Henry Rancourt | 09/03/2021 23:48:58 |
20 forum posts 47 photos | I’ve spent hours over the last three days looking for tapered roller bearings with tighter than normal tolerances and didn’t find any. Timken and SKF sites list tapered roller bearings with standard and tighter tolerances but I couldn’t find any. So I spoke with their technical support people and was told that, while they list them with tighter tolerances they don’t make them but if someone ordered 1000 they might make them. I’ve also searched many bearing distributor sites, in the US, UK and Japan and even sent emails to a few and got replies that they only have standard class K or class 0 tolerances. Does anyone know where to get tapered roller bearings with tighter tolerances? Thanks, henryr |
bernard towers | 09/03/2021 23:51:49 |
1221 forum posts 161 photos | For what purpose? |
Henry Rancourt | 10/03/2021 00:24:49 |
20 forum posts 47 photos | My Prazi SD300 uses tapered roller bearing for the spindle. |
Niels Abildgaard | 10/03/2021 04:34:07 |
470 forum posts 177 photos | It is my guess that headstock bores for cups and spindle seats for cones are more than ten times more unround than chineese taper rolling bearings. To use Your own time hunting unicorns is OK,but the bearing merchants are there for living. The whole point of tapered roller bearings is to adjust their preload on site. |
Hopper | 10/03/2021 05:46:57 |
![]() 7881 forum posts 397 photos | But tolerance and clearance are two different things. You can adjust clearance as you say but tolerance is the machined finish of the races and rollers and the exact size there of. Sounds like you have to buy the close tolerance bearings from the machine tool supplier who get them made in batches to special order. Hence the hundreds upon hundreds of pounds for Colchester taper roller headstock bearings. You might try some of the quality Japanese suppliers like Koyo and Naachi. Or the German FAG? But, depending what you are doing with your little Prazi lathe, the standard grade bearings will probably do the job. Maybe talk to Ketan at ArcEurotrade. He is pretty up on these small lathes and various bearing upgrades and suppliers.
Edited By Hopper on 10/03/2021 05:48:33 Edited By Hopper on 10/03/2021 05:49:33 |
Ketan Swali | 10/03/2021 06:13:12 |
1481 forum posts 149 photos | Posted by Hopper on 10/03/2021 05:46:57:
You might try some of the quality Japanese suppliers like Koyo and Naachi. Or the German FAG? But, depending what you are doing with your little Prazi lathe, the standard grade bearings will probably do the job. I agree. Ketan @ ARC |
Ady1 | 10/03/2021 09:18:35 |
![]() 6137 forum posts 893 photos | I recall reading that really fine workers always used solid bearings because rollers caused vibration |
Hopper | 10/03/2021 09:23:57 |
![]() 7881 forum posts 397 photos | Posted by Ady1 on 10/03/2021 09:18:35:
I recall reading that really fine workers always used solid bearings because rollers caused vibration Haha. That was a topic of such massive debate in the model engineering world of the 1950s that Mr Timken or one of his top men wrote a letter to the ME magazine explaining why these newfangled tapered roller headstock bearings would not precipitate the violent and shaking end of the world. I believe it is reproduced in the Articles section of this very forum website. |
Michael Gilligan | 10/03/2021 10:06:17 |
![]() 23121 forum posts 1360 photos | Posted by Hopper on 10/03/2021 09:23:57:
I recall reading that really fine workers always used solid bearings because rollers caused vibration Haha. That was a topic of such massive debate in the model engineering world of the 1950s that Mr Timken or one of his top men wrote a letter to the ME magazine explaining why these newfangled tapered roller headstock bearings would not precipitate the violent and shaking end of the world. I believe it is reproduced in the Articles section of this very forum website. . ... in modern parlance an ‘Advertorial’ MichaelG. . Ref: https://www.model-engineer.co.uk/sites/7/documents/on%20use%20of%20timken%20bearings.pdf Edited By Michael Gilligan on 10/03/2021 10:09:01 |
Hopper | 10/03/2021 10:12:24 |
![]() 7881 forum posts 397 photos | No. I think it was a genuine response to an ongoing debate trying to convey the latest technology to the grumpy old gits of pre-internet days. I doubt that Mr Timken cared too much about the model engineer's lathe market when they were selling wheel bearings to every car manufacturer in the world. It was a different world back then. And I think he was right: roller bearing lathes went on to become the norm and generally speaking seem to perform better than the old plain bearing machines. Compare a roller bearing Boxford or other South Bend Clone with an ML7 and you will soon be a believer. Plain bearings are so 1936. |
SillyOldDuffer | 10/03/2021 10:39:20 |
10668 forum posts 2415 photos | Posted by Ady1 on 10/03/2021 09:18:35:
I recall reading that really fine workers always used solid bearings because rollers caused vibration Certainly true in the good old days because it's much harder to make roller bearings than plain bearings. Balls and rollers were especially challenging because roller bearings run rough and wear quickly if only one of them is slightly out. Ball-bearings were popularised by push-bikes because plain bearings exhaust the rider, but early attempts to make them were only moderately successful in that they soon wore and became bumpy. The best early bearings weren't good enough for a lathe - they didn't last long enough before vibration set in. In the lathe 19th and early 20th centuries many companies tried to find ways to mass-produce high-tolerance rolling parts and failed! During WW2 both the UK and Nazi Germany imported top-end bearings from Sweden because SKF was one of the very few makers in the world capable of producing really good rolling bearings. (Better than anything UK, Germany, Japan, France, Italy or the USA could do, even though all these countries were all in the race, ho ho, geddit.) But this was in the long gone world of Trade Secrets, active patents, and semi-understood engineering. 80 years later it's not rocket-science to mass-produce good bearings anywhere in the world. Whilst the best bearings are still premium products, it's because of the extra care, exotic materials, and quality control typical of aerospace and other hi-tech requirements, not because there's any magic in it! Although plain bearings are the easiest and cheapest way of making a precision smooth running lathe spindle there are disadvantages:
