SillyOldDuffer | 11/03/2021 09:26:38 |
10668 forum posts 2415 photos | I'm deeply embroiled in doing up my son's new house, which has loads of minor defects and a few big ones! Can anyone advise on how to replace this common fitting, which combines the sink overflow with the plug chain end. It connects behind to a flexible plastic pipe, which then dumps overflow into the main outflow. I suspect the fixture just screws in but the plastic is brittle and likely to break. Or it might be glued in , a press-fit, or special to this particular sink. Does anyone know how and if these can be replaced? Ideally it's a standard screwed part, or I could make a non-standard one on my lathe. If changing it likely to go horribly wrong, I'll just leave it, because the fix is mostly cosmetic and the upgrading the kitchen is on the cards in the distant future when (or if) Son Of Duffer can afford it. Ta Dave
JasonB | 11/03/2021 09:30:53 |
![]() 25215 forum posts 3105 photos 1 articles | They usually screw in to the plastic "elbow" behind. usually come complete with the whole sink waste. Edited By JasonB on 11/03/2021 09:31:48 |
Journeyman | 11/03/2021 09:40:55 |
![]() 1257 forum posts 264 photos | As Jason says just unscrews not usually much more than finger tight. Whole kit less than a tenner from Wickes, Screwfix, B&Q etc. John |
Mike Hurley | 11/03/2021 09:42:17 |
530 forum posts 89 photos | As Jason says - simply screws into the elbow ot the rear. Have a look at Screwfix's website and search for sink overflow fitting and it will make it clearer. Hope that helps ****************** Journeyman beat me to it! Edited By Mike Hurley on 11/03/2021 09:43:38 |
Ady1 | 11/03/2021 10:00:48 |
![]() 6137 forum posts 893 photos | Just change the chain? the triangle bit pulls out sideways As a plumbing aside these are now easy to get on ebay Had one for a couple of years now and they are lifesavers when you have multiple women flushing alsorts down the drains, which always seem to block at 0830 on a saturday or sunday morning Edited By Ady1 on 11/03/2021 10:04:38 |
JasonB | 11/03/2021 10:04:34 |
![]() 25215 forum posts 3105 photos 1 articles | Looks like Dave wants to change it as the chrome has worn off rather then just wanting a chain Beware the above linked to unblocker as they do not mix well with push fit waste fittings! Edited By JasonB on 11/03/2021 10:05:30 |
Nick Clarke 3 | 11/03/2021 10:26:55 |
![]() 1607 forum posts 69 photos | Posted by JasonB on 11/03/2021 10:04:34:
Looks like Dave wants to change it as the chrome has worn off rather then just wanting a chain Beware the above linked to unblocker as they do not mix well with push fit waste fittings! Edited By JasonB on 11/03/2021 10:05:30 And even less well with push fit fittings on pipes running into a very shallow roofspace on a single story extension that has later had a low pitch tiled roof built on top! Please don't ask how I know as you do not want to see a grown man cry at the memory! |
SillyOldDuffer | 11/03/2021 10:51:42 |
10668 forum posts 2415 photos | What a wonderful forum! I'm much more confident about tackling it now I know it's screwed and that the whole overflow unit can be replaced. Every so often I come unstuck with DIY jobs when a simple part turns out to be unobtainium and the job escalates unreasonably . Like changing a tap washer reveals a badly grooved seat so the tap has to be replaced, but it's cemented into the sink, which breaks, forcing that to be changed, revealing the wall behind needs re-tiling and the whole bathroom has to be refurbished... Many thanks, Dave |
Zan | 11/03/2021 11:26:22 |
356 forum posts 25 photos | Lol been there done that ( almost) |
Grindstone Cowboy | 11/03/2021 11:42:29 |
1160 forum posts 73 photos | Dave - for future reference, one of these tap-reseating tools might be handy. Of course you don't get a refurbished bathroom, but it's a lot quicker. Rob |
Journeyman | 11/03/2021 11:56:06 |
![]() 1257 forum posts 264 photos | Of course most taps sold today do not have washers but a ceramic disc valve. If it starts to drip you simply replace the cartridge along with a few O-rings John |
