Here is a list of all the postings Deen Hussain has made in our forums. Click on a thread name to jump to the thread.
Thread: Bench grinder |
07/04/2022 01:55:52 |
Hi everyone just need some information regarding a 6inch Delta bench grinder with variable speed from 1720 to 2850rpm and also is a 230v and also has a stop switch on it that's not the same as the brand I see on the Internet or the Delta website this one stops the wheel in less then 10 seconds no more then 15 seconds I would say which normally the Delta 129v brand I seen on the Internet and reviews of it saying it takes long for the wheel to come to a stand still something like 4 and half minutes would say is a very big improvement not only the if you look at the RPM on the 120v Delta it would say from 2000 to 3450rmp but this is the more high end model of 1720 to 2850rmp so tried looking for information regarding this Delta brand I got but it will only keep coming back to the Delta 120v model with the up and down switch instead of the big square red & green button. So my question is do you think this model is a upgrade model specifically made to order as the sticker on the machine clearly says 230v with 1720 to 2850rmp 1PH... so you can rule out its been modified by someone else. Any help pls... |
