Rich2502 | 09/05/2022 14:15:41 |
83 forum posts 3 photos | Any one retro fitted a leadscrew to a small lathe? ( 15-20" between centres ) There are now motor controlled set ups withh off the shelf ballscrews that require no gear train so that would cut out a lot of the work. Is this a practical project or a rabbit hole ?
Clive Foster | 09/05/2022 14:20:18 |
3630 forum posts 128 photos | In principle pretty practical but, as you will only do it once, bound to be 5 times the work and general futzing about than you expected. Lots of careful measuring beforehand will be essential. This is the sort of job that really makes you wish for decent 3D CAD skills. Clive |
John P | 09/05/2022 14:51:02 |
451 forum posts 268 photos | Posted by Rich2502 09/05/2022 14:15:41
There are now motor controlled set ups withh off the shelf ballscrews that require Is this a practical project or a rabbit hole ? ------------------------------------------------------------
Martin Connelly | 09/05/2022 14:59:55 |
![]() 2549 forum posts 235 photos | Are you starting off with a lathe with no leadscrew? Often people with electronic leadscrews just add a stepper drive to an existing leadscrew. This allows the half nuts to be engaged and disengaged as required. Adding a ballscrew and nut would require a different way of working as there are no half nuts that work with ballscrews. You may have to come up with a way to disengage the carriage drive and move the ball nut away from the carriage if you wanted to do something that required moving the carriage manually. Back driving the ballscrew may not work. A permanently fitted ballscrew drive is halfway to having a CNC lathe, is this your aim? Martin C
JasonB | 09/05/2022 15:58:06 |
![]() 25215 forum posts 3105 photos 1 articles | If it is a small watchmakers type lathe with a clamp on saddle and no existing leadscrew then the saddle will probably not be designed to slide up and down the bed like on a larger lathe so you may get problems with twist and racking of the carriage. |
Frances IoM | 09/05/2022 16:20:14 |
1395 forum posts 30 photos | The Taig/Peatol small lathe has no leadscrew - there is, or was, a commercial addon package tho my lathe came with a jury rigged leadscrew using a threaded rod and a nut formed by bit of thin plate, the original rack + gear having been removed - I re-installed the rack as it felt more comfortable but if it were my only lathe think I would look towards a leadscrew of some form. |
bernard towers | 09/05/2022 17:06:34 |
1221 forum posts 161 photos | Look at deansphotgrafia site this shows Taig leadscrew fitting. |
Peter Cook 6 | 09/05/2022 19:19:58 |
462 forum posts 113 photos | There is an example of a leadscrew setup I fitted to a Taig here. |
Steviegtr | 09/05/2022 19:25:57 |
![]() 2668 forum posts 352 photos | Have a look at Ades workshop on Youtube . He is doing one now. Along with a lot of other upgrades. Steve. |
