Sawdust | 08/05/2021 21:05:03 | ||||
16 forum posts 33 photos | Hi all. I posted last July (seems incredible it was so long ago) in General Questions under the topic 'How Best to Sell a Clarkson Cutter Grinder and Accessories' and left it that I would in due course come back with photos etc. It's taken ages to figure out what came with the machine, and also to list and photograph the items - there's quite a lot of accessories with it albeit with a few gaps. It's not been offered for sale anywhere else yet. I'll post the item list and some sample pictures on this thread later tonight or tomorrow, and would also appreciate feedback and help with the identification of some of the items. Also of course expressions of purchasing interest. I'm in Ireland which complicates matters (will advertise it here also), but it perhaps would not be such a big deal if the lot went in a single shipment. If it gets to the point where serious interest is being expressed I can verify measurements, provide close up photos etc. It'd help greatly if for example there exists a document with pictures and better still also dimensional information for the full list of accessories (optional as well as standard - the manual and the various websites seem only to include pictures for the standard accessories and there's items with this machine not in it) There's also separately a Grind All No.1 (75mm centre height) fixture which was possibly used in place of OEM equipment for some grinding operations. Also a Jones and Shipman 521 knife edge balancing stand and what looks to be a very little used UX.8004 radius wheel forming/dressing attachment in its case - both came with the grinder. It seems that the photos should go in an album. There's 30+, does anybody know if there is a cap on how many can be posted in an album? Thank you Edited By Sawdust on 08/05/2021 21:06:13 | ||||
Steviegtr | 08/05/2021 22:33:43 | ||||
![]() 2668 forum posts 352 photos | Well if you look at my albums there are hundreds of pictures. So probably not a problem for you. I am sure there will be many forum members who would love to own your machine. Obviously at a reasonable price. Steve. | ||||
noel shelley | 08/05/2021 22:41:45 | ||||
2308 forum posts 33 photos | I know a bit about them so will await the pictures ! Some of the attachments will be worth more than the grinder it's self. Have you looked at The bedroom workshop site ? It has hundreds of picture and some dimensioned drawings Noel. Edited By noel shelley on 08/05/2021 22:44:51 | ||||
Sawdust | 08/05/2021 22:57:40 | ||||
16 forum posts 33 photos | Thanks guys. I've been trying to upload the pics (x32). Clicking 'browse' lets me access the folder on my PC, but I can't seem to select more than one pic at a time. All have been compressed to a few 100kbs each so they are not too large. Am I missing something? Can I for example select the folder containing all the pics, upload that and end up with all 32 pics dsplaying in a single album? If it is a case of doing it one by one, will they all end up in the same album? | ||||
JasonB | 09/05/2021 06:58:51 | ||||
![]() 25215 forum posts 3105 photos 1 articles | You need to do them one at a time then upload each batch of 5, they will end up in whichever album you select. As you can see from the number I have there is no total limit Edited By JasonB on 09/05/2021 06:59:21 | ||||
Sawdust | 09/05/2021 12:26:06 | ||||
16 forum posts 33 photos | Thanks Jason, will try that... | ||||
Sawdust | 09/05/2021 15:05:49 | ||||
16 forum posts 33 photos | That worked out fine, thank you. The pictures are now up in the album ‘Clarkson Mk2 Tool Grinder & Accessories for ID and Sale’ at **LINK** The following x3 posts list the items (too many words to post it in one), the numbers correspond with the numbers of the photos in the album. Bear in mind that the descriptions and identification of the items is provisional. I have machine shop experience but the Clarkson is new to me. Item identifications are generally from the pictures in the manual. All is clearly used but functional. Some of the items had surface rust at some point which has left staining (the lows res/compressed pictures are not complimentary in this regard), but there is nothing which seems likely to affect function. Bores and ODs are very little affected, perhaps because they were oiled. As before I also have the photos in full resolution form, and can make these available and take measurements and/or provide additional close-up photos of specific areas to enable resolution of questions and/or in the event of serious interest.
