Greensands | 15/06/2022 11:05:03 |
449 forum posts 72 photos | In the process of making up a batch of 10BA screws I have discovered that in order to avoid the screws from being lost in the swarf it is quite effective to capture it using an old toothbrush. Nothing new under the sun of course but it works for me and it avoids meddlesome fingers near a rotating chuck. |
peak4 | 15/06/2022 11:26:00 |
![]() 2207 forum posts 210 photos | Nice one, for larger items, I tend to catch them in aluminium foil ready meal trays. |
Dave Halford | 15/06/2022 12:04:31 |
2536 forum posts 24 photos | I use the grill tray from our previous oven |
Dave Wootton | 15/06/2022 13:23:27 |
505 forum posts 99 photos | What a good idea, well thought out, I'm about to make some batches of 8 ba PB screws for boiler construction I'll definitely give this a go. Dave |
David Noble | 15/06/2022 13:35:50 |
![]() 402 forum posts 37 photos | Yes, it was new to me David |
Nick Wheeler | 15/06/2022 14:00:50 |
1227 forum posts 101 photos | When parting off parts with a bore, I catch them on a short length of welding filler rod held in the tailstock chuck. |
DMB | 15/06/2022 14:46:15 |
1585 forum posts 1 photos | I have a small muck tray under the chuck, travels with the saddle, slotted to slide under the hex hd BSF screw in the lower left side. Myford tapped it to hold their travelling steady which I rarely use or need. Small parted off items drop into tray. Use old toothbrush to sweep swarf overboard down back of lathe where it falls into an old shallow baking tray for occasional clean up. The permanently fitted BSF screw keeps swarf out of the tapped hole. Tray keeps muckiest part of lathe bed clean. John |
larry phelan 1 | 15/06/2022 16:18:13 |
1346 forum posts 15 photos | Baking trays, pots [no longer required by SWMBO ], where would we be without them ? Also the old" piece of wire in the tailstock trick ", great for catching spacers or thick washers. Simple, but they work ! |
old mart | 15/06/2022 17:52:35 |
4655 forum posts 304 photos | I can loose 1/2" bolts in the swarf in the lathe, no bother. |
duncan webster | 15/06/2022 19:59:53 |
5307 forum posts 83 photos | Well have a tidy up then! |
Neil Lickfold | 15/06/2022 20:33:13 |
1025 forum posts 204 photos | With a small amount of cutting oil, the brush will also lubricate as it holds the small parts. I like the brushes with the extended front bristles , as they will reach into the groove being created. |
Sam Longley 1 | 15/06/2022 21:00:24 |
965 forum posts 34 photos | I'd be worried about the wife swallowing a screw in the morning |
Howard Lewis | 15/06/2022 22:00:59 |
7227 forum posts 21 photos | Having made a John Ashton Universal Screw Modification Fixture, I use that. It means making a holder for every size / thread of screw, (And I HATE mass production, the score now stands at over a dozen! ) but it holds the screw firmly so that it cannot screw itself back in, or get lost. The time making it and the various holders (From 8-32 UNC up to M8 ) was well spent. Howard. |
DiodeDick | 15/06/2022 23:15:50 |
61 forum posts 10 photos | If it has a hole in it, I use a bit of something small enough in the tailstock chuck, as per Nicholas above. If it does not have a hole in it I catch it in a bit of 15mm copper tube, with the bottom end blocked with a wad of kitchen roll. If it is too big for 15mm tube, use bigger tube. Either way, watch your fingers. Dick |
Dave S | 16/06/2022 20:21:12 |
433 forum posts 95 photos |
Huub | 16/06/2022 22:25:52 |
220 forum posts 20 photos |
