Taps with plus sizes?
Ian Parkin31/03/2021 16:58:24
1174 forum posts
303 photos
I was browsing eBay looking for a new tap and noticed a few 18mm x 1.5 taps with + 004” and + 0.24 after the size
i must confess i had not seen such before
why have an oversize tap?...only seemed to be for 18mm that I’ve seen
Pete.31/03/2021 17:04:06
910 forum posts
303 photos
I think it's for galvanised bolts etc?
Ian Parkin31/03/2021 17:18:45
1174 forum posts
303 photos
And are galvanised bolts common in m18?
colin hawes31/03/2021 17:28:44
570 forum posts
18 photos
They are used on steel that has to be case hardened to allow for hole shrinkage/distortion. Colin
Tony Pratt 131/03/2021 17:59:10
2319 forum posts
13 photos
Posted by colin hawes on 31/03/2021 17:28:44:
Good engineering practice is to plug tapped holes so the threads remain soft during the case hardening process or you can carburise the part then drill & tap the required holes then finally harden.
Tony
Pete.31/03/2021 18:50:40
910 forum posts
303 photos
Oversized taps do not only come in m18.
colin hawes31/03/2021 19:12:09
570 forum posts
18 photos
Posted by Tony Pratt 1 on 31/03/2021 17:59:10:
Tony
I have cyanide case hardened threads to about .005 deep on tooling that requires a wear resistant tapped hole. It gives long life and greater strength. The taps used were known as "B" taps. Colin
old mart31/03/2021 19:48:22
4655 forum posts
304 photos
Pre plating and anodising taps will be different oversizes depending on the exact conditions. At the museum we have a large number of taps, mostly given to us and I get rid of the oversize ones before they cause problems.
alan ord 231/03/2021 20:32:28
145 forum posts
41 photos
Old Mart you are correct. I used to source pre plating taps, which are slightly oversize for the tapped hole in a component. After plating the tapped hole is to the correct size.
This is common in industry.
Alan.
Edited By alan ord 2 on 31/03/2021 20:33:34
Edited By alan ord 2 on 31/03/2021 20:34:18
Tim Stevens31/03/2021 21:18:32
1779 forum posts
M18 x 1.5 = sparking plug size before WWII* - just in case it helps.
* except model T Fords, of course.
Tim
bernard towers31/03/2021 21:39:57
1221 forum posts
161 photos
Didn’t know anodising changed dimension, mine doesn’t,!!
Stueeee31/03/2021 22:16:49
144 forum posts
Posted by Tim Stevens on 31/03/2021 21:18:32:
Tim
Model T was/is 14 TPI 1/2" American Pipe thread IIRC...
Model "A" Ford and early Chevrolet used 7/8" x 18 UNS spark plugs, took a while for the world to arrive at "standard" spark plug threads.
Tim Stevens01/04/2021 09:40:12
1779 forum posts
Not wishing to swerve away from the original thread, but there are currently 4 'standard' plug threads, as well as the piddly little things used in ic engine models.
Tim
