Irwin Record vice swivel base
AJW16/06/2021 21:56:33
388 forum posts
137 photos
My workshop vice has done me proud over the years but it could do with a bigger jaw opening.
So as father's Day is upon us I have a Irwin Record number 5 vice one the way!
I understand a swivel base is available for this and as my existing vice swivels I think I might miss that feature but wonder how much height it adds to the vice?
Anyone got this combination or similar for ad(vice)?
Alan
old mart16/06/2021 22:15:46
4655 forum posts
304 photos
I tried googling your vise and there were a few pictures of a base which looks like being an inch high. I,m not sure if it could be retrofitted, however.
AJW17/06/2021 07:46:29
388 forum posts
137 photos
Thanks, definitely retrofittable to an existing vice, they are available for various models. Agree it looks like about an inch but I wonder if that could raise it a bit high especially for the likes of filing.
Think I will hang on till I get it as it could well be higher than my existing 4 inch job anyway.
Alan
388 forum posts
137 photos
Alan
not done it yet17/06/2021 09:46:58
7517 forum posts
20 photos
Could you not just stand on an inch board if you have a filing job? That, or saw off about an inch from the bench legs?
Edited By not done it yet on 17/06/2021 09:47:11
AJW17/06/2021 09:56:05
388 forum posts
137 photos
Or find my old Cuban heels!
Alan
ega17/06/2021 10:37:53
2805 forum posts
219 photos
Posted by AJW on 17/06/2021 09:56:05:
Alan
Or wear clogs; in addition to the extra height they are comfortable on concrete and provide some protection against impact.
not done it yet17/06/2021 14:31:02
7517 forum posts
20 photos
I did consider including to wear stiletto heels but thought it might not go down too well. Couldn’t think of the right word (cuban) at the time.🙂
Platform shoes are not really a safe option in my book - not for anywhere, let alone in a workshop.🙂
old mart17/06/2021 18:06:37
4655 forum posts
304 photos
A 5" vise will be about 1 1/2" higher than a 4" one before adding a swivel base.
John Reese19/06/2021 23:32:58
1071 forum posts
I have two bench vises with swivel bases I have never used the swivels.
not done it yet20/06/2021 08:27:44
7517 forum posts
20 photos
Not a recommendation for the specific item but this type of swivel would be more favourable (the vertical swivel/rotation) for me.
LINK
Edited By not done it yet on 20/06/2021 08:28:50
Clive Foster20/06/2021 08:40:20
3630 forum posts
128 photos
Swivel vice bases tend to be more of a fitters tool than an engineering one.
Handy when operating on an assembly with stuff hanging down the side that would argue with the bench top with the vice in the standard parallel to the bench position and prevent you grabbing the bit that needs grabbing. Standard bench vice mounting practice "at one end over the leg" gives you one clear side but sometimes you need both clear.
Apart from the height issue a potentially major issue with swivel vices is that they are considerably weaker mount than properly bolting the vice direct to the bench top. Two bots rather than three holding into cast iron via simple heads running under a slot. My steel topped bench has hefty angle and U sections undreneath the top carefully placed to accept vice fittings.
Maybe twice a decade I think a swivel base might be handy. Usually on a welding job. But, so far, a bit of coffee fueled creativity has always resolved the issue. If I ever get totally stuck I shall make up a one time mount from inch + thick steel with tapped holes appropriately arranged to get the a suitable angle of rotation. Hefty hex socket countersunk head bolts in the standard vice mount position should hold it down just fine. Odds are I'd make it with tapped holes allowing 30°, 45° and 90° rotations and call it good.
Clive Foster20/06/2021 09:03:24
3630 forum posts
128 photos
Interesting link from NDY.
Basically that Yost vice is a Swindens knock off. For the real thing **LINK**
http://www.swindens.org/welcome-to-swindens/4593841842
No prices on the site to protect casual browsers from heart attacks!
