Former Member | 11/02/2022 10:28:23 |
1085 forum posts | [This posting has been removed] |
Emgee | 11/02/2022 10:44:57 |
2610 forum posts 312 photos | I would usually drill through both clamped plates with the tapping drill, then use a clearance drill on 1 plate. Emgee |
Thor 🇳🇴 | 11/02/2022 10:52:56 |
![]() 1766 forum posts 46 photos | I too drill through both plates with the tapping drill, then clearance drill. For starting the tapping drill I first use a spotting drill (using the dials on the milling table handwheels to place the spotting drill), then the tapping drill. Thor |
Former Member | 11/02/2022 10:59:59 |
Emgee | 11/02/2022 11:08:20 |
2610 forum posts 312 photos | I would spot it with a drill the same size as the existing hole, only needs a light touch to give a point for the spot or centre drill to use. Emgee |
magpie | 11/02/2022 11:09:04 |
![]() 508 forum posts 98 photos | Spotting drill. |
Hopper | 11/02/2022 11:31:19 |
![]() 7881 forum posts 397 photos | I use the same size drill as the existing hole, so its a nice tight fit when I drill the start of the hole in the other plate, gets the new hole nice and central. Just sink the drill in to the edges of the tip, then change to the tapping size drill or pilot drill if you are going to use one. I don't bother with a centre drill or spotting drill in this instance as the larger drill has already provided the starting divot in the bottom plate. |
John Baron | 11/02/2022 11:54:14 |
![]() 520 forum posts 194 photos | Posted by Hopper on 11/02/2022 11:31:19:
I use the same size drill as the existing hole, so its a nice tight fit when I drill the start of the hole in the other plate, gets the new hole nice and central. Just sink the drill in to the edges of the tip, then change to the tapping size drill or pilot drill if you are going to use one. I don't bother with a centre drill or spotting drill in this instance as the larger drill has already provided the starting divot in the bottom plate. Exactly what I do ! Saves time and you end up with an accurately drilled hole.
Dalboy | 11/02/2022 12:47:49 |
![]() 1009 forum posts 305 photos | If you by chance have a set of transfer punches use them |
JasonB | 11/02/2022 12:55:53 |
![]() 25215 forum posts 3105 photos 1 articles | I'd do them separately using the DRO to set out the holes. Spot and clearance size in one plate. Spot and tapping size in the other and while it's on the mill use that to also guide the tap perfectly perpendicular Missed the edit, if I did not know the hole ctrs then use a spotting drill if I have one that fits existing hole if not use a drill bit of the same size to transfer onto the undrilled material. Edited By JasonB on 11/02/2022 12:58:09 |
larry phelan 1 | 12/02/2022 16:59:58 |
1346 forum posts 15 photos | Hi Br I thought you made it perfectly clear. Must be missing something ? |
