Peter Simpson 3 | 20/03/2022 11:28:29 |
122 forum posts 2 photos | Looking to roll a 5" gauge copper boiler !/8" thick copper plate. What rollers would be suitable ? There load of rollers on the Bay. but they only go up to 1.2 mm thickness |
Andrew Tinsley | 20/03/2022 11:54:43 |
1817 forum posts 2 photos | You don't need rolls. I simply make a former and bend the sheet around it. You will need to keep annealing the sheet between bends as it will work harden. Fully annealed copper is surprisingly soft and bendable. Andrew. |
noel shelley | 20/03/2022 11:54:46 |
2308 forum posts 33 photos | BIG ish ones ! Soft hammer and a round wooden block, anneal as needed ! Easy way would be to pop round to a friendly small engineering works and offer beer tokens, may be a lunchtime job ? Or copper tube at 3mm wall ? Good luck. Noel |
Nick Clarke 3 | 20/03/2022 12:06:50 |
![]() 1607 forum posts 69 photos | Has your local ME society got some larger bending rolls? - mine has. Where are you approximately in the country? |
Dave Halford | 20/03/2022 14:33:33 |
2536 forum posts 24 photos | Blackgates do 5" copper tube in 10G. |
duncan webster | 21/03/2022 21:59:34 |
5307 forum posts 83 photos | LBSC recommended bending boiler shell round a downspout. I don't! I'd take up Noel's suggestion, one anneal will get you from flat to round at 5" diameter. However, if you're aiming for the usual 80-100 psi working, you can get away with 13g for a round shell, more difficult if the back end is opened out for the firebox outer wrapper. If you go down this route take your boiler inspector along with you |
Speedy Builder5 | 22/03/2022 06:39:56 |
2878 forum posts 248 photos | If you are looking for rollers, make sure the are "slip rollers" so you can slip your tube off the end once rolled ! |
Paul Lousick | 22/03/2022 06:49:46 |
2276 forum posts 801 photos | Copper sheet is expensive, especially if you stuff it up and have to buy a second sheet. A set of slip rolls is also expensive and a costly ornament if you do not have another use for them. For a one-off project, best to take the plate to a local engineering business. |
Peter Simpson 3 | 28/03/2022 18:41:25 |
122 forum posts 2 photos | After phoning numerous engineering companies, non of which were remotely interested in doing the work. I have two choices. Buy flat 3mm sheet and form it round a 4" tube. Buy 5" diameter 10 SWG tube a cut the relevant triangle out to form the the 4.5" diameter smoke box end. Sheet is cheaper but tube may be easier.. What the thoughts of the experts ? |
Speedy Builder5 | 28/03/2022 19:34:08 |
2878 forum posts 248 photos | I am surprised that (Unless Peter has has a personal message) nobody here has offered to roll Peter's barrel. Bob |
JasonB | 28/03/2022 19:42:59 |
![]() 25215 forum posts 3105 photos 1 articles | Maybe not many members with large enough rolls, and from his latest post looks like it would really want rolls that can do tapers |
Simon Collier | 28/03/2022 20:43:12 |
![]() 525 forum posts 65 photos | I’ve rolled 3 mm copper using large rolls donated to the club. I had to keep annealing it with my 2944 burner. Rolled to 6-1/4” with slight taper. The member who donated them moved away and some time later they vanished. He undonated them! Hardly anyone is going to have rolls big enough. I suggest making a former from stacked plywood disks. With multiple annealings and using hands, hammers and band clamps, it can be done. Buying 5” tube would be so much easier. |
duncan webster | 28/03/2022 21:57:06 |
5307 forum posts 83 photos | If OP reveals where he is based we might be able to suggest firms we know of |