Weak point of all the copies is the simple sideways screw to clamp against horizontal rotation which is inadequate for heaving and adjusting jobs. The forces quoted by some suppliers sound impressive but don't actually add up to much when you get out to vice jaw range. The real thing has vertical clamp bolts closing a slit in a bore made a close sliding fit on the main bar. Swindens don't do a 5" like that Yost but if they did it would be approaching twice the weight!
Allegedly some of the knock offs are made from a very ordinary breed of cast iron and prone to fracture. Given the overhung nature of operations likely with such vices thats something I'd not like to verify by practical experience.
Journeyman20/06/2021 09:04:03
1257 forum posts
264 photos
I have had this Record swivel base vice for over 40 years. Fitted with aluminium jaws early in it's life.
I can truly say that I have never used the swivel function and that the circular base can get in the way of holding some jobs!
AJW20/06/2021 10:19:26
388 forum posts
137 photos
Thanks for your inputs. Only yesterday did I use the swivel facility of my vice on a long piece of 1 inch by 1/4 bar!
As you say it's what you get used to, but I think I would miss it, even if only occasionally. I like the idea of additional holes so the vice can be mounted 'on the angle' when required but rather than add height with a base I would go for extra fixing positions.
Existing bench is 1/8 in steel on top of 1.5 inch ply mounted on a square section steel frame on a concrete floor and bolted to the wall with the vice bolted in the usual corner position, so it's pretty solid.
New vice due tomorrow!
Alan
Bill Phinn20/06/2021 13:03:40
1076 forum posts
129 photos
Posted by not done it yet on 20/06/2021 08:27:44:
LINK
Among other vices, I've got this one, which I purchased in the UK.
It's been very convenient to use, and the extra height is a bonus because the heavy bench on which it sits is lower than average.
I can detect no appreciable difference in stability between this vice when bolted down and my old non-swivelling Record of a similar weight.
I do use the swivel facility, and apparently more frequently than most people here. I've yet to use the pipe jaws. It is very smooth in operation, requiring only one finger spinning round the middle of the tommy bar to quickly reposition the moveable jaw.
Clive Foster20/06/2021 13:44:13
3630 forum posts
128 photos
Alan
Extra holes will be a lot cheaper than a swivel base!
Consider permanently fitting a plate underneath with tapped holes for the bolts so you don't have to muck about with nuts'n washers underneath when moving the vice. Do remember to take a nuts depth or so of thread off the end of the bolt producing a plain spigot to help guide it in square helping to avoid cross threading. Well worth doing if using nuts too. Most especially if groping at some distance to fix things.
A lateral thinking version of this idea is to pre-fit bolts screwing up through the plate from underneath in all the holes. Just back off the ones you are not using till the end is flush with the bench. Keeps the holes and threads clear of swarf and stuff. Nut on to where you can see it has to be easiest way of fixing down. Thread in underplate needs to be fairly tight so the unused bolts don't unscrew under vibration when working. I usually use a first (taper) tap to leave a couple of turns a touch undersize when needing frictional tightness. Or acceot the minor inconvenience of a locknut.
AJW20/06/2021 15:20:40
388 forum posts
137 photos
Clive, I think extra holes is the way, also without incurring extra height. One thing I will do is make a 'plain' set of jaws. Had my existing vice jaws modified by grinding the grip surface off and never regretted it.
Alan
Mike Poole20/06/2021 16:59:50
3676 forum posts
82 photos
The classic start point for vice height is to mount it so the top of the jaws are at elbow height with your arm bent. As benches in our workshops were a standard height then tall lads often fitted a raising block to suit them, the short ones had a duck board to suit them. Duckboards were standard to avoid working on a concrete floor all day and although you might think they would present a trip hazard it never seemed an issue.
Edited By Mike Poole on 20/06/2021 17:00:23
Roderick Jenkins20/06/2021 19:29:14
2376 forum posts
800 photos
I swivel my vice all the time. I guess it partly depends where and how the vice is mounted. Today I needed to support this riveting dolly and since the vice is mounted so that a long bar can be held downwards in front of the bench, a small amount of rotation was required to bring the support bar on to the bench:
Rod
