Speedy Builder5 | 07/01/2021 18:39:36 |
2878 forum posts 248 photos | When I first purchased a MIg in 1998, MIG gas for steel was CO2. Now it is Argon 80% CO2 20%. Is this to limit CO2 emissions, or to improve weld joint? Bob |
DC31k | 07/01/2021 19:18:45 |
1186 forum posts 11 photos | https://www.mig-welding.co.uk/welding-gas.htm |
Speedy Builder5 | 07/01/2021 19:43:47 |
2878 forum posts 248 photos | That is an interesting read. Thanks DC31k Bob |
fizzy | 07/01/2021 20:07:21 |
![]() 1860 forum posts 121 photos | If youve ever tried welding with pure CO2 them moved to the mixed gas the difference is massive. CO2 is a horrid gas to weld with. |
Nicholas Farr | 07/01/2021 20:39:14 |
![]() 3988 forum posts 1799 photos | Posted by fizzy on 07/01/2021 20:07:21:
If youve ever tried welding with pure CO2 them moved to the mixed gas the difference is massive. CO2 is a horrid gas to weld with. +1 Regards Nick. |
John Reese | 07/01/2021 21:12:25 |
![]() 1071 forum posts | The CO2 used in welding or for carbonating your beer is extracted from the air so from that standpoint it is neutral. The energy requires to extract CO2 from the air is not carbon neutral. As others have said the welding characteristics of the argon blend are much better than straight CO2. |
peak4 | 07/01/2021 22:36:34 |
![]() 2207 forum posts 210 photos | Posted by John Reese on 07/01/2021 21:12:25:
The CO2 used in welding or for carbonating your beer is extracted from the air so from that standpoint it is neutral. The energy requires to extract CO2 from the air is not carbon neutral. As others have said the welding characteristics of the argon blend are much better than straight CO2. Completely off at a tangent (almost) there was quite a good film about Bulmers cider making on over the Christmas holiday. Bill |
not done it yet | 07/01/2021 22:53:53 |
7517 forum posts 20 photos | They liquify air to get the Argon. Argon is about 1% of the atmosphere, so it takes a lot of energy to get that 1%. Of course, they will also be separating the other gases, too, so not all that energy use is attributable to Argon production.🙂 |
Dave Halford | 08/01/2021 10:01:59 |
2536 forum posts 24 photos | The down side is that your gas costs double, also note that 3 x 600g disposable bottles pays for a 10lb co2 refillable after which your gas costs are 600g disposable = 10lb refill. I personally found welding cars much easier after changing from a Cebora/Snap-on 130 to a 170 commercial mig with a copper choke. |
Nick Wheeler | 08/01/2021 10:32:17 |
1227 forum posts 101 photos | Posted by Speedy Builder5 on 07/01/2021 18:39:36:
When I first purchased a MIg in 1998, MIG gas for steel was CO2. Now it is Argon 80% CO2 20%. Is this to limit CO2 emissions, or to improve weld joint? I bought my first MIG in 1990, and CO2/Argon mix was recommended then. I used CO2 because I worked in a bar and got it and a regulator for nothing. Then I used friend's machine with Argoshield, and rented a cylinder on the way home. I was repairing rusty cars. And it's 5% argon unless you're welding really thick steel.
CO2 is one of the waste products of brewing, and brewers struggle to get rid of it Edited By Nicholas Wheeler 1 on 08/01/2021 10:34:59 |
