Seized aluminium threads Tilley Lamp Pump
jon hill 313/02/2022 15:17:51
166 forum posts
40 photos
Acquired a Tilley Lamp with a defective pump only to find on taking out the pump that the threads are seized. I tried soaking in paraffin and gripping the body in the vise but no matter how much swearing and cussing it still wont open.wink
Any possible solutions? The threads I am trying to open are all ali on ali.
Grindstone Cowboy13/02/2022 15:43:52
1160 forum posts
73 photos
Heat, preferably not from an open flame unless you've got rid of most of the paraffin. I'mm becoming a convert to the hot-air guns in preference to blowlamps for this kind of thing.
Repeated cycles of heat/cooling may just break things free.
Rob
Howard Lewis13/02/2022 16:02:20
7227 forum posts
21 photos
If the problem is caused by corrosion, it may be posible to free things off by placing the pump on a hard surface and fairly gently rapping with a hammer, whilst it is rotated.
The objective is to produce just enough temporary distortion to break the corrosion, without any permanent.
It certainly works for rusted steel components, but obviously, not in every case, if the problem is severe.
Bo'sun13/02/2022 16:06:58
754 forum posts
Hi Jon,
The very best of luck, but if all else fails, try "The Base Camp" in Peterborough for a replacement pump.
JasonB13/02/2022 17:18:56
Or Tilley who are near Guildford
jon hill 313/02/2022 20:03:13
166 forum posts
40 photos
Tried all the above thanks guys. I think gripping the shaft with a pair of plumbers grips and a piece of rubber tube worked wonders without marking the metal.
Heres a pic of the burner in action:
Bo'sun14/02/2022 13:05:08
754 forum posts
Hello Jon,
Does the lamp work OK now? I've had problems getting my Tilley's to work as they did some years ago.
Flames outside of the mantle, pulsating and not very bright light.
Cleaned and changed everything, including new vapourizers without much luck. The only thing that seems to have changed is the fuel. Esso Blue and Aladdin Pink worked fine years ago.
Any thoughts welcomed.
Howard Lewis14/02/2022 18:51:07
7227 forum posts
21 photos
It is very likely that was is called paraffin (kerosene ) is quite different from the fuel for which the lamps were designed and developed.
Very probably the fuels have been modified to be more friendly to the environment and users. Possibly to the detriment of calorific value!
Howard.
duncan webster14/02/2022 20:08:14
5307 forum posts
83 photos
Just a warning, the old mantles of gas/Tilley lamps had Thorium in them, which is mildly radioactive. Probably nothing to worry about, but I always change them outside with my back to the wind, then the dust etc blows away from me and doesn't get inhaled. I seem to think modern ones are made from something else. We used a lot of Bullfinch lights when I was a scout leader. My successor managed to set fire to the mess tent by not being sensible with them, but I'd left by then.
SillyOldDuffer14/02/2022 21:48:59
10668 forum posts
2415 photos
Posted by Bo'sun on 14/02/2022 13:05:08:
...I've had problems getting my Tilley's to work as they did some years ago.
As far as I know Paraffin/Kerosene is the same light oil as always. No alcohol or anything that might spoil vaporisation unless the oil came from a dirty container. Other additives are possible: Esso Blue and Pink Paraffin had a dash of dye in them and Lamp Oil had something to reduce the smell, but I wouldn't expect them to stop a lamp working.
Air leak due to dirt or corrosion? Pulsating suggests low pressure.
duncan webster15/02/2022 00:23:51
5307 forum posts
83 photos
I just checked the price of paraffin at B&Q. £10 for 4 litres. Are they having a laugh, that's more expensive than petrol and there is a lot less tax on it
Caldo in St Helens have 3 grades of paraffin, Standard, Premium Pure and Aga, no idea what the difference is, a phone call would probably elucidate
Bo'sun15/02/2022 13:39:18
754 forum posts
Thanks Duncan,
I'm currently using Caldo "Premium". It's an improvement over the greenhouse heater stuff from B&Q, but still leaves a little to be desired as described earlier.
