Recommendations
Salvie Cudlip | 06/11/2021 09:25:18 |
15 forum posts 6 photos | Good morning, I’m new to this forum and new to model lathes! This has probably been asked a load of times so apologies in advance! The Chuck on my ml7 has seen better days! Could anybody recommend a good 3 Jaw chick with backplate, that I could bolt straight on without having to machine anything?? I don’t think my machining skills will be quite up to it just yet 😀 I believe it has the 3 jaw 100ml Chuck fitted.
Thank you |
Andrew Tinsley | 06/11/2021 10:20:56 |
1817 forum posts 2 photos | It really depends on what quality you want, it ranges from cheap and nasty far east products to high end stuff like Bison and others. If it were me, I would buy a 4" Chinese chuck and a matching backplate from Arc Eurotrade. I purchased such a chuck about a year ago and was amazed at how good the quality was, forgetting the modest price. Arc do backplates but you will need to turn the register to size and drill the mounting holes. Not a difficult task and good learning too. You may be able to buy a chuck with a backplate attached and ready to go, from the" New" Myford. If so it will probably be more expensive than going the Arc route and the chuck will be hard pressed to beat the Arc offering. Andrew. |
Salvie Cudlip | 06/11/2021 11:21:43 |
15 forum posts 6 photos | I’ll have a look on ARC and see what I can find. I’ve seen the Chinese built chucks but dubious about the quality! Thanks for reply. salvie
David George 1 | 06/11/2021 11:59:26 |
![]() 2110 forum posts 565 photos | Have a look on here. Rotagrip. http://www.rotagriponline.com/ David |
Andrew Tinsley | 06/11/2021 12:00:33 |
1817 forum posts 2 photos | Anything that Arc sell will be a quality product. The 4" Chinese chuck that they sell can be bought more cheaply on Ebay, but the quality is going to be poorer than the Arc version. Chinese companies sell the same product in different qualities, depending on what the buying company wants to pay and what quality they want. Arc has an exemplary reputation for excellent goods at reasonable prices. You can depend on the quality of their Chinese chucks. If in the highly unlikely event of a problem, you can depend on them to rectify it PDQ. Andrew. |
roy entwistle | 06/11/2021 12:46:58 |
1716 forum posts | Arc also sell backplates machined to fit Myfords |
John P | 06/11/2021 12:52:14 |
451 forum posts 268 photos | Have a look on the https://www.chronos.ltd.uk/ site here Soba Chronos Product Code: 145056 and also Chronos Product Code: K11100M . The Soba is probably the better of the two.
John |
Salvie Cudlip | 06/11/2021 13:47:25 |
15 forum posts 6 photos | Thank you all very much ! Really appreciate it. I’ll have a look at all the options. thanks again Salvie
Howard Lewis | 06/11/2021 14:00:05 |
7227 forum posts 21 photos | If you buy, cheap off E bay, you will not be sure of the quality, nor, if there is a problem will you get any help. You get what you pay for! If you buy from Arc, you will get sound advice, and help if there is any problem, or query. Do not be tempted to fit an oversized chuck. Too heavy a chuck will cause extra wear to the bearings, If you can find a chuck with a backplate to suit a Myford 7 Series, well and good. Otherwise you will need to do some machining. You can buy a backplate to suit a Myford thread and register, but you will need to turn the OD to match the register in the chuck, drill the holes for the retaining screws (Which in all probability will be Metric ) and skim the face to ensure that it is square to the axis of your lathe. This might be the more accurate way to do things, but the register diameter needs to be a close fit in the chuck, so don't rush things. Measure twice, cut once!.. Howard |
Peter Greene | 06/11/2021 16:49:25 |
865 forum posts 12 photos | Posted by Howard Lewis on 06/11/2021 14:00:05:
