jeff thyer | 18/03/2021 01:16:39 |
3 forum posts 1 photos | Does anyone have a 12/25 tooth fine-feed tumbler gear supplied by Myford. The gears are 14 1/2 degree PA, 20 DP. I intend to fabricate (hob) one of these compound gears for my ML7, but I would like to know if the 12 tooth pinion has an increased diameter to avoid undercut teeth. The 'normal' diameter for a 20DP, 12 tooth spur gear is 0.70 inches. The 'enlarged' diameter recommended by Machinerys Handbook is 0.762385 inches. The increased centre distance is not a problem because mating gears are always mounted on the change gear quadrant, so centre distance can be adjusted accordingly. Machinerys Handbook also states that 'enlarged diameter' pinions will mesh with 'normal' gears. I would be grateful if someone could measure the outside diameter of the 12 tooth gear if you have one of these tumbler gears. Thanks, Jeff |
not done it yet | 18/03/2021 07:40:45 |
7517 forum posts 20 photos | Yo most certainly shouldn’t be worrying about that last 0.000005”.🙂 I would likely not even worry to the nearest 0.001”. 🙂 Make it in Aluminium or other softer metal (even plastic)? |
John P | 18/03/2021 08:05:05 |
451 forum posts 268 photos | Hi The blank od for the 12 tooth gear that you have asked about is .746 inch in diameter. John |
AStroud | 18/03/2021 08:16:19 |
44 forum posts 12 photos | Good morning Just measured the 12T on my S7 and the OD over the teeth = 0.723" |
John P | 18/03/2021 11:21:00 |
451 forum posts 268 photos | Difficult to know why the difference in measured size of this 12 tooth gear,
In practical terms 5 teeth would be about the minimum and that would generally be A little more freedom with this is if helical gears are cut as the divide by cos helix angle Dimensions for 1 DP for other pitches divide by the dp
TEETH 17 .26 John |
Howard Lewis | 18/03/2021 15:00:12 |
7227 forum posts 21 photos | This is puzzling! Using the formula from Ivan Law's book on gears, OD = (tooth count+2 ) / DP, so a 20DP gear with an OD of 0.750 would have 13T . (13+2 ) / 20 = 0.750 The gear obviously has 12T, but 0.7465 x 2 = 1.493. So it looks as if the gear is oversize for a 20DP involute form 12T, unless there was a Zero error. (12+2 ) / 20 = 0.700 Are there any professional gear specialists out there to offer an explanation? Howard |
JasonB | 18/03/2021 15:02:57 |
![]() 25215 forum posts 3105 photos 1 articles | It's in the 1st post, small gears are often over size to avoid an undercut particularly if being cut with an involute cutter. |
Howard Lewis | 18/03/2021 15:08:44 |
7227 forum posts 21 photos | Thank You Jason! |
JasonB | 18/03/2021 15:13:11 |
![]() 25215 forum posts 3105 photos 1 articles | HPC's Technical guide shows how they increase the dia look at "corrected teeth" and you will see why you came up with 13 teeth for that OD, |
Pete Rimmer | 18/03/2021 21:21:45 |
1486 forum posts 105 photos | Posted by Howard Lewis on 18/03/2021 15:00:12:
This is puzzling! Using the formula from Ivan Law's book on gears, OD = (tooth count+2 ) / DP, so a 20DP gear with an OD of 0.750 would have 13T . (13+2 ) / 20 = 0.750 The gear obviously has 12T, but 0.7465 x 2 = 1.493. So it looks as if the gear is oversize for a 20DP involute form 12T, unless there was a Zero error. (12+2 ) / 20 = 0.700 Are there any professional gear specialists out there to offer an explanation? Howard As Jason said the small tooth count gears are modified with a 'long addendum' to reduce the under-cut and strengthen the gear. The amount of profile shift depends on the tooth size and tooth count. |
Howard Lewis | 19/03/2021 17:01:56 |
7227 forum posts 21 photos | Thank You Pete. Are similar tables available for Module Gears? If so, where can I find them please? Just in case I ever need tom use them. Howard |
John P | 19/03/2021 17:56:52 |
451 forum posts 268 photos | The list in my previous post was slightly corrupted when copying over to
20 dp 12 tooth .36/20 =.018" 12 tooth / 20 dp= pitch dia = .600 inch + .018 + addendum .100 inch Teeth Correction 17 = .26 The same basic rule applies ,for module gear the correction is the tooth number x the There are 3 examples here 1 mod gears . 1 cut at nominal pcd 6mm ,2 at 6.48 mm pcd Howard's suggestion that the caliper was not zeroed properly is not well thought Getting back to the OP's original question he could use any size from the from the .723 inch measured by Thanks Pete for posting that copy of table 8 .I never had any information on these corrections
John Edited By John Pace on 19/03/2021 17:58:39 Edited By John Pace on 19/03/2021 17:59:17 Edited By John Pace on 19/03/2021 17:59:55 |
jeff thyer | 20/03/2021 02:50:09 |
Gentlemen, thanks to all who contributed, this has been most helpful. It is difficult to understand how two S7 tumbler gears from Myford could have different diameters for the 12 tooth pinions. Without wishing to upset anyone, perhaps Mr Stroud measured his pinion across two diametrically opposite chords instead of across two diametrically opposite teeth. The attached photo illustrates my point. I will probably use the 0.746 inch dimension as it appears to have produced a suitable gear form. I assume the 'standard' depth-of-cut for the hob is used on a blank of this diameter to produce the desired profile shifted gear. Regards to all, Jeff |
AStroud | 20/03/2021 08:37:50 |
44 forum posts 12 photos | mea culpa, I had measured in situ. I have taken the gear off and remeasured |
jeff thyer | 20/03/2021 08:42:14 |
3 forum posts 1 photos | Thanks for that Mr Stroud, looks like 0.7445/0.7465 is the go! |
Michael Gilligan | 20/03/2021 09:13:53 |
![]() 23121 forum posts 1360 photos | Here are a couple of useful links for those mined to explore: http://www.hessmer.org/blog/category/gears/ https://khkgears.net/new/gear_knowledge/abcs_of_gears-b/gear_profile_shift.html MichaelG. |
John P | 20/03/2021 09:51:14 |
451 forum posts 268 photos | Hi Michael Have a look at this gear calculator from Ondrives it only works in module inputs so for 20 DP you would have to input 1.27 mod the interesting thing is when the checkboxes are filled in and calculated the diagram at the bottom of the page changes and shows the the tooth profile. https://www.mesys.ch/calc/ondrives.fcgi
John |
Michael Gilligan | 20/03/2021 10:14:09 |
![]() 23121 forum posts 1360 photos | Posted by John Pace on 20/03/2021 09:51:14:
John . Thanks for that, John ... very impressive For convenient reference: **LINK** My Bookmarks folder has grown again ! MichaelG.
Edited By Michael Gilligan on 20/03/2021 10:14:40 |
