How do you deal with this=Inaccuracy Z-Axis
Chris Mate | 09/03/2022 16:53:33 |
325 forum posts 52 photos | Hi, How do you deal with the quil play before & after you lock it down regarding the Z-Axis accuracy. |
JasonB | 09/03/2022 16:59:45 |
![]() 25215 forum posts 3105 photos 1 articles | I lower the head to put on a cut not the quill on my X3. Much like any larger knee mill where the table is raised to put on a cut keeping the quill retracted and locked for rigidity |
Andrew Johnston | 09/03/2022 19:22:54 |
![]() 7061 forum posts 719 photos | Posted by JasonB on 09/03/2022 16:59:45:
...like any larger knee mill where the table is raised to put on a cut... +1 I only use the quill for drilling and boring. For all milling the quill is retracted, and locked, and Z feed put on by raising the knee. Andrew |
Bill Davies 2 | 09/03/2022 20:35:53 |
357 forum posts 13 photos | The ZX45-type milling machines aren't knee mills, they have a heavy head (inc. motor+gearbox) that slide on the column. I use the quill for small vertical adjustments, and lock everthing except the moving axis (and put *some* locking pressure on that one). There can be some slight judder on the head coming down, less so moving up, but it can be adjusted before starting a cut. Mine is used infrequently and I give all the slides a good oiling before using it to minimise slip-stick friction. I might make Z-axis readout using a digital caliper, to get a better sense of vertical movements; I wouldn't bother on X and Y axes. Bill
JasonB | 09/03/2022 20:41:28 |
![]() 25215 forum posts 3105 photos 1 articles | That's is why I said "like a knee mill". Move a heavy head as I do with the X3 or move a heavy table, not much of a difference but keeping the quill protrusion to a minimum will help with rigidity and allow the DRO on the head to be used rather than fiddling about with a dti etc. |
fizzy | 09/03/2022 20:45:50 |
![]() 1860 forum posts 121 photos | I have two of these and only recently have I noticed this problem. You cant move the head as its on a round column and when loose will revolve. I have taken to keeping the bit as close to the work as possible at start up, keeping a slight bite on the quill when lowering and then tighten it back up - not ideal I know.
JasonB | 09/03/2022 20:48:10 |
![]() 25215 forum posts 3105 photos 1 articles | Chris has a Dovertail column on his machine so no issue with the head rotating. |
DiogenesII | 09/03/2022 21:53:40 |
859 forum posts 268 photos | Posted by fizzy on 09/03/2022 20:45:50:
I have a Major mill/drill and as with yours I have to put on cut with the quill - sometimes it's easier to pull the work clear of the cutter, 'overshoot' the depth and then catch it at the right spot with the lock, on the way back up.. ..it's easier with a dro.. Although I haven't really done any 'fettling' of the machine, one thing I did do was to make a new dog-point bolt to engage the quill slot - the fitted one was awful, a p***poor fit, and hacked off at the end - a new one made the action less erratic& easier to predict. |
Paul Lousick | 09/03/2022 21:55:53 |
2276 forum posts 801 photos |
Raising and lowering the column with the crank lever on the column is a cause feed and I use the quill for fine adjustment. I can lower the quill buy less than 0.1mm for fine cuts.. It does not change when I lock the quill.