Samsaranda15/02/2022 15:59:42
1688 forum posts
16 photos
Is it worth trying the Coleman fuel that is used in camping stoves and lights, available from Millets not sure of the price as it’s a long time since I bought any. Dave W
Bo'sun15/02/2022 16:26:37
754 forum posts
Hi Samsaranda,
Isn't Coleman fuel more like petrol? I thought Coleman lamps and stoves worked differently to the Tilley and Primus principle.
Steambuff15/02/2022 16:28:38
544 forum posts
8 photos
Coleman camp fuel is "white gasoline/petrol" .
Never use Coleman Fuel or gasoline/petrol in a kerosene/paraffin stove or lamp!
Edited By Steambuff on 15/02/2022 16:30:27
SillyOldDuffer15/02/2022 16:40:00
10668 forum posts
2415 photos
Posted by Samsaranda on 15/02/2022 15:59:42:
Like petrol, I think Coleman's a very light spirit that's likely to go bang or start a fire. White Spirit isn't recommended because it gums up the nozzle. I suspect diesel is too viscous to spray properly - anyone tried it?
The lamp works by blowing a light oil, normally paraffin aka kerosene through a narrow nozzle to create a spray that vaporises in a hot chamber full of air and then burns inside the mantle. The mantle glows white hot and creates the light.
To work the lamp has to be:
  • Filled with a light oil that sprays out of a suitable nozzle and then vaporises fully at operating temperature
  • Actually creating the spray. i.e Nozzle sized to match the viscosity of the oil and operating pressure range. Important it's not blocked by dirt or gummed up both problems caused by dirty or unsuitable oil.)
  • Mixing air with vaporised spray in the correct proportion. (Air input and chimney both clear. )
  • Flame hot enough to activate the mantle (oil needed, I doubt meths is hot enough.)
  • Mantle and base in good condition.
  • Able to hold the pressure produced by the air pump, i.e. no air leaks in the container or seals.
Be interesting to know if the spray nozzle has a plain or tapered hole. It might matter if the design has changed over the years to improve burn efficiency by tweaking nozzle shape and delivery pressure. I doubt it. Not fired up a Tilley lamp since my son was a baby when four of them were lit on holiday. I don't remember lamp-lighting being a fiddly job - much easier than my dad's brass blowlamp.
Edited By SillyOldDuffer on 15/02/2022 16:40:26
Bo'sun15/02/2022 16:41:16
754 forum posts
I thought so!
DiogenesII15/02/2022 18:02:27
859 forum posts
268 photos
Posted by SillyOldDuffer on 15/02/2022 16:40:00:
.. I don't remember lamp-lighting being a fiddly job - much easier than my dad's brass blowlamp.
Apologies if this teaching Granny, etc.. ..but there is a clip-on pre-heater that has to charged with Methylated Spirit and attached to the tube below the coil in order to provide the heat to first initiate vapourisation - after the lamp lights it should be self-sustaining.. ..at least with a blowlamp one just has to throw some meths in the trough..
Bo'sun15/02/2022 18:22:20
754 forum posts
Hi Dave,
The jet is pretty crude (probably wasn't when they were made originally). It's just a hole in a small plate welded to the top of the vapourizer tube. With a spring loaded "pricker rod" to clear the jet and turn the lamp off by shutting off the spray of paraffin..
Oldiron15/02/2022 18:23:37
1193 forum posts
59 photos
I have many Tilley lamp lights & heaters collected over 35 years as an aside to my passion for collecting old domestic style parrafin lamps. I use bog standard Bartoline brand paraffin bought in most DIY shops or on garage forecourts. Use the preheater with meths to get them really hot before attempting to light them. Get the preheater positioned level with the globe for best results. Turn on the valve very slowly as the preheater flame is on its last legs and you should have no problems lighting them. I always filter the fuel even from a new can with a very fine brass mesh. I have Tiley lamps in my caravan for use outside that have been bumping about under the seats for many many years and the mantles are still in good order.
regards
Edited By Oldiron on 15/02/2022 18:24:01
