Gary Wooding | 12/08/2021 10:44:36 | ||
1074 forum posts 290 photos | The keyless drill chuck I use on my lathe suddenly decided it had had enough. I had just removed a drill and wanted to insert another, but although the sleeve turned, the jaws didn't move. I can screw the sleeve in and out about 6mm, but the jaws don't move. There's a slight grinding noise apparent when rotating the sleeve, but the jaws remain stationary. There is no maker's name visible anywhere. I've used it without problems for a number of years. I can't see any way to open it up to determine, and hopefully rectify, the problem. Any ideas? | ||
mgnbuk | 12/08/2021 12:20:23 | ||
1394 forum posts 103 photos | This Youtube video might offer a few hints on how to dismantle one of those. I've only skipped through it, but brute force does not seem to be required. Nigel B. | ||
Ady1 | 12/08/2021 13:18:54 | ||
![]() 6137 forum posts 893 photos | utube is your pal here, someone somewhere will have done your type so hunt about They are clever little things and well put together I did one here and the only thing I would stress is point it up the way to get the hood off, with the body in a fixed vice and the hood being used as the "nut" part | ||
David George 1 | 12/08/2021 13:36:17 | ||
![]() 2110 forum posts 565 photos | It looks like the outer shroud has unscrewed instead of the body rotating. Screw the shroud back on but have a look e.g. the video first. Don't forget to take pictures as you disemble it and mark parts where they come from. David | ||
Clive Foster | 12/08/2021 17:52:13 | ||
3630 forum posts 128 photos | As all these engineering keyless chucks are assembled in a very similar manner it's worth rooting around the internet for Albrecht service instructions. The set I found had nice exploded drawings along with some "professional" techniques and wrinkles to get it working really well. Some of the amateur write ups and YouTubes are said to be lacking that little bit extra. Unfortunately the link I used for the Albrecht instructions is dead. Clive | ||
DC31k | 12/08/2021 19:08:13 | ||
1186 forum posts 11 photos | Try these as an aperitif: https://www.machinistblog.com/rebuilding-an-albrecht-drill-chuck/ https://www.penntoolco.com/content/AlbrechtPrecisionReplacementParts.jpg | ||
John Haine | 12/08/2021 20:41:59 | ||
5563 forum posts 322 photos | I am fairly certain that this has been answered previously on this forum. Use the Google search facility on the homepage. Or maybe Michael Gilligan will chime in as his search skills are excellent. | ||
Michael Gilligan | 12/08/2021 23:10:56 | ||
![]() 23121 forum posts 1360 photos | I don’t really do requests, John But as Clive has given us a good start : **LINK** https://www.albrecht-germany.com/en/instruction/ MichaelG. . Click on the letters SBF on the line
Edited By Michael Gilligan on 12/08/2021 23:18:18 | ||
Michael Gilligan | 16/08/2021 19:44:10 | ||
![]() 23121 forum posts 1360 photos | So … did you fix it, Gary ? MichaelG. | ||
peak4 | 16/08/2021 21:23:10 | ||
![]() 2207 forum posts 210 photos | These are the bearings that came out of mine. | ||
Gary Wooding | 17/08/2021 07:44:16 | ||
1074 forum posts 290 photos | I've not managed to fix it yet. I've not even managed to dismantle any part of it. I can't extract the taper from the chuck body, and the rear collar appears to be just a cap, which also refuses to come off. By holding the tang of the taper in a vice I'm able to app[y a powerful pipe gripper to the shroud, and have managed, little by little, to unscrew it enough to see the start of the thread. Each time I try, there is considerable internal grinding, and I'm able to unscrew it a little more, but not yet enough. | ||
Michael Gilligan | 17/08/2021 08:36:28 | ||
![]() 23121 forum posts 1360 photos | Sounds like you might have a lot of debris [previously known as balls] jamming-up the works. MichaelG. |