Bill Davies 2 | 09/03/2022 22:12:06 |
357 forum posts 13 photos | Sorry, JasonB, I misread your intentions, and I didn't know that the X3 was a similar mill. Bill |
Chris Mate | 09/03/2022 23:01:40 |
325 forum posts 52 photos | Thanks for the replies. What confused me, was the quill had a "fine adjust" which you engage specially to make that function work, that what lead me to use the quil for fine adjust face milling as experiment, I then soon realise it will be difficult to mill accurately this way. -I think I am going to give this extention of the crank handle a thought again for the head adjustment, you get these small gearboxes in different ratios.. Edited By Chris Mate on 09/03/2022 23:04:57 |
Paul Lousick | 10/03/2022 01:48:54 |
2276 forum posts 801 photos | Hi Chris, Mine is the same mill and I always use the fine adjust knob to lower the cutter and don't have a problem. As I have said, I can do fine finishing cuts of less than 0.1mm. The fine adjust wheel has a positive feel and a slight turn will raise or lower the quill without any backlash. The quill height does not change when I lock it in position. The RF-45 milling machines are designed by Rong Fu in Taiwan. Mine was made there but sold in Australia buy Machinery House as a HM-46. There are lots of other clones and I believe the ZX45 is made in China. I'm not sure it they are made to a different standard but I recommend the one I have.
JasonB | 10/03/2022 07:09:37 |
![]() 25215 forum posts 3105 photos 1 articles | One reason I went for the X3 is the head handle is at the front. As for putting on a fine cut I can quite happily lower by 0.01mm so if Paul's example is anything to go by then still quite coarse. I believe the Bridgeports as in what Andrew has also have a similar fine feed that can be engaged to lower the quill but he chooses not to use it except the autofeed for boring as do a lot of Bridgeport owners. |
Paul Lousick | 10/03/2022 09:40:06 |
2276 forum posts 801 photos | My memory is not as good as it used to be, and I did say less than 0.01mm, so I went to the workshop to check it. I can lower the quill by 0.005mm increments and lock it in that position. I am using Easson scales which have a resolution of 5µm. |
Cabinet Enforcer | 10/03/2022 15:17:52 |
121 forum posts 4 photos | Chris, it is hard to tell exactly what you are asking about, is your quill moving a lot when you clamp it, or are you just asking about how to keep track of Z axis movement? It is true that you need to take care not to wind down the fine feed while the quill clamp is engaged, the mental discipline comes easily once you have spoiled a couple of parts
The fine feed should have markings on the handle, same as the x and y, so in a pinch you can count those. Otherwise many of these mills have a cheap caliper type readout attached to the quill which while not as nice as a proper DRO is very useful, and despite mine having fittings which are not wholly convincing in their ridgidity, seems fairly repeatable. It looks like this one: Another option is to improve the awful depth stop, as detailed by Stefan Gotteswinter here: Stefan also later fitted a proper DRO to the quill, which can be seen in this more recent video dicussing other modifications: Edited By Cabinet Enforcer on 10/03/2022 15:18:49 |
Chris Mate | 10/03/2022 19:05:10 |
325 forum posts 52 photos | Hi, basicly I observe 2 types of play, and unlike the X/Y horizontal axis, you got something that wants to come down with the play involved, the return spring also play a role.(I will look further into this tention) |
Chris Mate | 10/03/2022 22:50:17 |
325 forum posts 52 photos | I did some thinking and going to try it out, the dial indicator will show if theres a difference or not. |
Paul Lousick | 11/03/2022 08:12:35 |
2276 forum posts 801 photos | The quill on my mill has a fair amount of tension and If I release the lock with the fine feed dis-engaged and do not hold onto the drive levers, it flies up and bottoms out with a big thump. The strong spring tension could be why I don't have any backlash. |
Chris Mate | 11/03/2022 15:32:17 |
325 forum posts 52 photos | Ok, I think I made some progress....Play down from .1mm..........."Spongy/Leaky"........to .01mm.....more down to .......Zero movement. This is way better than I experienced after doing the following: --------Sometimes I get .01 when I locked the quil, way better but not stable. Edited By Chris Mate on 11/03/2022 15:33:12 Edited By Chris Mate on 11/03/2022 15:34:16 Edited By Chris Mate on 11/03/2022 15:37:22 Edited By Chris Mate on 11/03/2022 15:38:00 |
Paul Lousick | 11/03/2022 20:34:19 |
2276 forum posts 801 photos | Hi Chris, How old is your mill ? If its still under warranty, go back to the supplier to fix the problem.
