Cracked motor foot
AJAX | 01/05/2022 17:49:49 |
433 forum posts 42 photos | Can anyone suggest a suitable method to repair this broken casting on a foot-mount motor? I would prefer something that looks good and strong (rather than JB Weld and some thick paint) but I would prefer not to invest too much time or money. My stick welder is not suited to this job but I do have a good propane torch which I only use for heating parts up for assembly/disassembly. I have no experience using aluminium brazing rods. I realise there are cheap brazing rods available online but I'm guessing they are not particularly good. I may end up pinning the joint, but I may need another look to see if this is possible. Pinning could also be combined with wrapping some flat around the corner and screwing it for reinforcement. However, I don't expect this would look very pretty. I look forward to your suggestions. |
Brian Wood | 01/05/2022 18:04:56 |
2742 forum posts 39 photos | I have made repairs with the aluminium brazing rods which are strong enough in that sort of thickness. They look satisfactory too I recommend you try them. Be sure to use a stainless steel brush to abrade the joint all round before you apply heat, the brazing torch should be quite adequate, this is not high temperature work Regards Brian |
AJAX | 01/05/2022 18:13:34 |
433 forum posts 42 photos | Posted by Brian Wood on 01/05/2022 18:04:56:
I have made repairs with the aluminium brazing rods which are strong enough in that sort of thickness. They look satisfactory too I recommend you try them. Be sure to use a stainless steel brush to abrade the joint all round before you apply heat, the brazing torch should be quite adequate, this is not high temperature work Regards Brian Thanks for your suggestion, Brian. Do you think it would be a good idea to grind the crack out a bit before brazing? Vee-groove all round? I could do this quite easily with a rotary burr. As it stands, it would be impossible to clean the faces inside the crack without opening it up somehow. Do the brazing rods work well in filling cracks and if so what is the optimal gap? |
Pete Rimmer | 01/05/2022 18:22:25 |
1486 forum posts 105 photos | I'd tig weld that for you if you were able to bring it to me in N Kent. |
AJAX | 01/05/2022 21:00:42 |
433 forum posts 42 photos | Posted by Pete Rimmer on 01/05/2022 18:22:25:
I'd tig weld that for you if you were able to bring it to me in N Kent. Pete, that's very kind of you to offer; however, I'm going to get some brazing rods and give it a try on some scrap. I'd like to see if I can do it myself as it could be a useful skill for future tasks. |
AJAX | 01/05/2022 21:25:16 |
I have made repairs with the aluminium brazing rods which are strong enough in that sort of thickness. They look satisfactory too I recommend you try them. Be sure to use a stainless steel brush to abrade the joint all round before you apply heat, the brazing torch should be quite adequate, this is not high temperature work Regards Brian Brian, what is the claimed melting temperature of the rods you used? Most seem to be 392 C with some more expensive ones that claim 300 C. |
Bezzer | 01/05/2022 22:18:28 |
203 forum posts 16 photos |
For similar jobs I use Benzomatic Aluminium solder rods. Unlike other makes you don't need to keep scratching the surfaces with a stainless brush, the flux stuff it's coated with lets it work without. Will be strong enough for your job, I've butt welded alloy tube to alloy plate with it and had to really whack it with a club hammer a couple of times to break it. This is a thermostat housing off an old bike I repaired with it, just make sure the surfaces are really cleaned up first, I used a burr on it to get to bright metal on this. |
noel shelley | 01/05/2022 22:33:11 |
2308 forum posts 33 photos | If your using the low temp rods and can weld FORGET ALL YOU KNOW ! Read the instructions and do JUST AS IT SAYS. I have used these rods with success on a high load job and was amazed that it held. There are numerous trade names, though for aluminium they are not made of that metal, I think it is a high Zinc alloy. You need to heat the whole casting, not just the broken area, and when it flows it will be a strange event, BUT IT WORKS ! Good Luck Noel. |
Steviegtr | 01/05/2022 23:39:25 |
![]() 2668 forum posts 352 photos | I too have used that method on a Renault alloy sump , that had hit a brick. It was a proper mess. But those rods worked well & it never leaked oil. Steve. |
Brian Wood | 02/05/2022 09:06:52 |
