MyFord S7 Carriage Screw
Franco Convertini21/12/2021 12:07:13
27 forum posts
8 photos
Goodmorning everyone. I have a Myford S7 lathe. I am looking for a set to thread this screw. I measured 1 / 4X26 but I don't know if it's the right size because I can't find the tool to make the thread. You can help me?
Regards, Franco
roy entwistle21/12/2021 19:33:31
1716 forum posts
1/4 - 26 is 1/4 BSF
Roy
DMB21/12/2021 20:44:41
1585 forum posts
BSF and 2 BA used all over MLS7s until near the end when they were probably finding new supplies were getting expensive and Nottingham started using some metric almost certainly to keep costs down.
My own is an early 1970s model with no metric.
Harry Wilkes21/12/2021 21:27:41
1613 forum posts
72 photos
Most UK model engineering suppliers and ebay sell imperial taps and dies and indeed fasteners etc as DBM points out there is also BA on the Myford
H
ega21/12/2021 23:34:58
2805 forum posts
219 photos
Franco:
Do you mean the screws which hold the saddle to the apron? If so, note that they have an over-size head to allow for front-to-back adjustment.
I understand that difficulty in obtaining these in BSF caused Myfords to use metric fastenings here on later lathes.
DiogenesII22/12/2021 06:45:28
859 forum posts
268 photos
Posted by Franco Convertini on 21/12/2021 12:07:13:
Regards, Franco
This company has the tooling & ships internationally;
Tracy Tools - 1/4 X 26 BSF
Like Roy suggests, I think the thread you need is 'BSF'
Franco Convertini22/12/2021 10:06:34
27 forum posts
8 photos
Thanks for your help, unfortunately I was unable to post a photo. Now I try to create an album again and see if I can load it
Franco Convertini22/12/2021 10:14:30
27 forum posts
8 photos
Evviva, ci sono riuscito. Ecco le foto con screw. Ho in mente di realizzare un stop carriage come questo. hemingway site
Edited By Franco Convertini on 22/12/2021 10:20:26
Edited By Franco Convertini on 22/12/2021 10:21:18
roy entwistle22/12/2021 14:12:48
1716 forum posts
On mine it's 1/4 BSF
Roy
Edited By roy entwistle on 22/12/2021 14:19:26
Franco Convertini22/12/2021 14:18:45
27 forum posts
8 photos
Thanks Roy
Howard Lewis22/12/2021 15:16:23
7227 forum posts
21 photos
You need a 1/4 BSF nut and 1/4 washer to retain that Thread Indicator Dial.
ega22/12/2021 17:04:37
2805 forum posts
219 photos
Posted by Howard Lewis on 22/12/2021 15:16:23:
And some sort of friction washer is desirable so that the TDI can be engaged and disengaged without the need for a spanner
Mark Rand22/12/2021 19:38:19
1505 forum posts
56 photos
I think Franco is making a new bolt to work with the Hemingway multi-position carriage stop.
Franco Convertini22/12/2021 21:13:38
27 forum posts
8 photos
"Penso che Franco stia facendo un nuovo bullone per lavorare con il fermacarro a più posizioni di Hemingway."
Yes I do
ian j22/12/2021 21:40:23
337 forum posts
371 photos
Posted by Franco Convertini on 22/12/2021 10:14:30:
Translation " Hurray, I did it.Here are the photos with screw.I plan to make a stop carriage like this "
Edited By ian j on 22/12/2021 21:43:42
Edited By ian j on 22/12/2021 21:47:26
roy entwistle23/12/2021 09:21:46
1716 forum posts
Surely a carriage stop held by that screw would be on the wrong side of the saddle
Roy
DiogenesII23/12/2021 09:44:43
859 forum posts
268 photos
Posted by roy entwistle on 23/12/2021 09:21:46:
Roy
It pulls a rod carrying a detented disc with multiple ?rod or ?screw stops up against a kind of 'arrestor-block' , I think..
bernard towers23/12/2021 10:04:53
1221 forum posts
161 photos
Can someone explain why I would get a personal message from Franco when I am not involved in this posting??
Edited By bernard towers on 23/12/2021 10:05:25
roy entwistle23/12/2021 11:12:43
1716 forum posts
Diogenes II I would have thought that that would have been on the chuck side of the saddle, but I don't know the Hemmingway setup
Roy
Franco Convertini23/12/2021 12:44:39
27 forum posts
8 photos
In this forum we talk about it here
Edited By Franco Convertini on 23/12/2021 12:55:57
