Grinder very noisy at start
Michael Brett 1 | 14/10/2021 20:19:08 |
59 forum posts 6 photos | Hi all I have a Erbauer 8 inch bench grinder model ERB8DLC that has developed this fault. On switch on the grinder makes a very loud hum and struggles to get turning. This started about 8 months ago. I have found that if I spin the wheel by hand first then turn it on it picks up speed much quieter . Once it is up to speed it works just fine. Would this indicate a fault with the run capacitor, if so is it an easy fix. Or would it possibly be what I believe is called the run switch on the shaft. As I say , once running its fine so reluctant to replace if its fixable. Cheers Mike |
noel shelley | 14/10/2021 21:41:16 |
2308 forum posts 33 photos | It does sound like a start condenser that has gone low. Your lucky to have got away with it for so long. IF the windings have not cooked then it should be repairable. IF you can read the value of the capacitor and can check it's current value thats a good start, remember the tolerance may be as high as 20%, it should be marked. It will have a run voltage of possiblly 400V DO NOT use a lower voltage. Good Luck, Noel. |
Andrew Tinsley | 14/10/2021 21:43:00 |
1817 forum posts 2 photos | It could be the start capacitor that has gone faulty or the run switch is stuck in the run position and hence the motor is struggling to start. Unless you have a capacitance meter and can check the start capacitor, I would simply change it out for a new one. If that doesn't cure it take the end plate off the motor and check the centrifugal switch isn't stuck. If you are tight fisted, like me, check the switch first, you might save the cost of a start capacitor, at the expense of some disassembly work! Andrew. |
Steviegtr | 14/10/2021 23:21:22 |
![]() 2668 forum posts 352 photos | Many bench grinders do not have a centrifugal switch. They are just capacitor start & run. The capacitor being in circuit permanantly. Hopefully a cheap fix for you. Steve. |
kevin laxon | 15/10/2021 07:07:37 |
19 forum posts | I agree with others,check the motor capacitor,you will probably have to remove a plate from the base & dont be supprised if it has bulged or even exploded. |
Nicholas Farr | 15/10/2021 07:57:20 |
![]() 3988 forum posts 1799 photos | Hi, my Draper 200mm grinder has a capacitor, I guess it makes them cheaper and easier to produce than a centrifugal switch and probably gives a softer start, which puts less stress on start-up for the wheels. Regards Nick. |
not done it yet | 15/10/2021 08:23:21 |
7517 forum posts 20 photos | … Once it is up to speed it works just fine. … That would indicate it is not a run capacitor. That it needs help to start rather indicates a start capacitor, winding or centripetal switch problem. You should hear a definite click as the motor runs down (close towards stopping). That generally indicates the switch is working (but not always). Continuity through the switch can be readily proved by a quick resistance check. Open circuit would indicate switch contact problem or a break in the start winding. The usual problem is the start capacitor has failed completely or has gone low on capacitance. A common issue. |
noel shelley | 15/10/2021 10:22:24 |
2308 forum posts 33 photos | The reason I did not mention the centrifugal switch in my first post is that many bench grinders do not have one. As others have said, Check the continuity of the start windings and if sound, then if you cannot check the condenser just replace it. Good Luck, Noel. |
Michael Brett 1 | 15/10/2021 10:22:58 |
59 forum posts 6 photos | Many thanks for all replies. I could not find any sort of centrifugal switch so I assume it must be the capacitor. Although this component showed no sign of damage, when I put my meter on the terminals it measured zero volts. Anyway I have ordered a new one so hopefully that should sort it . Cheers Mike |
Deen Hussain | 07/04/2022 01:55:52 |
1 forum posts | Hi everyone just need some information regarding a 6inch Delta bench grinder with variable speed from 1720 to 2850rpm and also is a 230v and also has a stop switch on it that's not the same as the brand I see on the Internet or the Delta website this one stops the wheel in less then 10 seconds no more then 15 seconds I would say which normally the Delta 129v brand I seen on the Internet and reviews of it saying it takes long for the wheel to come to a stand still something like 4 and half minutes would say is a very big improvement not only the if you look at the RPM on the 120v Delta it would say from 2000 to 3450rmp but this is the more high end model of 1720 to 2850rmp so tried looking for information regarding this Delta brand I got but it will only keep coming back to the Delta 120v model with the up and down switch instead of the big square red & green button. So my question is do you think this model is a upgrade model specifically made to order as the sticker on the machine clearly says 230v with 1720 to 2850rmp 1PH... so you can rule out its been modified by someone else. Any help pls... |
