It might not be one
Dave Halford | 01/02/2021 14:54:27 |
2536 forum posts 24 photos | |
Brian H | 01/02/2021 15:16:42 |
![]() 2312 forum posts 112 photos | That is VERY worrying! Brian |
Tony Pratt 1 | 01/02/2021 15:24:45 |
2319 forum posts 13 photos | Funnily enough I watched this on YouTube a couple of hours ago, loads of dangerous crap coming from somewhere?? Tony |
Harry Wilkes | 01/02/2021 15:38:49 |
![]() 1613 forum posts 72 photos | We all know the answer don't buy the cr_p in the first place, if it looks like cr-p and it's made you know where then then it is H |
SillyOldDuffer | 01/02/2021 15:43:01 |
10668 forum posts 2415 photos | Posted by Tony Pratt 1 on 01/02/2021 15:24:45:
Funnily enough I watched this on YouTube a couple of hours ago, loads of dangerous crap coming from somewhere?? Tony I wonder where? The item has a CCC Mark, which is a Chinese import requirement roughly equivalent to CE. Someone is making duff electrical goods for export to China...
Jeff Dayman | 01/02/2021 15:54:12 |
2356 forum posts 47 photos | These fakes are dangerous of course, but any electrician installing circuit breakers would surely test them at time of install and verify that they will trip. The fakes wouldn't trip of course, when a fault was simulated. |
Dave Halford | 01/02/2021 15:58:21 |
2536 forum posts 24 photos | Posted by Harry Wilkes on 01/02/2021 15:38:49:
We all know the answer don't buy the cr_p in the first place, if it looks like cr-p and it's made you know where then then it is H But it doesn't look crap does it, externally it looks like all the others, the only difference is it's lighter. |
Jeff Dayman | 01/02/2021 16:03:50 |
2356 forum posts 47 photos | If it doesn't trip under a simulated fault, it's no good, no matter what it looks like or what labeling it has or how light / heavy it is. My point is that the test after install is vital with any circuit breaker. |
Tony Pratt 1 | 01/02/2021 17:04:15 |
2319 forum posts 13 photos | bigclivedotcom does some good videos on dodgy electrical items, worth a look if you have a few minutes. Tony |
Steve Pavey | 01/02/2021 21:27:14 |
369 forum posts 41 photos | Big Clive says in the video that none of the standards tests an electrician would carry out would show this mcb up as a fake, which is a bit worrying. |
Steviegtr | 01/02/2021 21:36:18 |
![]() 2668 forum posts 352 photos | Posted by Steve Pavey on 01/02/2021 21:27:14:
Big Clive says in the video that none of the standards tests an electrician would carry out would show this mcb up as a fake, which is a bit worrying. That is true. If it were a rcd breaker then the rcd test would be done & show a failure. But a say 32a tp mcb would have to be overloaded to make it trip, a test that is not done . Very worrying. Been in the trade all my working life & never seen anything so bad. Someone needs to take on these monsters. Steve. |
Jeff Dayman | 01/02/2021 21:41:22 |
2356 forum posts 47 photos | I am not familiar with post install tests in UK, but if I were an electrician here in North America and I had just installed a circuit breaker I would test it with a simulated overcurrent load, or push its' test button. If either thing didn't trip the breaker, the breaker's no good. These fake ones being just a switch would not trip under overcurrent test. Is this overcurrent trip test / button push not done on UK breakers? |
Emgee | 01/02/2021 23:14:39 |
2610 forum posts 312 photos | Posted by Jeff Dayman on 01/02/2021 21:41:22:
I am not familiar with post install tests in UK, but if I were an electrician here in North America and I had just installed a circuit breaker I would test it with a simulated overcurrent load, or push its' test button. If either thing didn't trip the breaker, the breaker's no good. These fake ones being just a switch would not trip under overcurrent test. Is this overcurrent trip test / button push not done on UK breakers? MCB's don't have any test button and the regulations in the UK do not state any over current or short circuit test shall be conducted. As has been said the source of those switches needs investigating and action taken to prevent such supplies being available anywhere worldwide. Emgee |
Sam Stones | 02/02/2021 00:27:48 |
![]() 922 forum posts 332 photos | If you backtrack through his extensive list of videos, you’ll find that Big Clive has uncovered dozens of faulty products such as this. It’s just one of the things he does, and he does it well. Who should be held responsible? Sam Edited By Sam Stones on 02/02/2021 00:29:02 |
Emgee | 02/02/2021 00:37:54 |
2610 forum posts 312 photos | Posted by Sam Stones on 02/02/2021 00:27:48:
If you backtrack through his extensive list of videos, you’ll find that Big Clive has uncovered dozens of faulty products such as this. It’s just one of the things he does, and he does it well. Who should be held responsible? Sam Edited By Sam Stones on 02/02/2021 00:29:02 All who are involved from ordering through to the sale. Emgee |
Steviegtr | 02/02/2021 01:18:50 |
![]() 2668 forum posts 352 photos | So i guess from the responses on here the outcome is , do not buy anything electrical from China. This will include VFD drive units & anything that could kill you. Stay safe guys & gals . & remember where the covid came from. Chine wants to rule the world. It ain't gonna happen. Steve. |