Nick Clarke 3 | 11/03/2021 12:01:55 |
![]() 1607 forum posts 69 photos | Posted by SillyOldDuffer on 11/03/2021 10:51:42:
Like changing a tap washer reveals a badly grooved seat so the tap has to be replaced, but it's cemented into the sink, which breaks, forcing that to be changed, revealing the wall behind needs re-tiling and the whole bathroom has to be refurbished... Only when you try to remove the original tiles which in this house (1930s) are the small 3"x6" approx which, while some are cracked and some are missing, nothing short of a tactical nuclear device will shift the rest! |
Nigel Graham 2 | 11/03/2021 12:19:28 |
3293 forum posts 112 photos | Even the professionals don't always have it easy. A friend who is, recounted to me once trying to replace a customer's toilet cistern. His normal, local but major-chain outlet could not oblige - "We don't stock that type, I'm afraid". Pete - "What? There must be thousands of them around Yeovil! " Builders'-Merchant bloke - "I know that, you know that; but Head Office doesn't and says we have to sell those ones" - pointing to a high shelf laden with dusty, cobwebby cisterns. ++++ Don't remind me, Dave... My society used to rent a delightfully ramshackle workshop that had no water supply or drainage (so plastic containers, and luxuriant brambles); but did have a 3-phase supply. One evening I switched on a bench-drill - flash! bang! 3ph fuse blown. By the time the two of us present had replaced the fuse, we'd re-ground a damaged screwdriver on a1ph grinder so we could mend the faulty step-ladder so we could reach the steel conduit so trace and replace the faulty wire... then we locked up and went to the pub. Without drilling the hole. |
Bazyle | 11/03/2021 12:28:57 |
![]() 6956 forum posts 229 photos | Get with the 21st century. The whole sink has to be replaced. If in a vanity unit that too is part of the shrink wrapped replacement part. Count yourself lucky it isn't the newer type of house for which the entire bathroom is the spare part. |
noel shelley | 11/03/2021 12:30:20 |
2308 forum posts 33 photos | Tap with grooved seat if of the washered type you need the monument tap seat cutter, still available ! For the ceramic valve 1/4 turn type By the time you have found the right insert they will have lauched the life boat , just buy a new tap. Noel. |
Dave Halford | 11/03/2021 12:45:12 |
2536 forum posts 24 photos | Posted by noel shelley on 11/03/2021 12:30:20:
Tap with grooved seat if of the washered type you need the monument tap seat cutter, still available ! For the ceramic valve 1/4 turn type By the time you have found the right insert they will have lauched the life boat , just buy a new tap. Noel. Unfortunately that is so true, but does fit with the non siphon toilet flush that leaks after a couple of years - such an improvement over the old fashion lasts 15 years siphon powered by a sheet of plastic. |
Howard Lewis | 11/03/2021 14:35:56 |
7227 forum posts 21 photos | Sometimes, you do wonder in which direction progress is taking us? Years ago, a ferrule carrying an E clip on my wife's car failed. The repair, according to local dealer, was a complete new throttle cable assembly. ("Fits all models, sir" ) It went to the breakers yard with a bolt drilled through, and some steel banding bent to a suitable shape. Bigger profits seems to be the usual objective. But I am a grumpy frugal old man Howard |
Howard Lewis | 11/03/2021 14:51:42 |
7227 forum posts 21 photos | The plastic body for the pop up waste on the kitchen sink cracked. A suitable replacement seemed to be no longer available. But a piece of brass was. After some turning and drilling, a kind friend powder coated it to match the colour of the sink. It may be some time before that fitting fails! Howard |
noel shelley | 11/03/2021 15:58:52 |
2308 forum posts 33 photos | Dave, I have been known to cut a diaphram from a thick piece of polythene, and monument also do a small seat cutter for brass ball valves, Noel. |
SillyOldDuffer | 12/03/2021 21:56:11 |
10668 forum posts 2415 photos | Oh dear, didn't go well. Stuck tight, and cracks rather than unscrews. Left it for the time being... |
