Steve355 | 15/10/2021 10:30:39 |
321 forum posts 235 photos | Hi all In the end I got on OK with turning brass and have managed to make a couple of components for my milling machine, The next thing I need to make is one of these,
Any tips? Chuck away the 316 and get something else? I hear it is tough stuff.
thanks Steve
Edited By Steve355 on 15/10/2021 10:30:58 |
Andrew Johnston | 15/10/2021 10:50:20 |
![]() 7061 forum posts 719 photos | Some stainless steels can be a pain, but 316 is lovely to turn. However, it work hardens at the drop of a hat. So one needs to use decent depth of cut and feed rate (4 thou/rev or more) and never let the tool rub. The tool shown seems an odd shape? i'd use a standard knife tool. Andrew |
Tony Pratt 1 | 15/10/2021 10:54:52 |
2319 forum posts 13 photos | Stainless IS completely different to brass, feeds & speeds need looking at also you need to keep the tool on centre height. Tony |
Steve355 | 15/10/2021 10:55:31 |
321 forum posts 235 photos | Thanks Andrew I made the tool that shape cos it will need to get into some shoulders.I actually tried several tool shapes. What if the tool has *already* rubbed and hardened the steel?
steve |
Brian Wood | 15/10/2021 10:55:44 |
2742 forum posts 39 photos | Try carbide tips Steve, not at high speed and keep the feed on, don't allow the tip to dwell as that induces work hardening in the material. You should get a decent finish straight from the tool and stringy swarf, which is sharp and bitey! Regards Brian Edited By Brian Wood on 15/10/2021 10:56:06 |
Steve355 | 15/10/2021 10:57:09 |
321 forum posts 235 photos | It’s 1 inch diameter - ish and 300 rpm. Which is apparently 80 SFM. |
Andrew Johnston | 15/10/2021 11:29:30 |
![]() 7061 forum posts 719 photos | Posted by Steve355 on 15/10/2021 10:57:09:
It’s 1 inch diameter - ish and 300 rpm. Which is apparently 80 SFM. That's a bit on the fast side, even the professionals only recommend 70fpm for 316 and HSS tooling. Drop it to 50/60fpm. Andrew |
Martin Connelly | 15/10/2021 11:46:37 |
![]() 2549 forum posts 235 photos | At work we tried chamfering 321 and 316L stainless with pipe bevelling machines with carbide cutters. Even then the slightest rub hardened the face and we always ended up resorting to grinding and latterly replaced a large double off-hand grinder with some belt linishers. I find the ground and polished carbide tips work well on stainless but always use power feed. I made something (the usual need for a tool to make something else) this week from a bit of scrap and only realised it was stainless when I couldn't pick up the chips with a magnetic sweeper. That included using a carbide threading insert to cut a 16mm thread on the end of it at 66RPM (middle pulley + back gear). The main bit of turning was from Ø20 to Ø16 at 106RPM (middle pulley direct drive). Martin C Edited By Martin Connelly on 15/10/2021 11:51:05 |
noel shelley | 15/10/2021 13:05:36 |
2308 forum posts 33 photos | 316 is notorious for work hardening, you MUST keep the cut running. once hardened only carbide will work. Coolant is good if you have that luxury. Good Luck, Noel |
Steve355 | 17/10/2021 22:52:52 |
321 forum posts 235 photos | So… managed to find a bit more time for this today….. Turns out that in fact I had miscalculated and previously I was turning at 600rpm = 152 fpm so way too fast for 316. I dropped the RPM to 200 = 50 fpm and it is cutting consistently and properly, without wearing down the tool bit in seconds. Problem is ,now I am getting a nice screw thread. See pic. I’ve increased the nose radius, made little difference. I could increase the speed, but then I’d be back to where I was before. In fact, my lathe doesn’t seem to have any other speed between 200 and 600. 600 is the slowest main gear speed and 200 is the fastest back gear speed, as far as I can tell. Any thoughts? Cheers Steve Edited By Steve355 on 17/10/2021 22:59:28 |
Emgee | 17/10/2021 23:07:57 |
2610 forum posts 312 photos | Change your feedrate to something around .004" per rev, looks like your feed is on thread cutting rate. Emgee |
Steve355 | 18/10/2021 05:53:23 |
321 forum posts 235 photos | Ahhh I get it. That’s why the change wheel chart has 114.4 and 171.6 TPI. I was wondering why on earth anyone would want to cut a thread that fine! luckiky this is the beginners forum!
David George 1 | 18/10/2021 08:11:07 |
![]() 2110 forum posts 565 photos | This is a video to roughing out a stainless stem with a carbide indexable tool from JB cutting tools. On my 1950 M Type Drummond lathe. https://youtu.be/vzrhyDr4JBM David Edited By David George 1 on 18/10/2021 08:12:34 |
Steve355 | 18/10/2021 09:52:30 |
321 forum posts 235 photos | It never ends 🥺 So to do proper power feeding I need to use a full complement of change gears. But the little arbor to attach the second set of change gears to the quadrant is missing. It’s a Zyto lathe but uses Myford change gears - but I can’t obviously find a Myford part that matches. Luckily it looks pretty easy to make, even for me. I can’t do the slot for the key, it in the short term that probably won’t matter. Can someone please recommend a suitable type of metal to make it from? |
Tony Pratt 1 | 18/10/2021 10:49:23 |
2319 forum posts 13 photos | Mild steel will be fine, the key slot may be needed depending on your set up? Tony |
Richard Millington | 18/10/2021 10:50:35 |
101 forum posts 9 photos | If you are going to mount two gears on it for one to drive the other then you will need the slot. You could file the slot for the keyway, or clamp the tube on the cross slide on a small V block and put a small milling cutter in the chuck.
Steve355 | 18/10/2021 10:56:38 |
321 forum posts 235 photos | Good points, of course I need the key slot, what was I thinking. Mild steel it is, I will order some.
thanks Steve |
Tim Stevens | 18/10/2021 11:20:01 |
![]() 1779 forum posts 1 photos | You need to be a bit careful what you order, Steve. There is a lot of 'construction' steel about which is used for building roofs, etc, and it welds wonderfully but is difficult to machine in hobby workshops. If you order 'bright mild steel, leaded' you will pay a bit more but you'll get what you need. And leaded means it has metallic lead in the recipe, so it machines nicely. Pronounced leddid, not leedid. Regards, Tim |
Clive Brown 1 | 18/10/2021 11:57:10 |
1050 forum posts 56 photos | The slot isn't essential. All that's needed is a half-height key to connect the 2 change-wheels. Out with the hack-saw and files. |