Edited By Sawdust on 09/05/2021 15:31:04 | ||||
Sawdust | 09/05/2021 15:14:22 | ||||
16 forum posts 33 photos | Ref the pictures in the album ‘Clarkson Mk2 Tool Grinder & Accessories for ID and Sale’ at **LINK** - the numers in the list correspond to those in the photo names. Clarkson Tool Grinder Related:
X2 9268? with 1.25in bore both ends (one with plated retaining collar for use with universal head) x1 with 25mm bore at flanged end. (the 16mm adapter bush is in situ and needs pressing out) x1 with 0.625in bore both ends (accepts 0.625 OD long reducing sleeves listed as item/pic 25 below). Also of later manufacture (?) - quality is as above but the flanges are not knurled: x1 with 1in bore at flanged end x1 with 1.25in bore at flanged end. x1 possibly unfinished (not yet ground?) of OD 38.75mm (does not fit uni heads) with 24.6mm bore.
Sawdust | 09/05/2021 15:19:10 | ||||
16 forum posts 33 photos | Clarkson Tool Grinder Related: contd. 9. Tooth rest for spiral work 91103 with rotatable tooth mounting. 10. Tooth rest for general work 97010. 11. Adapter bush set metric 92617 – 92622 inc., OD 25mm x IDs 6, 8, 10, 12, 16, 20mm. 12. Adapter bush set inch 92607 – 92611 inc., OD 1in x IDs 0.25, 0.375, 0.5, 0.625, 0.75in. 13. Wheel flanges, small 92559(?) (on machine), large 93575(?) In pic - latter somewhat rust pitted and possibly of local mfg. 14. Extension spindle 92614(?), OD 1.5in. 15. Miscellaneous loose teeth. 16. Set of unidentified (possibly local mfg) ground cylindrical metric mandrels, OD 10, 11, 12, 14, 14.42 (long), 16, 18, 20, 25, 30mm. 17. Regrind mandrel, unidentified but probably OEM, 1.25 in dia spigot. Dark staining is surface. Edited By Sawdust on 09/05/2021 15:44:00 | ||||
Sawdust | 09/05/2021 15:20:50 | ||||
Clarkson Tool Grinder Related (contd.) 18. Air bearing flute grinding attachment metric 98101 in original box, collets missing. 19. Close up pic of bore of air bearing flute grinding attachment. 20. Dedlock 200 regrind mandrel 1.5in spigot, 91126(?) Missing tommy bar. 21. Pair of flanged mandrels, unidentified. 0.625in shanks. X1 with 25mm dia spigot, x1 1in. 22. X3 cylindrical mandrels, unidentified. ODs 0.75, 1.0, 1.25in. 23. Flanged and threaded mandrel, unidentified. Dedlock 150 regrind mandrel or could be local mfg. copy? 1in dia shank, 26.2mm dia spigot. 24. Quantity 15no miscellaneous local mfg (?) mandrels. 25. Set x6 long reducing sleeves (x2 with screw fixed knurled collars) to fit in straight shank holders, unidentified but probably OEM. 0.625 OD x IDs 0.25, 0.375in. Also 1.25 OD x IDs 0.5, 0.625, 0.75, 1.0in. 26. Pair of unidentified mounting blocks for diamond dressing points. Edited By Sawdust on 09/05/2021 15:21:48 Edited By Sawdust on 09/05/2021 15:22:53 Edited By Sawdust on 09/05/2021 15:28:52 Edited By Sawdust on 09/05/2021 15:29:40 Edited By Sawdust on 09/05/2021 15:30:04 | ||||
Sawdust | 09/05/2021 15:25:23 | ||||
Other Items (not related to Clarkson tool grinder)
27. Jones and Shipman UX.8004 (?) radius grinding wheel forming/dressing attachment in box. Very little used. 28. Box belonging to Jones and Shipman UX.8004 (?) radius grinding wheel forming/dressing attachment. 29. Grind All No.1 75mm centre height fixture with separate radius arm accessory, from working side. Probably used in for certain tool grinding operations in place of OEM accessory on the Clarkson. Seems tight and smooth. 30. Same Grind All No.1 75mm centre height fixture with separate radius arm accessory, from handle side. 31. Jones and Shipman model 521 knife edge static balancing unit. 32. Selection of unidentified mandrels, T nuts, brackets etc that came with the grinder, may or may not be related. 33. Selection of unused but unidentified cup grinding wheels and similar. Edited By Sawdust on 09/05/2021 15:27:27 Edited By Sawdust on 09/05/2021 15:34:18 Edited By Sawdust on 09/05/2021 15:37:07 | ||||
