Member postings for AStroud
Here is a list of all the postings AStroud has made in our forums. Click on a thread name to jump to the thread.
Thread: Saving Money in the Workshop
05/05/2023 17:12:35
I used magnets to attach a shield on my BCA and found the chips they attracted soon became annoying + the magnets grabbed any tool that I went close with. Quickly changed to another method.
Thread: Fastener Storage
12/03/2023 13:12:48
My low tech solution, small boxes made from cardboard and ex spice racks from a boot
storage.jpg sale
Thread: Beam engine Watts Linkage
07/02/2023 15:07:23
I have started building Gerry's beam engine and have wondering about the linkage and alignment.
Would it be a bodge or cheating if I mounted the cylinder base on a pivot to allow it to move slightly. It would seem preferable to any binding at the gland or piston. The pivot could be hidden if necessary and I am guessing any movement would be hardly noticeable.
Thread: Ford Production Line (with a difference)
21/01/2023 09:13:21
In the late 70's I remember being taken around a Perkins diesel production line as an interviewee after a graduate apprenticeship, we had been warned the workers may appear hostile. We were catcalled all the way around presumably because we looked like management. It was quite intimidating.
Edited By AStroud on 21/01/2023 09:14:16
Thread: USS 'MONITOR' engine build
15/01/2023 13:21:20
Hi David
Yes I have and do not remember any problems apart from one or two minor dimensions not shown but easy to either derive or choose to suit.
I did freelance some features
Thread: Metric O Ring Grooves
08/01/2023 10:35:55
My go to for O ring selection is the James Walker catalogue, downloadable as a pdf from their website, p29 onwards has groove design for o ring size.
Thread: Miniature Rams Needed
21/08/2022 11:12:18
I used the designs shown on Magonhrc to build my own cylinders, roughly the size you mentioned.
I have used them at up to 150 psig without any disasters or leaks.
20/08/2022 09:03:58
Try this site for inspiration **LINK**
There are sections for farm machianry and construction vehicles
Thread: Pre-order the September issue now!
05/08/2022 12:10:14
Often wondered how pre-order differs from order, here it seems the same thing. Maybe its the delivery time.
Thread: Axial piston air motor
06/07/2022 16:17:40
Thanks Noel
Whilst there are many diagrams of hydraulic pumps and motors available I could not find much for air motors though I suppose there many similarities
I did consider air passages down the pistons to the swivel joints and possibly through the slipper pads for lubrication and pressure compensation but decided it was a step too far for the moment.
06/07/2022 13:42:46
Hi
Here's a picture of my own design axial piston air motor. There are 6 12mm dia pistons in the barrell which will rotate around the angled swash plate which will be on an axle to allow the angle to be varied. The aluminum valve plate is stationary, held against the barrell with a spring and will have radial adjustment to allow valve timing variation.
To finish I need to shorten the shaft, mount the swash plate on an axle with gear and worm for adjustment and machine the ports in the valve plate. I also need to figure out the radial adjustment of the plate whilst allowing it to self align to the barrell.
I am slightly concerned there will be too much friction to allow it to run and possibly too much leakage at the valve plate/ barrell seal, we shall see.
Thread: boiler connector
26/05/2022 17:30:06
Hi Duncan
When I had a similar issue it turned out the rotor which detects the flow had fallen off. Maybe something to bear in mind if the switch itself turns out to be OK.
Thread: Hello - Uni or apprenticeship
26/05/2022 16:20:06
You may aspire to becoming a Chartered Engineer and a member of the M.I.Mech.E , be good to check with them the entry requirements.
Thread: Just A New Somebody
22/05/2022 16:05:48
Hi Chris
Welcome to the forum, look forward to hearing about and seeing your interests.
Thread: Oil can (again)
20/05/2022 10:28:02
Hi John
Contraption??!!surprise
Its a half built IC engine, based roughly on one of Brian Rupnow's designs, he gives them all names but I have forgotten which one I used for inspiration but it has an overhead cam.
Having built a Potty mill engine and a Monitor I thought I should make an IC engine but stalled when it came to making the cams. I do not have a dividing head and could not see an easy way. The model got pushed to the back and I made a Corliss instead, in the photo you can see a scrap cylinder, milled the steam chest too deep.
I do plan to finish the IC engine, just waiting for the right inspiration to come along.
20/05/2022 08:01:42
I got fed up with oil cans that leaked, seemingly even if not being used so I made my own from bits in the scrap box.
Not the most ergonomic design but it works well and does not leak at all.
Thread: What Did you do Today 2022
18/01/2022 08:19:25
Finished my own design mill engine
Thread: Lock nuts / Jam nuts - MEW 311
07/01/2022 14:24:38
If used in steel buildings the bolts are likely to be high strength friction grip where the shear is taken by the friction between the 2 clamped surfaces.
Thread: BCA belt replacement
31/10/2021 12:17:44
Thanks for the replies.
I wanted to avoid stripping out the main spindle and so not use a made up belt.
The only reason for looking at the leather belting was the mechanical joint sounds more dependable as I wonder about the effectiveness of the green belt joint by fusing together but sounds like it should not be any issue.
Edited By AStroud on 31/10/2021 12:18:10
31/10/2021 11:07:15
Hi BCA owners
My Mk111's belt has a crack in it at what looks like the joint about 50% through so only a matter of time before it goes. It is not the orignal belt but certainly pretty old, some poly* material I think.
I put a hot knife blade in the crack then pressed it together and held until it cooled but no sign of any join or weld.
I see on ebay there is round leather belting available, 5/16" dia with a staple to join, meant for sewing machines and I wondered if anyone had tried this at all and what the experience is. If not good then I will try some of the round poly belt that is available.
I would be greatful for any advice/experience in the belt replacement.
