3" and 4" Wheels
Tee shaped 3" and 4" Ring with ability to add the Spokes
Malcolm Farrant25/03/2021 15:44:10
102 forum posts
I am currently trying to make a sale model of a Ransomes Class A Thrasher.
The Model requires 2 x 3" wheels and 2 x 4" Wheels. The Plan shows the Wheel section to be Tee shaped with the spokes then attached to either side of the base line of the Tee.
Can any one give me a source to find these 3 and 4" Rings
Without the necesary rings it would seem I may have to turn them from a solid bar.
Any suggestions would be much apreciated
Thank you Malcolm Farrant
JasonB25/03/2021 15:51:48
You can either get some thick wall tube from the likes of M-machine and turn that to a Tee section or make them up from slices of ERW steel tube with silver soldered in "washers" to give the tee section. have a read of this where I did some 5.5" ones
noel shelley25/03/2021 17:28:57
2308 forum posts
33 photos
As Jason ! but braze tn the "washers" save a fortune ! Some of these machines had cast wheels with quite a thick rim. Thick wall tube There are countless combinations of dia and wall. Good luck. Noel
Bo'sun25/03/2021 17:49:52
754 forum posts
Another vote for thick wall steel tubing. Mine came from "Metals United Limited". Although I'm sure there are many other suppliers. Mine from MUL was available as a 300mm length.
Malcolm Farrant26/03/2021 14:04:10
102 forum posts
Asalways thnks for your suggestions. \as always a BIG help
Best wishes
Malcolm Farrant
DMB26/03/2021 14:21:44
1585 forum posts
Jason, I prefer your method rather than that of a fellow club member. He did his by trepanning the discs, but did the rims differently. He obtained thickish steel sections, milled a central slot, rolled the up to spring over the remains of the discs and welded it all together. More than one way of skinning the cat as they say.
Richard S226/03/2021 15:52:22
237 forum posts
135 photos
I found it easy to source thick walled steel tube (seamless) from M-machine. A quick check shows up a choice of the sizes you would require to produce turned 'T' rings.
I recently produced a pair with a diameter of 4 1/2", although mine had all the spokes riveted to the inner face of the 'T', but easy enough to alternate. Maybe a little fiddly on the 3" Diddy ones, but do-able.
I used a simple double edged (3/16ths) square HSS tool in a boring bar on my lowest speed (ML7) with no issues-
There are some images in my album which may assist you with building them this way, or help you decide.
Rgds