Sawdust | 09/05/2021 15:32:41 | ||||
16 forum posts 33 photos | That should be it on the information. Please pardon the formatting funnies, there may be some incompatability between Firefox and the forum software - or something else... : ) Edited By Sawdust on 09/05/2021 15:38:24 Edited By Sawdust on 09/05/2021 15:44:56 | ||||
Tony Pratt 1 | 09/05/2021 15:53:34 | ||||
2319 forum posts 13 photos | Are we not using the for sale section now? Tony | ||||
Sawdust | 09/05/2021 16:06:46 | ||||
16 forum posts 33 photos | It's here because I'd hoped for some assistance in the identification of some of the accessories Tony. I wasn't aware anyway of there being a for sale section, but if a moderator feels that the thread could be in a more appropriate section then that's for them to call. | ||||
noel shelley | 09/05/2021 17:00:23 | ||||
2308 forum posts 33 photos | Photo No 21 may be part No 47074. 19, the ABFG has a nonstandard Taper so missing it's collets is a great shame. 31 The wheel balancer should have a bubble plate that sits on the ways to set level. 25, are they MT bore ? No 1,2,3,4 ? The machine when new would have most of these parts as part of the kit. The ABFG was an extra and the other items obviously not with it. Hope that helps Noel. | ||||
Oldiron | 09/05/2021 17:10:00 | ||||
1193 forum posts 59 photos | Posted by Sawdust on 09/05/2021 16:06:46:
I wasn't aware anyway of there being a for sale section, For Sale is the big box on the right of the page titled "Latest "For Sale" ADs. If you are using a phone it may not be visible to you. regards | ||||
Sawdust | 09/05/2021 23:06:34 | ||||
16 forum posts 33 photos | OK, thanks - found the latest for sale ads box, it displays well down the page. I previously looked for a forum thread. It links to the option to list a for sale advert. I'll put the advert in there, but can't do it yet as 'price' is a required field - I'm only finding my way towards a view on likely values.
Edited By Sawdust on 09/05/2021 23:07:35 | ||||
Sawdust | 09/05/2021 23:28:17 | ||||
16 forum posts 33 photos | Thank you for the input Noel. 21 - they look OEM, but I've no idea what they are used for. The 47074 part number doesn't seem to bring up a pic or any information on a web search. 19 - it's a pity all right regarding the missing ABFG collets, they presumably are not widely available. 31 - the Jones Shipman wheel balancer does not have the bubble plate. 25 - the sleeves so far as I can tell do not have Morse taper bores, but are parallel. The seem much longer than the holder listed as 91125 standard equipment in the manual. The mix of accessories is a bit hit and miss, I don't know why. The machine as I said came from a now deceased friend. He may have bought it when the local branch of a US multinational with a mould maintenance oriented toolrom closed in the early 80s. He used it only intermittently to regrind small numbers of tools for customers when his tool design business was slack. | ||||
Sawdust | 14/05/2021 22:44:13 | ||||
16 forum posts 33 photos | Just to say guys that there should be an advert for the Clarkson Mk2 tool grinder and accessories plus the other items discussed under this thread up on lathes.co.uk in the next week or so. Thanks for the input - takes a while to get grounded when you're not familiar with a market or with the equipment in question... |
