Brazing Hearth
John Billard 107/06/2021 18:54:00
111 forum posts
Any tips and ideas for creating a hearth suitable for making a medium size 5" gauge loco boiler?
Thanks
John B
Dave Halford07/06/2021 19:37:35
2536 forum posts
24 photos
Buy loose 9x4.5x1 bricks off Ebay and screw them together. Three for each end and as many L shaped ones you need for the middle section. I got 12 bricks for £26 from solidfueladvisoryservice.
Other more complicated and expensive ways are available
Rod Renshaw07/06/2021 20:12:50
438 forum posts
See photos of my brazing hearth made for me by the Iron Dwarf who advertises cooking ranges and related items for medieval re-eneactors on eBay. His charge for the steel parts was very reasonable and firebricks are readily available.
Rod
Bazyle07/06/2021 20:25:40
6956 forum posts
229 photos
There are commonly available buff coloured 'firebricks' weighing in at about 4kg. They are not intended for insulating but extreme heat resistance. They are only good for building large pottery kilns so I don't understand why they are so common except for ripping off piza oven builders. They absorb a lot of heat by design to stabilise such a kiln. You don't want them.
There are lightwieight white insulating bricks weighing in at 1.5kg which absorb little heat and do insulate. Ideal but more expensive than any other brick.
There are compressed vermiculite insulating boards for lining wood stoves. Also pretty good but more fragile. Probably a good option.
There are lightweight grey building blocks like Thermalite (size of but not breeze blocks). These are a pretty good bet as cheapest by volume and could be further lined with the vermiculite boards. Easy to carve to shape.
All materials must be kept scrupulously dry or will spall when heated.
Rod Renshaw07/06/2021 20:44:01
438 forum posts
+1 for Bazyle's input on firebricks.
The insulating ones seem expensive per brick, but you don't need that many. They are fragile, and can be cut to size with an old woodworker's handsaw. It's quite a good idea to use a pizza oven shelf, which is strong and hard and heat resisting but not that insulating, to use as a working surface on top of the firebricks that form the base of the hearth, to take the wear.
Rod
duncan webster07/06/2021 22:04:46
5307 forum posts
83 photos
You can get ceramic fibre insulation blankets, good for wrapping round the shell when working on the firebox end. It dissolves in flux, so not for use where you are actually silver soldering
High temp rockwool for want of a better description.
noel shelley07/06/2021 22:34:23
2308 forum posts
33 photos
American K23 kiln bricks, light as a feather, absorb little heat and throw it back. Ceramic fibre also keeps the heat in as Duncan says. DO NOT use nightstor heater bricks, they absorb heat. Noel.
Thor 🇳🇴08/06/2021 05:18:54
1766 forum posts
46 photos
Hi John,
I used compressed vermiculite bricks to build my brazing hearth. You can cut them to size easily and mine are still working well after several years of use.
Thor
Former Member08/06/2021 07:38:54
1085 forum posts
John Billard 108/06/2021 19:30:23
111 forum posts
Thank you all for your comments - much appreciated. I have some Thermalite blocks or similar that I might use. Plan to mount them in an angle iron frame - I just wonder what the best size would be? I can visualise a 5 1/2" boiler barrel red hot - I don't want it going anywhere else!
John B
Former Member08/06/2021 19:48:15
1085 forum posts
Former Member08/06/2021 20:51:13
1085 forum posts
Nick Clarke 309/06/2021 10:22:56
1607 forum posts
69 photos
Posted by br on 08/06/2021 20:51:13:
John B
Forgive me for stating the obvious but it need to be capable of being used in the vertical plane as well as the horizontal, hence the need for the packing blocks to contain the vessel in either.
bill
Or a hole in the metal or whatever base and suitably shaped firebricks to allow the tubeplate or backhead of your boiler to poke through from below.
Former Member09/06/2021 11:26:54
1085 forum posts
Former Member09/06/2021 11:26:55
1085 forum posts
shaun meakin 109/06/2021 12:21:57
62 forum posts
We supply vermiculite blocks which are lightweight and reflect the heat back into the brazing area. Anything that helps speed up the time taken to get the joint up to brazing temperature is good practice.
They can be bought individually or as a set with a kaolin wool mat. As an optional extra we supply a laser cut frame for them to fit in.
The kaolin blanket in itself is a good insulation material. If wetted it can be shaped and when dry will retain that shape. In the olden days we used to put a bit of the mat on our hand and heat a piece of copper up to cherry red. Not allowed now of course!!
If you are going to the Midlands (fingers crossed) they are 25% cheaper than on the internet.
Shaun.
mechman4809/06/2021 12:54:32
2947 forum posts
468 photos
I used vermiculite blocks bought off eBay a reasonable price plus a kaolin blanket from CupAlloy to make my small mini hearth, have a look in my albums for 'mini hearth'
George.
Usual disclaimer applies.
Edited By mechman48 on 09/06/2021 12:55:03
