pgrbff | 13/03/2021 13:34:01 |
261 forum posts 31 photos | Is there a product, water-based, that you can immerse small steel parts in, like nuts and bolts that have been cleaned up during restoration? I use a small ultrasonic cleaner with water-based cleaning and oxidation removal products but have to dry each piece thoroughly and quickly after removal. |
Clive Hartland | 13/03/2021 13:50:46 |
![]() 2929 forum posts 41 photos | Put them on a metal tray in a warm oven. |
pgrbff | 13/03/2021 14:06:47 |
261 forum posts 31 photos | That's what I usually do but you can still get a film of rust with some steel. |
DC31k | 13/03/2021 14:15:03 |
1186 forum posts 11 photos | Somewhere else, I saw this product recommended: Bilt Hamber Atom Mac. If you look it up and then use some of the terms it uses to describe itself in a search, you will find alternative products that work in a similar manner. |
pgrbff | 13/03/2021 14:40:33 |
261 forum posts 31 photos | Posted by DC31k on 13/03/2021 14:15:03:
Somewhere else, I saw this product recommended: Bilt Hamber Atom Mac. If you look it up and then use some of the terms it uses to describe itself in a search, you will find alternative products that work in a similar manner. That would be too good to be true if it works. |
mgnbuk | 13/03/2021 16:14:20 |
1394 forum posts 103 photos | Coolant. IIRC water soluble coolants have a corrosion inhibiting as well as lubrication capabilities. ScotOiler - a company that makes motorcycle chain lubrication systems - have a product called FS365 for all-year-round motocycle corrosion protection described as " FS 365 Complete Bike Protector is a water-based corrosion inhibitor, the idea is that you spray it on and the water content carries it into all the hard to reach places of the bike, we’re talking every tiny little gap. The water content then evaporates leaving a film of protection on all surfaces. " This stuff smells like synthetic coolant ! A litre spray bottle costs around a tenner & it can be had from Halfords and motorcycle dealers (or online). A bulk 5 litre refill container full is around £35 I have a bottle, but as I don't ride all year round now I cannot vouch for it's effectiveness. It has been around for a few years now & gets recommended in the motorcycle mags & forums for "year round" riders. Nigel B. |
Mike Crossfield | 13/03/2021 16:42:41 |
286 forum posts 36 photos | I can vouch for Bilt Hamber Atom Mac. Dilute with water and spray to prevent corrosion. Very high dilution ratio, so a small bottle lasts for ages. I use it to spray the brake discs on my cars after washing to stop them flash rusting. Works a treat. Incidentally, for any car enthusiasts out there, Bilt Hamber’s other car care products are also good value. Wide range of products, and all the ones I’ve used are excellent. Their “2 speed wax” is the best I’ve ever used (and I’ve tried a lot), and their alloy wheel cleaner regularly comes top in comparative tests. Same goes for their rust removal products. Usual disclaimer - no connection just a happy user. |
Trevor Drabble | 13/03/2021 16:47:46 |
![]() 339 forum posts 7 photos | Have you seen the excellent range of Shield Technology products available from Arc ? No connection with company , but have used 3 of the 5 ST products with considerable success . Trevor. |
Oven Man | 13/03/2021 17:21:21 |
![]() 204 forum posts 37 photos | How about central heating corrosion inhibitor? Peter |
DC31k | 13/03/2021 17:25:43 |
1186 forum posts 11 photos | Posted by mgnbuk on 13/03/2021 16:14:20:
A bulk 5 litre refill container full is around £35 Compare and contrast to the Bilt Hamber product. Going rate seems to be £21.95 for 500ml and dilution rate is 2-5%. |
Tim Stevens | 13/03/2021 18:39:58 |
![]() 1779 forum posts 1 photos | the problem with a water-base product where the water is not intended to evaporate (complying with your spec, PGRBFF), is that water - even distilled water - contains dissolved oxygen. And if it doesn't, because it has been boiled five seconds ago, it will absorb it from the atmosphere. Cheers, Tim |
Bazyle | 13/03/2021 18:54:02 |
![]() 6956 forum posts 229 photos | Phosphoric acid. Leaves a dull grey finish so not suitable for clocks. |
bernard towers | 13/03/2021 21:41:18 |
1221 forum posts 161 photos | recoil used to do a metal protect which I use on freshly turned parts but sadly I am nearly out of it so like you will have to start looking again |
bernard towers | 13/03/2021 22:29:56 |
1221 forum posts 161 photos | apparently rocol still do it its called Metal Protect green fluid |
blowlamp | 14/03/2021 00:44:38 |
![]() 1885 forum posts 111 photos | What about some Antifreeze? |
jimmy b | 14/03/2021 06:38:26 |
![]() 857 forum posts 45 photos | I use ACF50 liquid. I used to use this stuff on my motorcycles and ride all through winter. Excellent! That FS365 stuff was useless!!
For things that come out of my ultrasonic tank, I leave on the radiator for bit to dry.
Jim |
AdrianR | 14/03/2021 07:54:06 |
613 forum posts 39 photos | If i want to dry something quickly I rinse it in meths or acetone. This absorbs the water and then the solvent evaporates much quicker.
Adrian |
Mike Poole | 14/03/2021 08:27:39 |
![]() 3676 forum posts 82 photos | Having cleaned your parts what are you going to do with them? Obviously water is only going to be a carrier for another chemical that provides the protection. If plating, paint or blacking or some other treatment is to follow then you will be cleaning it again. Steel rusts very quickly when clean so the protection needs to be applied quite soon after cleaning. Mike |
Martin Connelly | 14/03/2021 08:55:10 |
![]() 2549 forum posts 235 photos | We used to use an ICI product that contained phosphoric acid to pickle mild steel pipes, I think it was called Deoxidine. We then washed the parts in a tank of cold water to remove the acid then finally they went into a third process tank containing water and another ICI product that was basically sodium nitrite. The parts were immersed in the hot tank to allow them to heat up then when they were raised out of the tank the water flashed off leaving a fine layer of sodium nitrite that acted as a rust inhibitor for a day or two. This gave enough time for the parts to be further treated without a rust bloom, they were usually painted on the outside and the bores sprayed with an inhibiting oil. We got rid of all this stuff by going all stainless to get rid of the labour costs associated with mild steel processing which were making them more expensive than the stainless versions. Martin C |
pgrbff | 14/03/2021 08:59:09 |
261 forum posts 31 photos | Posted by Oven Man on 13/03/2021 17:21:21:
How about central heating corrosion inhibitor? Peter I have lots of that! I have around 7000l of water in my CH so I always have some to top up with. |
