John Smith 47 | 30/12/2021 13:08:08 |
393 forum posts 12 photos | Hello |
Robert Butler | 30/12/2021 13:45:49 |
511 forum posts 6 photos | A very small radius gauge! Robert Butler |
Nigel Graham 2 | 30/12/2021 13:59:30 |
3293 forum posts 112 photos | "Fillet " normally means an internal (concave) radius, as the root of hot-rolled steel angle, and if its end is accessible it can be gauged with a twist-drill shank. For a radius along an edge, you'd need a radius-gauge - but lacking a set, you could make one by drilling the right-size hole through a slip of sheet-metal, near one corner, and carefully cutting a 90º sector from it. |
David George 1 | 30/12/2021 14:10:29 |
![]() 2110 forum posts 565 photos | Hi John where are you as it may be possible to borrow or use some ones gauges. I personally have sets of Starrett radius gauges in meteoric and imperial from when I did toolmaking at work before retirement. David |
John Smith 47 | 30/12/2021 14:14:46 |
393 forum posts 12 photos | > "Fillet " normally means an internal (concave) radius Edited By John Smith 47 on 30/12/2021 14:19:30 |
peak4 | 30/12/2021 14:30:21 |
![]() 2207 forum posts 210 photos | Most radius gauge sets seem to include blades with measure convex and concave.
Edited By peak4 on 30/12/2021 14:51:57 |
Chris Evans 6 | 30/12/2021 14:59:28 |
![]() 2156 forum posts | When |I was working (toolmaker) this was a daily task. Made easy with a shadograph with resolutions from 10 to 1 up to 100 to 1. Where are you located ? There may be a local company willing to let you use their kit or measure for you for a tea fund donation. |
John Smith 47 | 30/12/2021 15:07:27 |
393 forum posts 12 photos | Yes, unfortunately it seems hard to find anything smaller than 0.3mm. My plan would be to start with smaller radius gauges, and then work my way up in sizes. ==> And at some point the square edges would no longer fit around the square faces of my part, and the gauge start to 'rattle'.
Edited By John Smith 47 on 30/12/2021 15:12:20 |
peak4 | 30/12/2021 15:11:30 |
![]() 2207 forum posts 210 photos | To follow on from my last post, amateur and professional mycologists have the need to measure fungi dimensions under the microscope, and are often working out the sizes of individual spores. Edited By peak4 on 30/12/2021 15:15:40 |
Peter H | 30/12/2021 15:14:02 |
10 forum posts | This tool looks like it will measure the radius from 0-10mm in 0.1mm increments across right angles. Radius gauge 0 - 10 mm, 0,1 mm (0597305)
John Smith 47 | 30/12/2021 15:17:24 |
393 forum posts 12 photos | Nice thinking Bill... however it seems to me that measuring along length of an edge that might be say 2 or 3 cm long, and have a variable (hand made) radius, would be best 'felt' (if technically possible) rather than inspected visually. |
peak4 | 30/12/2021 15:18:06 |
![]() 2207 forum posts 210 photos | Posted by Peter H on 30/12/2021 15:14:02:
I think your link maybe broken, Is it this? |
John Smith 47 | 30/12/2021 15:18:27 |
393 forum posts 12 photos | Posted by Peter H on 30/12/2021 15:14:02:
Peter I can't get that link to work. |
Peter H | 30/12/2021 15:22:47 |
10 forum posts | Bill has posted the correct link. |
John Smith 47 | 30/12/2021 15:29:11 |
393 forum posts 12 photos | Posted by peak4 on 30/12/2021 15:18:06:
I think your link maybe broken, Is it this? Looks cunning, but do any of you know how to use it? I can't work it out! Edited By John Smith 47 on 30/12/2021 15:31:51 |
SillyOldDuffer | 30/12/2021 15:48:12 |
10668 forum posts 2415 photos | Posted by John Smith 47 on 30/12/2021 13:08:08:
I need a tool to enable me to measure the radius of a small convex fillet where two flat faces meet at 90 degrees. Can you clarify please John? Do you want to:
The first finds out what a radius is, the second confirms a radius is within acceptable limits - perhaps a GO/NO GO Gauge. Checking radii in the range 0.1 to 0.3mm is a tough requirement, especially if it has to be done accurately! You can look for light leaking around the corner of a thin plate placed into a gauge, but much harder to detect if a radius is correct along a lengthy edge. Easy: Gets harder with increasing length: Radius gauges are easy enough to buy in larger sizes, but not many tiny ones about. Could be you need a loupe, shadowgraph or microscope. Dave |
peak4 | 30/12/2021 16:03:38 |
![]() 2207 forum posts 210 photos | Posted by John Smith 47 on 30/12/2021 15:29:11:
Edited By John Smith 47 on 30/12/2021 15:31:51 Here you go, shown in use on P53 of their catalogue Edited By peak4 on 30/12/2021 16:05:15 |
Robert Butler | 30/12/2021 16:09:45 |
511 forum posts 6 photos | The Helios Preisser H0597305 radius gauge works by offering the test piece to the gauge with the two relevant edges containing the radius against the gauge and the calibrated angular slide advanced until it touches the radius. A reading is then taken from the Vernier scale and compared to tables supplied? or calculated? I know not which. It all depends on the accuracy of the radius. Robert Butler
Edited By Robert Butler on 30/12/2021 16:11:54 |
Tony Pratt 1 | 30/12/2021 17:25:03 |
2319 forum posts 13 photos | Some sort of shadowgraph would be my tool of choice. Watching this thread with interest to see where it leads. Are we to assume this radius will be machined rather than filed? Tony Edited By Tony Pratt 1 on 30/12/2021 17:26:15 |
Tim Stevens | 30/12/2021 18:31:24 |
![]() 1779 forum posts 1 photos | the link sent by Peter H was caught by an oddity in the software used by ME* - it came out like this: radius%20gauge%200%20-%2010%20mm%2C%200%2C1%20mm%20%280597305%29 Some typesetting and word processing programs use an extra 'hidden' symbol or two to tell the computer what it intended. Here the extra symbols include %, followed by a number, calling up a letter or symbol not in the 'standard alphabet' used in the days of 8-bit and 16-bit computers. I'm not sure what you or I can do about it, except wait for ME to update - or, * perhaps the fault lies within the computer used by Peter H. I wonder ... Cheers, Tim Edited By Tim Stevens on 30/12/2021 18:33:09 |
