derek hall 1 | 12/11/2021 18:41:00 |
322 forum posts | Hi, I am currently building my Quorn and have reached the stage of making the grinding spindle assembly. However I was wondering if anyone has built Mr D Broadley's grinding spindle (available as a kit from Hemingway Tools) and wondered if this would be an easier and possibly better option? Kind regards Derek |
John P | 12/11/2021 20:33:18 |
451 forum posts 268 photos |
There are many ways to make a better spindle that is stiffer that |
derek hall 1 | 14/11/2021 12:14:40 |
322 forum posts | Hi John Thanks for reply, looks like the Quorn spindle is the way to go. Kind regards Derek |
John Purdy | 14/11/2021 18:20:18 |
![]() 431 forum posts 252 photos | John I'm curious as to why you think the spring box arrangement for preloading the bearings is superior to the disk springs washers. Could you elaborate? When I built mine I used the disk springs as I felt it would be easier and produce a more uniform preload. In use it has been perfectly satisfactory, and I feel was easier to make. Derek I have a PDF of the drawing of my modified spindle using the disk springs also a short write up of its construction. If you are interested I can send them to you. John |
duncan webster | 14/11/2021 18:35:57 |
5307 forum posts 83 photos | In the distant past I worked on design of gearboxes for small gas turbines. They used wavy washers and angular contact bearings. Shaft speed was ~80,000 rpm, so first gear shaft speed would be 16-20,000 rpm. One potential problem with the spring box arrangement is getting equal load on all the springs |
John Purdy | 14/11/2021 19:30:14 |
![]() 431 forum posts 252 photos | Duncan That was my concern. When I got my castings from MES, included were 6 springs for the spring box. A cursory inspection of them showed that there was a difference in the spring rate between them. This would mean that if made as drawn, the preload would not be uniform around the bearing. . Whether this uneven preload would make any difference in the operation of the spindle in the type of service that the Quorn spindle is used for I don't know, but that is why I went with the disk spring design. In the case of the turbine gearbox you mention I suspect that uneven loading on the bearings at those speeds and prolonged running would very likely cause premature bearing failure. John |
John P | 14/11/2021 21:13:37 |
451 forum posts 268 photos | Posted by John Purdy 14/11/2021 18:20:18 I'm curious as to why you think the spring box arrangement for preloading When I built mine I used the disk springs as I felt it would be easier and ----------------------------------------------------------------------- Hi John, I don't think there is any problem with the disk springs being used The photo of spindles shown earlier are similar to the Chaddock In the Quorn Universal tool and cutter grinder book Prof Chaddock " The other bearing is firmly clamped on the inner ring but the outer ring The washers as in the Broadley design which has recently been The OP had asked for an opinion on the the 2 designs of spindle John |
John Purdy | 14/11/2021 21:46:36 |
![]() 431 forum posts 252 photos | John Thanks for your explanation. Your reasoning makes good sense and I can see why it might be superior in that aspect. Perhaps a better way to utilize the disk springs would be to have a sliding sleeve 2 x as long as the bearing diameter bearing on the bearing outer race with the other end bearing against the disk springs to provide the preload. This would alleviate your concern of little support for the outer race and provide for heat transfer, at the same time providing a uniform preload around the circumference of the outer bearing ring. Just a thought. John |
John P | 14/11/2021 22:27:02 |
451 forum posts 268 photos | Hi John, I had come to that same conclusion using the disk springs in the way that you describe ,the Quorn spindle is not that demanding , it is lightly loaded and does not run that fast to be a problem ,the 3 spindles seen earlier run to 31,000 rpm they are only limited by the drive belt which gives up due to the centrifugal force flexing the belt as seen here ,the belt has so much tension it needs some effort to fit over the pulleys but turns into chewing gum at high speed. |
John Purdy | 15/11/2021 03:30:58 |
![]() 431 forum posts 252 photos | Just as an aside, ( and not implying anything ) the Unimat SL lathe spindle uses two A13 magneto bearings ( the same as the Quorn ), and the preload is provided by a pair of disk springs ( >< )bearing directly on the outer race of the bearing at the pulley end. Out of curiosity I was going to measure the preload that is used on the Unimat but my spring scale that I used when I did my Quorn spindle seems to have grown legs and disappeared! John |
Mark Rand | 15/11/2021 10:33:49 |
1505 forum posts 56 photos | Posted by John P on 14/11/2021 22:27:02:they are only limited by the drive belt which gives up due to the centrifugal force flexing the belt as seen here ,the belt has so much tension it needs some effort to fit over the pulleys but turns into chewing gum at high speed.
For future designs, would it be better to use nylon reinforced flat belts? They are nowhere near as stretchy as the round polyurethane belts. |
John P | 15/11/2021 14:19:43 |
451 forum posts 268 photos | Posted by Mark Rand 15/11/2021 10:33:49 ------------------ Posted by John P on 14/11/2021 22:27:02:they are only limited by the drive belt Most probably . Like most things some compromises have to be made, As the spindle has a working speed from about 4,000 to the Crystal lake grinder internal spindle speed 17,500 rpm These are just a few ,i am sure there will be some more ,i guess there is John
