Mystery Mains Connector
Michael Gilligan06/04/2021 15:55:52
23121 forum posts
1360 photos
My wife has a tiny ‘travel iron’ which she uses for pressing patchwork details
Unfortunately, this has a ridiculously heavy and stiff mains cable, with a poorly-fitting connector.
The iron is only rated at 25W
Does anyone recognise V-5-2 ... and is there anywhere I can buy one with a nice flexible lead [or is there even a rewire-able version] ?
Philip Rowe06/04/2021 16:28:57
248 forum posts
33 photos
Looks very much the same as the charging lead on my Karcher window vac, but of course that's only low voltage. Is there any chance a standard figure of 8 lead would fit? I think they are called C7.
Phil
Ian P06/04/2021 16:35:31
2747 forum posts
123 photos
That's one I've never seen before!
There are many similar ones, but the 'V' shaped notch is unusual. I would be tempted, because its low wattage, to find something like an old electric shaver lead and trim the moulding to suit the iron recess. Obviously the spacing and pin diameter need to be in the right ball-park.
Is the iron marked as double insulated? it should be really.
Ian P
Michael Gilligan06/04/2021 16:56:01
23121 forum posts
1360 photos
Posted by Philip Rowe on 06/04/2021 16:28:57:
Phil
Not as it stands, Phil ... The vee is quite pronounced
Thanks for the thought though.
DiogenesII06/04/2021 17:05:09
859 forum posts
268 photos
Posted by Michael Gilligan on 06/04/2021 16:56:01:
Phil
..if only we had a milling machine..
Michael Gilligan06/04/2021 17:10:28
23121 forum posts
1360 photos
Posted by Ian P on 06/04/2021 16:35:31:
Ian P
Yes ... marked as double insulated yes
Edited By Michael Gilligan on 06/04/2021 17:16:29
Michael Gilligan06/04/2021 17:22:40
23121 forum posts
1360 photos
Posted by DiogenesII on 06/04/2021 17:05:09:
That may indeed be the solution [even if it doesn’t answer the question]
Ian P06/04/2021 17:25:59
2747 forum posts
123 photos
Re 'milling machine' above. What about a Dremel on the recess of the iron?
A polarised connector is not needed so removing the whole male part of the V will not matter, Again, pin spacing and diameter on whatever lead you can find will determine what is possible.
Ian P
Brian G06/04/2021 17:30:45
912 forum posts
40 photos
My guess would be that the cable is stiff because it is a hot condition type, and perhaps that is why the non-standard connector is used (like the difference between a computer "kettle lead" and a real kettle lead.
Having said that, this non-reversible connector looks similar, but without a drawing or clearer photo (from the supplier, not Michael) it is hard to tell.
Type C52 connector
Brian G
peak406/04/2021 17:38:47
2207 forum posts
210 photos
Phil
Michael, what size is it compared to a Figure of 8?
In the past, I've modified a C7 connector with a Dremmel and a round burr.
This was so I could use one, albeit unearthed in a clover leaf socket for my travel lead when we go on holiday.
Hydra Mains Cable
Yes it is carefully soldered and each core insulated, as well as the overall joint being double sleeved as well.
It lets me use 4 camera chargers, or 3 chargers and a laptop from a single outlet, which is quite handy.
I have one for UK plugs, one US and this EU style.
There's various proprietary connectors, many of which are now discontinued, particularly in the EU
https://www.plugsocketmuseum.nl/PowerCord1.html
Bill
Michael Gilligan06/04/2021 17:59:28
23121 forum posts
1360 photos
Posted by Ian P on 06/04/2021 17:25:59:
It's easily small enough to do on the BCA ... just more faff than I was hoping for
Michael Gilligan06/04/2021 18:20:48
23121 forum posts
1360 photos
Posted by peak4 on 06/04/2021 17:38:47:
Phi
Bill
Thanks, Bill ... but that’s where I started my quest
Drew a blank, so came to the forum
Pin diameter and spacing looks identical to the typical fig 8 connectors ... but I will check more carefully.
I suspect that the ‘special High Temperature version’ may be the gotcha
Robert Atkinson 206/04/2021 18:20:50
1891 forum posts
37 photos
The lead is probably stiff because it is cheap and nasty heat resistant cable. The connector is non-standard. This is because you should not be able to use a non heat resistant cable on a heating device ( hence difference between C13 computer leads and C15 kettle leads). Using a different lead by modifying it or the iron will reduce its safety.
A bigger concern is the sole plate of the iron appears to be metallic This would almost certainly need a 3 core earthed connection. I would bin it and by a travel iron from a reptutable manufacturer. While this one does have a CE mark, the label is clearly not compliant and the website does not exist.
Robert G8RPI.
Edited By Robert Atkinson 2 on 06/04/2021 18:21:27
old mart06/04/2021 18:34:00
4655 forum posts
304 photos
Bin it and look for a known brand. As already mentioned, the metal soleplate must be earthed.
Michael Gilligan06/04/2021 19:23:19
23121 forum posts
1360 photos
Not allowed to bin it ... it says so on the label
angel
peak406/04/2021 19:29:45
2207 forum posts
210 photos
Just for interest, the UK company importing them from India went bust a few years ago
https://www.thegazette.co.uk/notice/2936066
The web address used to be correct, according to the Internet Archive.
https://web.archive.org/web/20161028211527/http://www.teamuki.com/index.php?route=common/home
And you can still import them yourself if you wish, direct from India, but I guess only by the pallet load, and I'm not sure about electrical certification.
https://www.indiamart.com/proddetail/micro-iron-4590020473.html
None of which helps you obtain a replacement lead of course.
Bill.
Trevor Drabble06/04/2021 19:32:44
339 forum posts
7 photos
Michael , Wonder if those kind and knowledgable people at Bulgin would be able to help ? Trevor .
Speedy Builder506/04/2021 19:33:42
2878 forum posts
248 photos
HP used to use them at one time. I had to get a non polarised plug and grind a slot into it.
Michael Gilligan06/04/2021 20:18:22
23121 forum posts
1360 photos
For what it’s worth ... the cheap and nasty cable is branded KEMA-KEUR and proudly carries its details
... too much information to be worth quoting here; except to mention that the conductors are each.0.75mm^2, which is rather hefty for 25W
**LINK** https://www.dekra.com.cn/en/cables-and-wiring/
The cable is dated 1997, and the product was supplied by ‘Comet’
[ I picked it up, apparently unused, at a Charity Shop ]
The box states that it uses “PTC technology” and works on 100V to 250V”
... this may, or may not, also imply that the soleplate is adequately insulated from the electrics
Here’s what little I currently know about PTC heating: **LINK**
https://www.pelonistechnologies.com/blog/three-benefits-of-ptc-heating-technology
Edit: __ Thanks for the recent posts yes
Edited By Michael Gilligan on 06/04/2021 20:20:17
Robert Atkinson 206/04/2021 21:11:57
1891 forum posts
37 photos
OK don't bin it, "dispose of in a legal and environmentally friendly manner" with extreme prejudice devil
Being PTC based means it will maintain temperature but is no indication of the quality of insulation, It is very difficult / expensive to achive good thermal conductivity and the electrical insulation, including creapage and clearance, required for a class II (double insulated) appliance. I would be VERY suroised if this iron met the required safety standards. it is cheaper to use an earth wire. This was probably designed for 100 /115V
The UK importer probably went of of business so they didn't have to give refunds. Several of the items on the archived webpage clearly would not meet european safety standards e.g. 2 bar electric fire.
Robert G8RPI.
