Small jig for honing drills below 1mm
Mike Waldron | 01/06/2021 20:14:03 |
51 forum posts | I have recently read of a small honing jig which possibly has its beginnings with the author(s) Duplex, and seen a photo of one, along with a attribution to a certain Derek Brown. Can anyone furnish me with details of this device? There apparently was an article a while ago in either MEW or ME (not sure which) illustrating a device for sharpening these tiny drills - which might possibly have this device, or possibly an update of famed the wishbone jig (not the printed plastic one called Wishbon2!) thanks Mike |
Neil A | 01/06/2021 21:50:28 |
160 forum posts | The last time I think this device was described was in MEW No251. The article, by Jacques Maurel, had detailed drawings of his version of the sharpener. Neil |
Mike Waldron | 01/06/2021 22:05:59 |
51 forum posts | Thanks Neil. Unfortunately I don’t have that issue, as I’m not a regular purchaser, so missed it. Can anyone help? Mike |
noel shelley | 01/06/2021 23:05:08 |
2308 forum posts 33 photos | Derek Brown is the man, I saw him demonstrate his device some years ago. Noel. |
Adrian Nicolson | 01/06/2021 23:32:48 |
13 forum posts | Hi There, I know of two options: MEW No:9 Feb/Mar 1992 Article Start Page 14 by D J Unwin on A Small Drill Sharpening Jig (which is, an over implication...but simply put, two small bits of Square Bar, with a diagonal vee Groove to hold the small drill) or MEW No:97 April 2004 Article Start Page 22 by Trevor Marlow on "Musing About The Wishbone" (where the writer makes a sheet steel/homemade version of the original Wishbone Sharpener. Hope these help Regards, Adrian |
John Ockleshaw 1 | 02/06/2021 02:44:54 |
![]() 56 forum posts 7 photos | Hello Mike In the Model Engineer 2785 ,of the 7th October 1954, Len Brown described a "Small Drill Sharpening Device". depending how big you make it it will accommodate Number 80 drills, For these small drills you wiill probably need a magnifier to help you position the drill. They are simple to make and I have three to cover the range 5/332" to less than No.80 diameter.. They work very well. If you send me a PM with your email address I will send you a copy of his article.; Regards John |
Kiwi Bloke | 02/06/2021 06:25:49 |
912 forum posts 3 photos | D A G Brown wrote it up in ME Nos. 3690 & 3692. It's also described and discussed here I've seen Derek using his original - it works well! IIRC, he got a diamond-impregnated plate specially made for him. That would have been in the mid- to late '90s: it's easier to source such things now. |
Speedy Builder5 | 02/06/2021 06:44:30 |
2878 forum posts 248 photos | Is it a tool like this ? |
Mike Waldron | 02/06/2021 06:49:17 |
51 forum posts | Thanks all for the suggestions. The little gadget shown is intriguing, Speedy builder! The first time I’ve seen that one. Mike Edited By Mike Waldron on 02/06/2021 06:50:02 |
Phil P | 02/06/2021 08:46:51 |
851 forum posts 206 photos |
That little tool looks like it is for sharpening a watchmakers graver. The drill version allows the tool to be tipped sideways to add clearance, so its wheels are fore and aft as opposed to being side to side like the one in the photo. A graver just needs a simple flat producing on the end. Phil |
Gary Wooding | 02/06/2021 16:04:44 |
1074 forum posts 290 photos | A few years ago I decided to combine D.A.G.Brown's designs of the 2 jigs he created for sharpening very small drills. There were two jigs, 1 for drills up to #42 (3/32" |
Dave Wootton | 02/06/2021 16:44:49 |
505 forum posts 99 photos | Full details and drawings for his drill sharpening jig are included in D.A.G.Browns excellent book on making injectors, easily available.
Dave The little credit card sized diamond pad detailed in the drawings is available from ARC. Edited By Dave Wootton on 02/06/2021 16:46:07 |
duncan webster | 02/06/2021 16:53:23 |
5307 forum posts 83 photos | With the DAG jig as you sharpen the primary clearance the alignment of the cutting edge goes off. I asked him about this once and he advised to set it a tad wrong to start with so that as you sharpen it comes right. How big the 'tad' is depends on how blunt the drill is. I must admit that making the collets is what is putting me off this device, but trying to hold little drills in a vee block is a non starter, been there failed to do that |
Speedy Builder5 | 02/06/2021 19:42:17 |
2878 forum posts 248 photos | Another shot of the tool. The knurled knob tightened a rod which passed through the main body. That rod had a 1.5mm diameter hole through it perpendicular to its axis. The bottom of the body has a small "V" groove in it along its underside such that a small rod (Drill ??) could be held to project forward of the body at the "pointy" end. A bit small for holding a graver though. Unfortunately, I have sold it ! |
duncan webster | 02/06/2021 22:30:54 |
5307 forum posts 83 photos | I have a scan of the Jaques Maurel article, if anyone wants a copy send me a pm including your email address |
bernard towers | 02/06/2021 22:52:08 |
1221 forum posts 161 photos | Is this the one?. Works well once you are used to it, I fitted side cheeks to mine which are not on the very first drawings and a stop collar to set the depth. |
Howard Lewis | 03/06/2021 02:15:18 |
7227 forum posts 21 photos | As Gary Wooding says, Derek Brown made two versions of his sharpening jig, to cater for various sizes of drills. It is intended, I think, to produce four facets. When he brought his Quorn to exhibit on our stand at Shows, he demonstrated four facet drill grinding. I( I remember rightly, the Jacques Maurel tool is a development of the "Bommerang" jig. Eclipse, used to sell a plastic jig, for larger drills, which incorporated eccentric rollers, and intended to be run to and fro over either a flat sheet of emery, or a large oilstone. Howard.. |
Mike Waldron | 03/06/2021 08:22:54 |
51 forum posts | Many thanks everybody for all your info., scans, downloads and advice! Certainly much food for thought!! Mike |
Mike Waldron | 06/06/2021 16:22:24 |
51 forum posts | A further question re Derek Brown’s 2 articles (thanks for them, Gents!) Having read the 1994 initial articles about his device to sharpen small drills, it all seemed very simple - though I have to say a bit terrifying to drill 1.24” into 9/64” silver steel to make the collets with nos.55 & 68 drills!! I then read the later 1996 revision …. and notice an upward extension of the sizes …. But he now talks of a larger capacity - up to 1/4” / 6mm, and larger block. Fine … but am I missing something? Do both systems work together? Does version 2 now have the tiny scary collets as well as the 1/4”, 3/16” & 1/8” multi size ones?? I’m confused!! Can anyone clarify please? Gary Wooding - your version seems to avoid the confusion…. If I’m not further confused!! Mike |
Clive Brown 1 | 06/06/2021 17:32:55 |
1050 forum posts 56 photos | In his book, DAGB describes the jig as handling drills from 3/32" to no. 80 dia. He also refers to his larger jig which will handle drills of 1/8" dia. so he appears to have two separate jigs. |
