Help needed with tool post
Ian Skeldon 224/05/2021 23:36:19
543 forum posts
54 photos
Hi,
I recently bought a used Chester Craftsman lathe, it seems to be reasonable now that I have set it up how I like it, but the lathe arrived without the box spanner that tightens the screws that hold the tool in the 4 way tool post. I know that the studs/screws are 10mm AF so I know what size tool I need to buy but what are they actually called? and where would I need to look in order to buy one?
TIA
Ian
Clive Foster24/05/2021 23:50:09
3630 forum posts
128 photos
Ian Skeldon 2
Searching for Toolpost Spanner via Google comes up with this :-
https://www.rdgtools.co.uk/acatalog/Toolpost-spanner-3-8----10mm-Square-9324.html
which may do.
It has got a "proper" name which I used to find one maybe 20 years back but darned if I can remember it.
Ady125/05/2021 07:36:08
6137 forum posts
893 photos
10mm radiator key
would bring up a few returns
Michael Gilligan25/05/2021 07:58:19
23121 forum posts
1360 photos
Posted by Clive Foster on 24/05/2021 23:50:09:
Ian Skeldon 2
which may do.
I believe the “proper” name is Box Spanner : **LINK**
http://www.smithfrancistools.co.uk/box.htm
... or maybe Box Wrench [according to prference]
P.S. __ Not entirely convinced by RDG’s dual-sizing ... but perhaps that’s just me.
Edited By Michael Gilligan on 25/05/2021 08:15:57
JasonB25/05/2021 08:18:22
Rotagrip have Bison and Dickson ones in 10mm
DiogenesII25/05/2021 08:18:56
859 forum posts
268 photos
Toolpost Key, surely?
Clive Foster25/05/2021 09:38:54
3630 forum posts
128 photos
Michael
Looks like you could be right about box spanner being the correct name these days. However to me box spanner always meant the steel tube things with the ends pressed round into hexagons and a couple of cross holes through the middle for a (bent!) tommy bar.
Bought a set of Draper 28967 Metric ones in that style back in 1973 from a proper engineers tool shop at the motorway side of Orpington. These days they call it Tubular-Box-Spanner-Set-(6-Piece) but I'm pretty certain that back then they were just plain ordinary box spanners.
Key has the feel of being historically more correct for the style in question. Googling Toolpost Key as suggested by DiogenesII comes up with some results of similar forged hex head on stalk devices. Both T handle and bent shaft.
Ian Skeldon 225/05/2021 13:08:42
543 forum posts
54 photos
Gentlemen thank you, this forum never fails. Many years ago I thought they were known as tool post wrenches or tool post box spanners but I look on RDG and ARC and couldn't find anything, hence my question, I will go away and get one ordered.
Many thanks for your help,
Ian
larry phelan 125/05/2021 18:07:54
1346 forum posts
15 photos
I never knew what thread those screws were !!
But then, I only have my Craftsman lathe about 20 years !!!cheeky
old mart25/05/2021 18:15:40
4655 forum posts
304 photos
I bought a very cheap box of sockets on ebay simply because it had a couple of double square sockets in it. They were for 8 and 10mm heads. The other way would be to just buy some SHCS of the right length and diameter, and use a hex key.
Ian Skeldon 226/05/2021 21:27:54
543 forum posts
54 photos
Posted by larry phelan 1 on 25/05/2021 18:07:54:
How do you find your Craftsman in use, by that I mean that mine arrived with the operating handle needing to be pushed down for normal spindle running (anti-clockwise), I changed the wiring over so that lifting the lever up now provides AC rotation. I also find the cross slide function odd, if I tighten the gib so that I can only just move it it moves so freely with the leadscrew, I don't want to over tighten it and induce wear but it does seem slack in operation.
Any hints tips or advice gratefully received.
Ian
