Andy Stopford | 03/01/2022 20:58:23 |
241 forum posts 35 photos | I recently purchased a Warco WM180 lathe. It has Start and Stop buttons, and a speed control. I'm sure I've read somewhere that its undesirable to start the motor with the speed control set above minimum because it can fry control board components; can anyone confirm this? Its a little tiresome having to keep winding the speed control back and forth if frequently stopping the spindle to take measurements. |
Ed Duffner | 03/01/2022 21:33:41 |
863 forum posts 104 photos | Hi Andy, I have a WM180 and never had a problem with the control board in 7 years of use. I usually switch on, then adjust speed as necessary. Ed. |
Andy Stopford | 04/01/2022 18:43:12 |
241 forum posts 35 photos | Thanks Ed, that's good to know. |
HOWARDT | 04/01/2022 19:25:21 |
1081 forum posts 39 photos | Have my Sieg for five years, always turn speed control to zero before switching off and had no trouble with electrics so far. |
Christopher Taylor 1 | 04/01/2022 20:40:34 |
14 forum posts 3 photos | I also had a WM180 and did have to replace control board for starting with the speed set fairly high, a large flash when it happened and not cheap. I have now up graded to a WM250 and have replaced the plug fuse to 5 amps as a precaution and must say the fuses do seem to pop frequently, no doubt due to my over ambitious cuts. I seem to recall there was a sticker on my WM180 warning about starting with the lowest speed setting. I would recommend changing the plug fuse and keep a few spare fuses as a precaution.. |
SillyOldDuffer | 04/01/2022 20:58:02 |
10668 forum posts 2415 photos | It depends on the design of the control board: it might do an automatic 'soft start', and be generously rated or it might not. Unless the instructions say otherwise, I'd always start the motor at the lowest speed. Better safe than sorry! Dave |
Andy Stopford | 04/01/2022 21:08:26 |
241 forum posts 35 photos | Hmm - no warning sticker, but... I might phone Warco and ask - if I get any useful information I'll post it here. |
Andrew Johnston | 04/01/2022 21:16:11 |
![]() 7061 forum posts 719 photos | Posted by Christopher Taylor 1 on 04/01/2022 20:40:34:
..fuses do seem to pop frequently... That's because the 5A fuse is too small. The plug fuse is there to protect the upstream wiring, not the downstream electronics. A fuse is a thermal device and even under overload conditions can take tens to hundreds of milliseconds to blow. The semiconductor devices on the board will blow orders of magnitude faster than that if there is a fault. Using a smaller fuse doesn't achieve anything, apart from increasing the PITA factor. Andrew |
larry phelan 1 | 05/01/2022 09:23:24 |
1346 forum posts 15 photos | I have a Clarke wood lathe [seldom used ] which has a motor like that, and they clearly advise to reduce speed to zero when stopping or starting. Dont like motors like that, but that,s the way it came ! Might be a P-I-T-A, but might be cheaper too. |
noel shelley | 05/01/2022 10:13:12 |
2308 forum posts 33 photos | DO NOT all burst out laughing at my ignorance ! All this talk of stopping and starting motors - I take it they do not have a clutch ? and little or no stepped pulleys to give speed change ? Now I understand why they can be so cheap ! and why machines with a clutch are so much more useable and reliable. Ah well, Noel. |
Andrew Johnston | 05/01/2022 11:01:23 |
![]() 7061 forum posts 719 photos | Posted by noel shelley on 05/01/2022 10:13:12:
....machines with a clutch are so much more useable and reliable. The only one of my industrial machine tools that has a clutch is the horizontal mill. Ah, just remembered that the power guillotine has an electromagnetic clutch. Andrew |
Martin W | 05/01/2022 11:16:01 |
940 forum posts 30 photos | While this doesn't help the OP with his question regarding start up procedures for his lathe. The Chester DB7V that I have has a built in soft start and to date I have had no problem with the electronics even though I rarely set the speed to minimum prior to starting unless I require a high speed setting. The lathe must be over 10 years old now and hasn't missed a beat in that time, famous last words!! As I said this doesn't help the OP but I believe that this illustrates the benefit of soft start procedures be they implemented either electronically or manually so if you are unsure whether your system has a soft start built in then starting at the minimum speed and ramping up to the required operating speed will do the electronics no harm and could well extend their life. |
Andy Stopford | 05/01/2022 19:17:59 |
241 forum posts 35 photos | Posted by Andrew Johnston on 05/01/2022 11:01:23:
....machines with a clutch are so much more useable and reliable. The only one of my industrial machine tools that has a clutch is the horizontal mill. I wouldn't trust these dodgy modern clutches. I drove my industrial horizontal mill the proper way, via fast-and-loose pulleys (I made the pulleys from layered MDF, glued together, and after machining the diameters, painted with several coats of red oxide. They worked surprisingly well and didn't wear away despite my very inexpert use of that wretched alligator lacing stuff). I tried phoning Warco today, but most of the staff seem to be off until next week. |
MikeK | 05/01/2022 20:14:08 |
226 forum posts 17 photos | My 7x16 mini-lathe throws a fault if I turn it on with the speed above zero. I guess others don't have this protection? |
Anthony Knights | 06/01/2022 01:43:14 |
681 forum posts 260 photos | My Clarke CL300 mini lathe has interlock relays and a switch on the speed control pot which means you HAVE to start up from zero speed setting. |
Andy Stopford | 10/01/2022 19:02:24 |
241 forum posts 35 photos | Warco emailed me today to confirm: "Your are correct, these machines should always be started with the knob on minimum as the sudden surge in power when turned on can cause damage to the speed control PCB board." |
John Haine | 11/01/2022 07:25:08 |
5563 forum posts 322 photos | Which means that the design is poor. You would think that for the price of a resistor and capacitor they would add soft start at least, if the power control is that flaky. |
John Haine | 11/01/2022 07:25:09 |
