Martin Bryars | 10/07/2021 10:56:29 |
21 forum posts | Much as I like it, I have decided my Myford 254S is too small for some work I want to do so I am thinking of changing to a Harrison M300 with a gap bed. I used to have a Colchester Student which was very old. My workshop now has a Bridgeport in it, so space is more restricted and the M300 is a bit smaller than a Student in footprint. .I have two possible positions for the lathe, one end on to the wall, the other end on to the garage doors, but the latter is much poorer for general convenience. That is all very long winded but sets the scene. What I really want to know is how frequently one really needs access to the end of the headstock. There is the door for the switchgear and a cover for the change wheels. So far as I can see, all the threads one is likely to use are covered by the standard change wheel set and I assume the electrics are only accessed if something nasty has happened. At the tailstock end, one would rarely if ever need to remove the tailstock. I would welcome any thoughts, particularly from M300 owners. |
peak4 | 10/07/2021 11:07:27 |
![]() 2207 forum posts 210 photos | I don't have an M300, but did buy a Warco GH1330 a while ago. On that, the wiring panel is on the rear of the headstock, so I positioned the lathe with that panel over the window ledge. |
DC31k | 10/07/2021 11:07:44 |
1186 forum posts 11 photos | Just as food for thought, and especially as access will be needed infrequently, perhaps have a good look at the machine and see if the 'operating mode' of the door and/or cover can be changed to suit the location. I can only speak for a Chipmaster, but making the door hinge pins removable on that, so that it does not need to swing open 90 degrees for access has freed up a lot of space. |
Roderick Jenkins | 10/07/2021 11:13:38 |
![]() 2376 forum posts 800 photos | I'd want the option of having a long bar poking out of the rear of the headstock. Rod |
Andrew Johnston | 10/07/2021 11:25:58 |
![]() 7061 forum posts 719 photos | My M300 sits against a wall with the headstock end next to the garage door. I open the gear train once a year for oiling. In 20 years I've never needed to change the gears, and I do a lot of screwcutting. Likewise I've only opened the electrical cabinet a few times to make adjustments. There is about a foot between the end of the lathe and the garage door. So enough room to poke metal through the headstock. If I ever needed to turn something longer than 4 or 5 feet, or properly access the electrics, I can always open the garage door. I don't recall ever having removed the tailstock. Andrew |
Vic | 10/07/2021 11:28:23 |
3453 forum posts 23 photos | Posted by Roderick Jenkins on 10/07/2021 11:13:38:
I'd want the option of having a long bar poking out of the rear of the headstock. Rod It depends what you mean by “long”. I’ve had a couple of feet of material sticking out the back of my hobby lathe without issue. Some thinner stuff has needed extra support though. Speed of course is another issue. |
Buffer | 10/07/2021 12:10:38 |
430 forum posts 171 photos | I have to put a bar in the end of an m250 to knock a centre out when turning between centres. |
Martin Bryars | 10/07/2021 14:22:39 |
21 forum posts | Thank you to all those who have replied. Very helpful indeed. I must admit that I hadn't thought about metal through the headstock, but should have done, nor about changing the door for the electrics. I can never recall removing the tailstock from a lathe either as is mentioned. Altering that garage is not possible for both practical and aesthetic reasons. I shall now go away and have further thoughts about where to put one. At least no-one has discouraged me from an M300. |
DC31k | 10/07/2021 15:16:17 |
1186 forum posts 11 photos | In case you need it for dimensions, there is an M300 manual here: http://vintagemachinery.org/pubs/detail.aspx?id=13849 With regard to removing the tailstock, a simple modification to the eccentric locking lever, so that it is retained by some other means than the grubscrew-in-a-groove (maybe drill and tap it on the side facing the user and use a countersunk bolt and washer) would allow vertical removal of the tailstock, removing the necessity to slide it off the end of the bed. |
Martin Bryars | 10/07/2021 15:59:23 |
21 forum posts | Thanks. I had the dimensions, but the copy manual is helpful, as is your tip about the tailstock. |
Howard Lewis | 10/07/2021 16:00:28 |
7227 forum posts 21 photos | Like Rod, I value the ability on odd occasions, to poke long material through the Headstock. (The longest was the 18' flex hose from a pressure washer, all round the shop! ) There is JUST enough room if I ever want to remove the Tailstock, but there is room for a couple of feet of 38 mm through the Mandrel, on the rare occasions when such things become necessary. AND my shop is on a much smaller scale that yours. Howard Fat fingers strike again! Edited By Howard Lewis on 10/07/2021 16:01:54 |
Martin Bryars | 10/07/2021 16:11:05 |
21 forum posts | I have taken the point about metal through the mandrel on board and I should have thought of it. I know my workshop is quite roomy, but I have some other constraints like access to a door high up which is loft storage above my wife's workroom, a 4inch traction engine I am building and its stand, and enough workbench space for my son to build a prototype robotic arm of a fair size for specialist industrial purposes, plus at the moment everything is pretty well laid out. Anyway, I now have the information/confirmations that I need. This forum really is very useful. |
larry phelan 1 | 10/07/2021 18:44:27 |
1346 forum posts 15 photos | It,s nice to be able to pass a long length of bar through the headstock, can often save material that way.. |
Bazyle | 10/07/2021 19:58:37 |
![]() 6956 forum posts 229 photos | Come on, long stock in headstock a problem? Everyone knows you just drill a hole in the workshop wall. |
Nick Wheeler | 10/07/2021 21:20:22 |
1227 forum posts 101 photos | Posted by larry phelan 1 on 10/07/2021 18:44:27:
It,s nice to be able to pass a long length of bar through the headstock, can often save material that way.. Yes, I'm frequently surprised by how low a priority a large spindle bore is when specifying a lathe. |
Martin Bryars | 10/07/2021 21:49:11 |
21 forum posts | One of the reasons I want to change lathes is to have a bigger spindle bore. I tend not to have very long lengths of material to machine, but plenty that is more than 1 inch diameter, the limit on the Myford. |