2742 forum posts 39 photos | AJAX, I don't know what the melting temperature is for the rods I used, I made up some cranked carriers in thin aluminium box section to hold a starter switch out over the back of a lathe. It has worked well. As others have said, do the job using the instructions supplied and without doing any vee prepping, just flow the metal into the joint.. I think you will be pleased with the result
Baz | 02/05/2022 11:01:32 |
1033 forum posts 2 photos | I bought some of the rods that were being demonstrated at the Harrogate exhibition quite a few years ago, I used them to build up a couple of Sweet Pea loco smokebox saddles that had been fettled way too much and there was nothing to machine. This stuff built the edge up beautifully and stayed put through subsequent machining operations |
Ronald Morrison | 02/05/2022 11:14:49 |
98 forum posts 4 photos | Posted by AJAX on 01/05/2022 21:00:42:
I'd tig weld that for you if you were able to bring it to me in N Kent. Pete, that's very kind of you to offer; however, I'm going to get some brazing rods and give it a try on some scrap. I'd like to see if I can do it myself as it could be a useful skill for future tasks. The aluminum brazing rods will probably do everything you need for this repair. However, do be aware that this is an irreversable repair. Once done, TIG welding is no longer an option. The area to be TIG welded would be contaminated by the brazing rod. |
Nicholas Farr | 02/05/2022 11:38:33 |
![]() 3988 forum posts 1799 photos | Hi, I've got some Taymar 3520 & 3530 which were in a clearance sale in one of the big DIY stores, there is no melting temperature on them, but Farnell have the same numbers in their list which may give you an idea Alloy repair rods I've also got some GoGas AR2423 ones as well which Cromwell have GoGas repair rods I've had these for several years, but never used any of them, so I can't vouch as to how good they are or not. Here's the instructions for the AR2423 ones. Regards Nick. Edited By Nicholas Farr on 02/05/2022 11:52:41 |
Bazyle | 02/05/2022 12:03:35 |
![]() 6956 forum posts 229 photos | As this is Al can this kind of job be done with simple propane rather than acetylene or is the heat too diffuse? |
Brian Wood | 02/05/2022 12:40:56 |
2742 forum posts 39 photos | Bazyle, A propane flame is quite hot enough, no need for oxy-acetylene, that might meld the part you are trying to repair. Brian |
AJAX | 06/05/2022 20:50:14 |
433 forum posts 42 photos | I thought it might be useful to give a quick update. I bought some cheap "aluminium brazing rods" with a claimed melting temperature of circa 390 degrees. Not having used any before, I gave them a quick try on some scrap aluminium - an extruded finned aluminium heat sink from a power supply. I started off gently but found I had to turn up the gas to reach a suitable temperature which I checked with a non-contact thermometer. The brazing/soldering worked just fine and gave a good looking joint. I was quite impressed. Buoyed by my initial success with the heat sink, I turned my attention to the broken casting. Lucky I was paying attention as the casting had a much lower melting temperature! I had barely started before it visibly softened. There was no chance of the rod melting at that temperature so I abandoned the job before it vaporized. I'm guessing it was an aluminium / zinc alloy. The casting has now been drilled and screwed together, with a good dose of strong epoxy. I'm quite happy to have tried the brazing rods and I would use them again given a suitable material. |
AJAX | 06/05/2022 20:51:46 |
433 forum posts 42 photos | Posted by Brian Wood on 02/05/2022 12:40:56:
Bazyle, A propane flame is quite hot enough, no need for oxy-acetylene, that might meld the part you are trying to repair. Brian Even propane was hot enough to melt the broken casting. |
noel shelley | 06/05/2022 21:40:27 |
2308 forum posts 33 photos | Propane is more than hot enough and great care is needed to control the heat and get the rod / work to flow. I would say that you had TO MUCH heat. The heating is VERY critical. Noel. |
not done it yet | 06/05/2022 22:17:29 |
7517 forum posts 20 photos | There is very little load on that piece, when tightened down - using suitable washers. It’s basically here as a means of providing a ‘pivot’ - like hold-down kits for holding bits on milling machine tables. |
AJAX | 06/05/2022 22:33:23 |
433 forum posts 42 photos | Posted by noel shelley on 06/05/2022 21:40:27:
Propane is more than hot enough and great care is needed to control the heat and get the rod / work to flow. I would say that you had TO MUCH heat. The heating is VERY critical. Noel. Too much heat for the casting but not enough for the rods I was using. That's why I decided they were unsuitable for this job. And as "not done it yet" suggests, there will be minimal load on this part so I'm happy with my screwed and glued repair. |
