |
Tony Pratt 1 | 28/06/2022 21:41:47 |
2319 forum posts 13 photos | Interesting never heard of Bergeron & their expensive staking punches until now, I doubt you will get 4.7 mm silver steel but after heat treat & polishing the 3/16 maybe will fit? Is hardened 4.7 drill rod from Zoro any good? Also your size is listed at Mcmaster Carr. Likely to be made originally from 5mm hardened stock. Tony Edited By Tony Pratt 1 on 28/06/2022 21:42:55 |
peak4 | 28/06/2022 21:47:25 |
![]() 2207 forum posts 210 photos | Posted by Peter Cook 6 on 28/06/2022 21:27:38:
Edited By Peter Cook 6 on 28/06/2022 21:28:10 I guess it depends on how many punches you plan on making. |
Michael Gilligan | 28/06/2022 22:10:01 |
![]() 23121 forum posts 1360 photos | Posted by Tony Pratt 1 on 28/06/2022 21:41:47:
Interesting never heard of Bergeron & their expensive staking punches until now, … . For info. Bergeon has been around for quite a while: **LINK** https://www.bergeon.swiss MichaelG. |
JasonB | 29/06/2022 07:36:30 |
![]() 25215 forum posts 3105 photos 1 articles | What about 12g piano/music wire, it's the diameter you want and has a similar carbon content to Silver steel |
speelwerk | 29/06/2022 08:10:44 |
464 forum posts 2 photos | Punches of a watchmaker staking tool I have (Boley/Star/Bergeon/Helios) all are 4.7mm diameter, why I don't know but t is not handy if you want to make your own punches. The guide bush for the punches on top of the tool has its bore placed eccentric and a small spring loaded ball to prevent the punchen from sliding down but it would be not to difficult to make one with a 5mm bore. Niko. |
Hopper | 29/06/2022 08:12:08 |
![]() 7881 forum posts 397 photos | Knocking two thou off a piece of 3/16" in the lathe to reduce it from .187" to the desired .185" (4.7mm) shouldn't be too hard should it? Bit of emery tape would do the job pretty quickly. Or a fine cut with an HSS toolbit if the job is held dead true in a collet or 4-jaw. Depends on how many punches you want to make though. A dozen or so should be easy enough. More than that could be a bit tedious I'm sure. Edited By Hopper on 29/06/2022 08:12:41 |
Peter Cook 6 | 29/06/2022 15:02:19 |
462 forum posts 113 photos | Thanks for the feedback. McMaster-Carr has exactly what I need and at US$6.29 for a 3ft length! However they don't ship to Europe. Bill, I have asked Phoenix for a quote for a couple of 1 Metre lengths, and have also asked an outfit called raptorsupplies who claim to supply any McMaster-Car part in UK. Hopefully their prices will not resemble their name! Hopper - taking a bit of 3/16 down is my fall-back position, but if I could get the material for anything like McMaster-Carr's price I would do so in preference. Jason, not sure 12g piano wire is the same wire guage - all the suppliers I can find make 12g = 0.75mm i.e. AWG rather than Stubbs. Niko, there is a bit of a discussion about the reason behind the size used at https://mb.nawcc.org/threads/identify-staking-punch-and-size.135442/post-1048863 Thanks again. Edited By Peter Cook 6 on 29/06/2022 15:18:44 |
JasonB | 29/06/2022 16:36:02 |
![]() 25215 forum posts 3105 photos 1 articles | Always been SWG when I have bought it, same with the first few hits on google |
Dave Halford | 29/06/2022 16:55:40 |
2536 forum posts 24 photos | Posted by Peter Cook 6 on 29/06/2022 15:02:19:
Jason, not sure 12g piano wire is the same wire guage - all the suppliers I can find make 12g = 0.75mm i.e. AWG rather than Stubbs. Thanks again. Edited By Peter Cook 6 on 29/06/2022 15:18:44 I just thought it was for a really big piano |
Michael Gilligan | 29/06/2022 17:24:55 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 29/06/2022 16:36:02:
Always been SWG when I have bought it, same with the first few hits on google .
Why would anyone want 2.65mm [or thereabouts] wire to make 4.7mm punches ? MichaelG. |
JasonB | 29/06/2022 18:16:41 |
![]() 25215 forum posts 3105 photos 1 articles | The heading is asking for 4.7mm or 12gauge 2,642mm is 12gauge by the SWG standard. Unless Stubbs had their own gauge system? |
Peter Cook 6 | 29/06/2022 18:18:30 |
462 forum posts 113 photos | They wouldn't want 12 SWG which is as you say 2.65mm diameter. No 12 piano wire (AMWG - not AWG my mistake in the reply post) is 0.75mm They would want #12 Stubbs steel wire guage an old and probably obsolete wire guage. Not to be confused with Stubbs Iron wire guage. The Stubbs #12 steel is 4.7mm. This from a K&D catalogue of staking tools dated 1910. They seem to have been the instigator of such devices, and everyone copied their standard. Edit - the metric to inch conversions presumably use the US inch rather than the UK inch - they were different at the time, only standardised to 25.40mm in the 1960's Edited By Peter Cook 6 on 29/06/2022 18:27:00 Edited By Peter Cook 6 on 29/06/2022 18:28:42 |
JasonB | 29/06/2022 18:27:40 |
![]() 25215 forum posts 3105 photos 1 articles | Thanks For that peter, did not know they had their own system. Think I had brain fade this morning and had 2.7mm in my head not 4.7 Edited By JasonB on 29/06/2022 18:31:27 |
Michael Gilligan | 29/06/2022 20:49:42 |
![]() 23121 forum posts 1360 photos | I am now unconfused/deconfused [or whatever] … MichaelG. |
Peter Cook 6 | 30/06/2022 12:51:51 |
462 forum posts 113 photos | OK 3/16 and time on the lathe it is. Phoenix only offered 3/16 not 4.70 special. Raptor supplies wanted £16.70 each for the bars, £63.00 shipping and handling plus Vat so £115+ for two items totalling US$12.50 at McMaster-Carr. |
Nick Clarke 3 | 30/06/2022 16:39:02 |
![]() 1607 forum posts 69 photos | Tracy Tools list drill branks in all sizes if that would be long enough? |
Michael Gilligan | 30/06/2022 16:50:18 |
![]() 23121 forum posts 1360 photos | Posted by Nick Clarke 3 on 30/06/2022 16:39:02:
Tracy Tools list drill branks in all sizes if that would be long enough? . That sounds ideal MichaelG. Edited By Michael Gilligan on 30/06/2022 16:50:40 |
