Here is a list of all the postings Salvie Cudlip has made in our forums. Click on a thread name to jump to the thread.
Thread: Run out on bar |
12/11/2021 10:39:41 |
This was after I turned the bar down! Wouldn’t 0 indicated that the bar is now straight in the Chuck? Used a micrometer and reading same values either end! |
11/11/2021 23:12:32 |
11/11/2021 23:11:44 |
11/11/2021 23:11:05 |
11/11/2021 23:09:20 |
Cheers for the reply’s guys. I managed to get a couple thou out by tightening the Chuck up several times! That seemed to work well! I managed to turn a bit of bar down! Probably a terrible cut. Wasn’t sure on the angle of the tool relative to the bar. Probably should of looked that up before I started! 🤦♂️
11/11/2021 08:58:16 |
Thank you all very much! Just a big learning curve for me. I believe I also have a 4 jaw Chuck. I was under the impression, if you clamp something in a Chuck, it would be true! Clearly not 😂 Will watch the video later .
much appreciated |
11/11/2021 08:32:58 |
Thanks for link! 1971 ml7! As I’ve never used a lathe before, I wasn’t sure what to expect! I assumed, a new Chuck with a straight bar, it wouldn’t have any runout. As I said, complete novice! Just want to learn. Thank you |
11/11/2021 08:20:05 |
11/11/2021 07:47:29 |
Hi all, I’ve got a question regarding different length bar in my Chuck! Regardless of the length or diameter of bar, I seem to have run out with my dti gauge at the end of the bar. I’ve just fitted a brand new Chuck and backplate as I thought the old Chuck was worn ! sorry if this is a stupid question! Complete novice starting out!
thanks in advance. |
Thread: Clutch slip |
11/11/2021 07:27:27 |
Made up a new push pin, slightly longer than the one fitted. Clutch working fine now . Thank you for information |
07/11/2021 13:21:53 |
Thank you all for replying! Apologies for my incorrect terminology! Push pin looks too short! The shoes look absolutely fine, loads of material on them. I’ve deglazed the shoes and inner drum. When I adjust the pin so the clutch is completely engaged, the pin sometimes falls out . I’m thinking of making a longer pin so the adjusting screw won’t be wound in so much. I have some bar which I should be able to run down to diameter. I’ve taken pictures but unfortunately can’t send from my phone! Really appreciate the replys salvie |
06/11/2021 23:03:06 |
Hi all, I have clutch slip on my myford ml7! Cleaned, and deglazed shoes. Refitted, still the same. |
Thread: Myford ml7 Chuck |
06/11/2021 13:47:25 |
Thank you all very much ! Really appreciate it. I’ll have a look at all the options. thanks again Salvie
06/11/2021 11:21:43 |
I’ll have a look on ARC and see what I can find. I’ve seen the Chinese built chucks but dubious about the quality! Thanks for reply. salvie
06/11/2021 09:25:18 |
Good morning, I’m new to this forum and new to model lathes! This has probably been asked a load of times so apologies in advance! The Chuck on my ml7 has seen better days! Could anybody recommend a good 3 Jaw chick with backplate, that I could bolt straight on without having to machine anything?? I don’t think my machining skills will be quite up to it just yet 😀 I believe it has the 3 jaw 100ml Chuck fitted.
Thank you |