Pero | 02/02/2021 02:39:26 |
193 forum posts | Easy on the conspiracy theories Steve! Checking on various electrical items from a prestige Australian 'manufacturer' some years ago I found that all were imported from elsewhere - China, Malaysia, Philippines, even Romania. Although I did note that prices had been increased - presumably to take advantage of the cheaper labour costs ( or possibly the mugs who buy the stuff ). I later discovered that it was possible in some cases to buy direct from the factory supplying these items at a fraction of the cost. QC checks confirmed that these were not seconds or otherwise incomplete - just no supplied with the Australian 'manufacturers' label. The point of the above is that buying from the 'local manufacturer' in this day and age is no guarantee that the item will not have been made ( and quite likely well made ) almost anywhere overseas. Basically the same issue with a lot of the engineering tools and equipment purchased with well known brand names. The criminals responsible for the item at the top of the page can pop up anywhere in the world - often financed in one country and made in another -, and likely slip their trash into supply lines in many countries, with third world ones being likely soft targets as they are less likely to be detected. With expanded world trade and the proliferation of products on the market it becomes more and more difficult for electrical safety authorities to maintain checks on all items, let alone detect the deliberately dodgy ones. Pero
PatJ | 02/02/2021 05:21:15 |
![]() 613 forum posts 817 photos | It is common to use what is called a "motor circuit protector" in motor control centers, which is a circuit breaker with the instantaneous function only, and no overload. The overload is not needed with a motor control center, since the starter has overload protection in it. I made the mistake of allowing IEC rated starters on one project many years ago, and the contacts were so tiny and fragile that they started failing not too long after installation. These days (in the US) I specify that all products must be UL listed and labeled, and they must also be NEMA rated. I don't allow anything to be IEC. I do industrial design work, and the equipment must be industrial-rated, else it will not last very long under the harsh conditions that it sees. The things I look for in a breaker are the manufacturer (I generally spec three mainstream manufacturers for electrical equipment, and don't allow any others), UL listing and label (which means it has been tested and verified to perform as designed and intended), and after today I will check the physical weight of any breaker that I personally purchase. As they say "Let the buyer beware". The UL listing process is a very rigorous one, and it tests produces under a wide variety of temperatures, etc. Many electrical products fail for thermal reasons, ie: they overheat due to various reasons, mainly it seems due to connections and contact points not remaining tight. You could make a very inexpensive and dangerous product if you ignore the UL testing, and apparently some do exactly that. But same as buying an auto. Don't buy a Hugo, Pinto, Corvair, etc. unless you are a collector. Remember the old adage "Unsafe at any speed?". . Edited By PatJ on 02/02/2021 05:21:45 Edited By PatJ on 02/02/2021 05:23:58 |
PatJ | 02/02/2021 06:06:08 |
![]() 613 forum posts 817 photos | I guess that product could be a DIN rail mounted "means of disconnect", with no intention of any interrupt rating. I use medium voltage "non-loadbreak" connections often, and it is the same situation, you can disconnect a medium voltage cable, but not under load (they also make load-break-rated medium voltage connections in some sizes). I use low voltage (below 600 VAC) disconnect-only means too, and they are not rated to interrupt load, but rather allow you to turn off the equipment via a start-stop button or similar, and then electrically isolate the equipment from the line connections. You can mount just about anything on a DIN rail, but again, know your product. . |
SillyOldDuffer | 02/02/2021 11:26:55 |
10668 forum posts 2415 photos | Posted by Steviegtr on 02/02/2021 01:18:50:
So i guess from the responses on here the outcome is , do not buy anything electrical from China. This will include VFD drive units & anything that could kill you. Stay safe guys & gals . & remember where the covid came from. Chine wants to rule the world. It ain't gonna happen. Steve. If only life were so simple!
A better test is the percentage of duff electrical products we can identify in our homes and workshops. It's well known that there are bad 13A plugs on the market. I checked 89 plugs in my house (not all plugged in at the same time) and found zero fakes. I have got 4 old-style 13A plugs with plain L & N pins. My survey doesn't prove there are no fake plugs, but it does suggest they're not common. Of course the chance of getting a punk product is higher if it's bought cheap from an unreliable source, or if you set up a website to expose them and people send in examples! Being sold rubbish has always been a problem and always will be. Caveat Emptor has been good advice for over 2000 years... Dave Edited By SillyOldDuffer on 02/02/2021 11:28:25 |
