PipesandStuff | 03/10/2021 14:14:33 |
20 forum posts 8 photos | Hello chaps. Well it is moving forward and I appreciate the help and the replys I have gotten here. I have decided not to use the old original 3 phase motor and just get a new 1 phase. But have changed the bearings and refurbished the old motor in case I decide to sell it. Next job is to make the shims to the headstock. Could these be made out of soda cans? Or do I need to buy thin brass shets? |
Thor 🇳🇴 | 03/10/2021 14:21:25 |
![]() 1766 forum posts 46 photos | I wouldn't use aluminium (soda cans) for shimming, brass or steel would be better, something like this. Thor |
PipesandStuff | 03/10/2021 14:24:42 |
20 forum posts 8 photos | Posted by Thor 🇳🇴 on 03/10/2021 14:21:25:
I wouldn't use aluminium (soda cans) for shimming, brass or steel would be better, something like this. Thor Do you know anywhere in Norway that sells these kinds of shims stock Thor? |
Thor 🇳🇴 | 03/10/2021 14:32:34 |
![]() 1766 forum posts 46 photos | The closest I have found is: ***Link*** (may not be your size) You may have to order from abroad. Thor |
noel shelley | 03/10/2021 14:55:45 |
2308 forum posts 33 photos | Some drinks cans are steel and then there are oil cans ! Noel |
SillyOldDuffer | 03/10/2021 15:16:51 |
10668 forum posts 2415 photos | The problem with Aluminium shims made from a can is the metal slowly deforms under pressure: the alloy is too soft for a permanent shim. Mild steel is better but still relatively soft. Steel cans are made from dead mild-steel, which is a fair bit softer than mild steel. Extruded drink cans are always made from a soft metal, and although convenient, they're not ideal for shimming. I use aluminium to shim my 4-way tool post and occasionally put new in due to it flattening in use. Dave |
Michael Gilligan | 03/10/2021 15:24:05 |
![]() 23121 forum posts 1360 photos | I have no idea whether you would find a local supplier, Tonny ... but this type of material is ideal for shimming split bearings : **LINK** http://www.shimpack.com/shimlammetals.html MichaelG. |
Dave S | 03/10/2021 16:25:14 |
433 forum posts 95 photos | I have used razor blades for small shim stock - the double edge type, not the ones moulded into plastic. Dave |
Oldiron | 03/10/2021 16:31:20 |
1193 forum posts 59 photos | Another source of good shims are feeler gauges. Dirt cheap and available every where. regards |
PipesandStuff | 03/10/2021 16:38:15 |
20 forum posts 8 photos | I too thought about feeler gauges, but they are not wide enough. Need to be something like this. |
Mike Crossfield | 03/10/2021 16:38:17 |
286 forum posts 36 photos | I have used material salvaged from old feeler gauge sets to make shims in the past when I didn’t have the right size shim stock to hand. edit. Didn’t type fast enough…….. Edited By Mike Crossfield on 03/10/2021 16:40:00 |
Howard Lewis | 03/10/2021 17:03:43 |
7227 forum posts 21 photos | If you can't obtain laminated shim stock, the alternative is to buy shim steel.. Stubs sell it in UK in thicknesses from 0.0015" (0.038 mm) up wards to about 0.0102 (0.254 mm ) HTH Howard |
Trevor Drabble | 03/10/2021 17:28:29 |
![]() 339 forum posts 7 photos | Tonny , l have limited stocks of both brass and steel shim in different thicknesses. If you could please list the actual quantities , sizes and thicknesses you require I'll do what l can to help . Trevor. |
PipesandStuff | 03/10/2021 17:57:11 |
20 forum posts 8 photos | Found a shop that sells thin sheets of brass. Just bought some and will give that a go. Thanks for the replys! |
