Ricky Walker | 10/02/2021 12:57:49 |
27 forum posts 6 photos | Hi, I've started building the small lathe from L C Mason's book, and wondered what sort of motor I should be looking at for driving it? Nothing is mentioned in the book about powering the lathe, that I can find. I have a 12v DC motor and speed controller I got off Ebay, of Chinese origin, for another project, not sure if it is big enough or powerful enough though, I know it revs to 3k rpm, but not sure of the power output. I may try to use that, or see if I can get something a bit bigger. Any help in deciding what motor I should be looking for would be much appreciated! Edited By Ricky Walker on 10/02/2021 12:58:13 |
Emgee | 10/02/2021 13:12:28 |
2610 forum posts 312 photos | Ricky To help get more info please tell us what size the lathe is, what diameter can it turn over the bed and what is the distance between centres fitted to the spindle and tailstock ? Emgee Is this the lathe you are building ? Edited By Emgee on 10/02/2021 13:22:32 |
Michael Gilligan | 10/02/2021 13:19:21 |
![]() 23121 forum posts 1360 photos | Posted by Emgee on 10/02/2021 13:12:28:
Ricky To help get more info please tell us what size the lathe is, what diameter can it turn over the bed and what is the distance between centres fitted to the spindle and tailstock ? Emgee . For preliminary info. ... See the fourth post on this old thread: **LINK** https://www.model-engineer.co.uk/forums/postings.asp?th=56802 MichaelG. |
Trevor Drabble | 10/02/2021 13:23:04 |
![]() 339 forum posts 7 photos | Ricky , Believe the Cowells and small Sieg machines use 125 W - 150 W motors . Hope this helps . Trevor. |
Cornish Jack | 10/02/2021 13:48:08 |
1228 forum posts 172 photos | Still have the part complete bits from an attempted build some 30+ years ago. I intended to use a Parvalux, which, from memory, was around 100 watts. I based it on the Unimat 3, which I still have, but was a bit concerned that the plain bearings might have needed slightly more. I would have thought that Parvalux would still have something suitable in their range. rgds Bill |
IanT | 10/02/2021 14:07:10 |
2147 forum posts 222 photos | Ricky, I have a small lathe (similar to a Super Adept) and used a small fractional HP AC motor that I already possessed for it. If I was looking for a small motor now though, I'd probably fit one of these 200W nominal (it's probably about 150W output) brushed DC motors. I have the same motor (but with the original variable speed control PCB) on my Cowells drill and it works very well. I'm sure it would do so on your small lathe too when combined with the pulleys. You don't really need a very large motor but your (12V DC) one may not be quite enough. Regards, IanT Edited By IanT on 10/02/2021 14:07:39 |
Hollowpoint | 10/02/2021 14:20:27 |
550 forum posts 77 photos | I don't know if you should take my advice because I keep blowing things up lol. ..but there are several routes you could go: If you aren't bothered about reversing the direction of the lathe or controlling the speed then a simple small AC motor would be fine. Something like 100w or more. 230v 1450rpm Another option is a 12v or 24v DC motor with a matching power supply, If you go this route I would try to find something over 150w as you can easily stall the motor at low speeds. The ampage is the thing to watch here. (low volts=high amp) A third option is a 90v or 180v DC motor and a KBIC style DC drive board. Again 100w or more. This would be my preferred option since the drive board compensates for the load by increasing the voltage and you get good torque. Lastly you have the option of a small 3ph motor and a VFD. This is probably the best solution but also the most expensive by a considerable margin. |
Ricky Walker | 10/02/2021 15:51:58 |
27 forum posts 6 photos | Posted by Emgee on 10/02/2021 13:12:28:
Ricky To help get more info please tell us what size the lathe is, what diameter can it turn over the bed and what is the distance between centres fitted to the spindle and tailstock ? Hi EmGee That is indeed the book, I am building my lathe from. The specs for the lathe as designed are: Centre height:1-3/4" Distance between centres: 8" Max swing on faceplate: 4" dia. Max swing over saddle:1-7/8" Dia. I am planning on making a few changes, eg 6mm threads instead of 1/4" Whitworth, and plan on making a set of module 1 change gears instead of 20 DP in the original - I may need to use Module 1.2 or so for the back gears, to get closer to the original 20 DP gears. I still have to work out the gears needed. I'll be making all my own gears, I have a Warco Mini Lathe, and a Clarke CM10 Mill/drill for machining the parts with. Thanks to everyone who has replied so far, you've given me a lot to think about Ricky Is this the lathe you are building ? [edited: image of L C Mason book, "Building a Small Lathe"] Edited By Emgee on 10/02/2021 13:22:32
IanT | 10/02/2021 17:14:02 |
2147 forum posts 222 photos | If you do purchase one of the 200W DC motors Ricky (and have a 3D Printer) I can supply a simple SCAD script to print a suitable 'saddle' for it. Regards, IanT |
Former Member | 10/02/2021 17:34:29 |
1085 forum posts | [This posting has been removed] |
Bazyle | 10/02/2021 18:00:37 |
![]() 6956 forum posts 229 photos | How about an industrial sewing machine motor? Some come with variable speed. A domestic one probably wouldn't be enough. |
Pete. | 10/02/2021 19:07:34 |
![]() 910 forum posts 303 photos | Trevor Drabble, is that boat in your icon the one filmed by Mr Crispin at a model engineering show? Did you build this? Apologies to the op for interruption of his question. I agree with Bazyle, there are some interesting sewing machine motor kits on ebay with motor, speed controller etc. |
Ricky Walker | 11/02/2021 18:14:46 |
27 forum posts 6 photos | Thanks to all who have replied, I have now bookmarked that 200w motor and controller, I should be able to buy it in a week or so. My next decision is as to what size to make the mandrel nose. The original drawings call for a 1/2" BSF thread, but I'm thinking I may go for the Unimat 3 nose size, it depends on what chucks are available at what price. It will be a while before I get that far, so I have plenty of time to look into it Cheers Ricky |
Former Member | 11/02/2021 18:34:45 |
John Baron | 11/02/2021 20:01:58 |
![]() 520 forum posts 194 photos | Hi Ricky, Guys, An excellent source of small induction motors is the scrap yard ! I've salvaged many "Shower Pumps" that have seized up pumps but the motors have all been OK. The hot side pump usually leaks and lime scale build up causes them to seize. Very occasionally water migrates into the bearings, but they are common, cheap and easy to replace. I've salvaged motors from 175 watts (1/4 Hp) right up to 900 watts, (just over 1.2 Hp). All have been two pole motors (2880 rpm). There are some that are universal brush motors, but you don't always find that out until you pull it apart. I tend to take those back to the scrappy after I've salvaged the useful bronze parts.
Colin Heseltine | 11/02/2021 21:02:44 |
744 forum posts 375 photos | John, Which country are you in. Certainly where I live (UK - Midlands) you cannot go into scrapyards and have a ferret around like we used to do 50 years ago. H&S has seen to that. I spent hours climbing into cars stacked two or three high to find bits for cars I was working on. Colin |
John Baron | 13/02/2021 14:27:37 |
![]() 520 forum posts 194 photos | Hi Colin, So do I ! I'm in North Yorkshire. I do have access to s couple of scrapyards around here and I did used to have access to one in Birmingham which unfortunately seems to have closed down and the land is currently being sold. But I do agree that it is becoming harder to find places that will let you wander around them. One that I go to will put stuff on one side for me if I let him know what I'm after. There was an old lathe in there a few days ago. I expect that it went into the cast iron scrap pile.