As always, horses for courses, but today 'good enough' roller bearings are usually the best bet for most purposes, even lathes! Low maintenance, high-reliability, and standardisation means they're relatively cheap and easy to replace. Probably best not to 'save money' by rushing to nastyRubbish.com and buying the cheapest possible bearing you can find on the market though! Very cheap goods are rarely top-quality... Dave
Edited By SillyOldDuffer on 10/03/2021 11:31:51 |
Michael Gilligan | 10/03/2021 10:43:31 |
![]() 23121 forum posts 1360 photos | I know, Hopper ... but yes, your point is well made As we have seen, Timken is also doing good work in the Wind Turbine business. MichaelG. |
Dave Halford | 10/03/2021 11:40:03 |
2536 forum posts 24 photos | Posted by SillyOldDuffer on 10/03/2021 10:39:20:
Probably best not to 'save money' by rushing to nastyRubbish.com and buying the cheapest possible bearing you can find on the market though! Very cheap goods are rarely top-quality... Dave Edited By SillyOldDuffer on 10/03/2021 11:31:51 I saw a video on Utube yesterday on some of those, 11 thou wobble and made from mild steel, they were crushed in a vice into a pretzel |
not done it yet | 10/03/2021 12:51:44 |
7517 forum posts 20 photos | Remember, tolerance in this discussion is how close fitting the parts will be. Nothing to do with how long those bearings might last. HERE is the link to that excrement bearing video I referenced yesterday.. https://youtu.be/AvF5ETQfm8o |
mgnbuk | 10/03/2021 13:49:17 |
1394 forum posts 103 photos | Remember, tolerance in this discussion is how close fitting the parts will be. I would expect that the "tolerance" described by the OP is more likely the accuracy of the bearing under operating conditions compared to a "standard" bearing - reduced axial and radial runout that would translate directly to improved part accuracy on a lathe. Machine tool accuracy bearings were troublsome and expensive to source several years ago. My previous employment was for a CNC machine tool rebuild company & spindle bearings were replaced during a rebuild. Mostly we had specialist bearing factors searching for them & most were NOS. Timken quoted 2 years delivery on one direct enquiry, which led to the original bearings having to be refurbished rather than replaced (crossed roller bearing for a vertical borer). The races were reground and a new set of rollers manufactured. SOD's assertion that " roller bearings run rough and wear quickly if only one of them is slightly out " was not true in this case - a surface finish issue with the finished machine was eventually traced to the remanufactured rollers not being made to the required dimensional accuracy. The table ran smoothly and quietly, and the total axial displacement was within spec. , but the axial error was not in the same place every rotation of the table. Another set of rollers made to a tighter tolerance fixed the problem - suprising the effect of a "roving" 0.04mm error on a machine with a 1500 mm diameter table ! On one occasion a precision ball thrust bearing just couldn't be obtained, so BSL (as it was at the time) sent us their entire stock of standard grade bearings & I had to unpack each one, clean it, set it up on a surface plate and measure the axial runout. One ended up being only just outside the specification for the precision grade - we used that & returned the rest. Some of the others were only just within spec for the "normal" grade ! I doubt that a Hobbymat's turning performance would be substantially improved by fitting precision grade bearings over standard grade for a reputable maker. Nigel B.
Tony Pratt 1 | 10/03/2021 15:07:16 |
2319 forum posts 13 photos | Posted by not done it yet on 10/03/2021 12:51:44:
Remember, tolerance in this discussion is how close fitting the parts will be. Nothing to do with how long those bearings might last. HERE is the link to that excrement bearing video I referenced yesterday.. https://youtu.be/AvF5ETQfm8o That video was so funny [well I thought it was]. Tony |
Henry Rancourt | 12/03/2021 15:19:49 |
20 forum posts 47 photos | I emailed many distributors, in the US, UK and Japan and Timken, SKF and Nachi technical support, and all told me they only make tapered roller bearings in the lowest tolerance class like 0 or K. It seems there is one company, Gamet, that makes them but cost is around $1000 for one bearing. So i'm considering using angular contact or deep groove ball bearings. My research has started.
HOWARDT | 12/03/2021 15:48:18 |
1081 forum posts 39 photos | A few years back I needed to acquire a number of abec 7 bearings for some spindles that were in the early design stage. Before going too far with the design, which was flexible on size at this stage. I contacted my usual local bearing supplier only to be told that no bearings were available in the particular size I quoted. After ringing round and getting the same answer I contacted SKF themselves, I think they were somewhere like Luton at the time, they were able to tell me that if I placed an order shortly for the forty odd bearings I wanted they would be available as they were going into manufacture in a few weeks. It seems like most things semi specials are produced in batches when a suitable quantity is preordered or likely to be. Only used taper roller bearings on larger spindle designs for milling or slow revolving shafts. Bearing manufacturers used to produce documents showing bearing configurations for different machine tool spindles, they probably still do. Dependant on spindle size and weight capacity you could probably get away with a set of angular contact bearings and roller bearing. |
Raymond Anderson | 12/03/2021 15:51:26 |
![]() 785 forum posts 152 photos | Have you tried Schaeffler or Barden ? both do high precision bearings. will be very spendy though . |
Michael Gilligan | 12/03/2021 15:59:19 |
![]() 23121 forum posts 1360 photos | This may be of general interest: **LINK** https://koyo.jtekt.co.jp/en/support/bearing-knowledge/7-1000.html ... especially as Koyo has a site at Barnsley: **LINK** https://www.koyo.eu/en/plant-company/8-kbe.html MichaelG. |
