BOB BLACKSHAW | 07/12/2020 09:18:59 |
501 forum posts 132 photos | Hello, I have made the engine and near finishing the boiler for the tug boat I am making. I am to start on the hull but would like a formula to see if it will float at the correct line after all the parts are installed. The problem is that I am making the hull out of 16g copper cut into strips and soldering up to 18g steel formers. I have a 1/2 sheet of copper that will never be used and it will be easy to work around the shapes needed. But I worried that after making it with all the parts in will it be to low in the water, is there a formula that can be used to determine this problem .Hull size is 30 inches x 7.6 inches, or will it be to heavy and sink Thanks Bob |
Ramon Wilson | 07/12/2020 09:44:26 |
![]() 1655 forum posts 617 photos | Bob I don't know the formula but if I have my Archimedes principle right the total weight of the boat should not exceed the weight of the volume of water it displaces at the correct waterline. If you can work out that volume and convert to weight of fresh water that should tell you the total weight you can accept. A boat hull made from tinplate has been done many times but 16swg copper is obviously much heavier - given the size of hull I would not have thought this is a viable material to make a hull from. Conversely the lighter the hull can be made the more weight you can fit in it - important when using a boiler and steam plant.
Regards - Tug |
Bazyle | 07/12/2020 09:56:22 |
![]() 6956 forum posts 229 photos | Be very careful about making it top heavy aswell. For an idea of the weight have a look at other similar disgns (type/length) especially kits doing a search on the Model Boat and Mayhem forums and you will probably find some reference to the wieght. There used to be a beautiful tug sailed on the lakein St Albans of a design I haven't found on the web. The key point being that is was a small harour tug with a fully exposed engine - hence able to show off the scale fittins. The point being it was made with teh copper from a scrapped hot water copper cylinder. Not sure how thick that would be - especially as it was scrap due to corrosion. |
Rod Renshaw | 07/12/2020 09:57:21 |
438 forum posts 2 photos | +! for Tug''s approach. and I agree with Tug's gut feeling that this hull is likely to be too heavy to float, especially if it is to have a steam engine and boiler. We don't have anything like enough information to calculate this in any scientific way, some boat hulls are much finer than others. Something box- like and deep ( like a barge) will have much more internal volume than a hull with a rounded shape and shallow draft , even though they have the same length and beam. Naval architecture is as much an art as a science and even the professionals get it wrong sometimes. Best to keep the weight to the absolute minimum, you can always add ballast, but not easy to take it away. Sorry to have doubts about this. Rod Edited By Rod Renshaw on 07/12/2020 10:09:14 |
Ramon Wilson | 07/12/2020 10:47:03 |
![]() 1655 forum posts 617 photos | Without the correct formula(s) (and the knowledge) the only way is to take a calculated guess at it Bobs model is 30 OAL x 7.6 beam so if the draft is say 3 inches thats 684 cu ins. Obviously thats more than the hull due to its shape and curvatuures but lets say its displacement is around 75% of that - 513 cu ins. 1 cu in of freshwater weighs .036 lbs so thats 18.46 lbs of displacement. I built the model Wide a Wake some time back. It's a 52" hull at 14 1/2" beam with a good sized volume of displacement. As built mainly in parana pine the hull is quite light for it's size. I don't know how much it weighs in total but once on the water with the boiler and feed tanks full etc but no extra ballast it sat a bit more below the anticipated water line than expected. Regards - Tug
Andy_G | 07/12/2020 11:26:41 |
![]() 260 forum posts | Look up ‘prismatic coefficient’ and ‘block coefficient’ - they won’t give you the answer, but should help estimating displacement. From a quick look, tug hulls typically have a block coefficient of 0.6, so will displace 60% of the theoretical length x beam x draught volume.
Ramon Wilson | 07/12/2020 11:50:49 |
![]() 1655 forum posts 617 photos | Thanks Andy - that's useful to know. That makes Bob's potential hull displacement 410.4 cu ins = 14.77 lbs. With due respect Bob I think you are going to have to try a different material. Incidentally you may be interested in a series of articles in ME quite some time ago by a 'Don Gordon'. He set out to build a ship and plant as scale as possible. I think he used brass shim for the hull. Don was a member of the Norwich society so often got to see his microscopic attention to detail. I have no idea when they were featured but they may be worth searching out.
Regards - Tug
Journeyman | 07/12/2020 11:59:05 |
![]() 1257 forum posts 264 photos | Posted by BOB BLACKSHAW on 07/12/2020 09:18:59:
... is there a formula that can be used to determine this problem .Hull size is 30 inches x 7.6 inches, or will it be to heavy and sink There certainly is a formula, actually quite few. You could start with Simpson's Rules and it gets more complicated from thereon. I am afraid it is about 55years since I briefly studied Naval Architecture and all I remember was that it involved and awful lot of calculation (then with a slide rule). I think I would probably go with Ramon's method. John |
Rod Renshaw | 07/12/2020 12:05:40 |
438 forum posts 2 photos | Don (DG) Gordon, ME 1975 -76, Vol 141-142, also 1980 Vol 146 and 1981 Vol 147.mostly articles on boilers and machinery for model steamships and paddle steamers. He does emphasise the need to keep the weight down. Rod |
JasonB | 07/12/2020 12:08:28 |
![]() 25215 forum posts 3105 photos 1 articles | If you are handy with CAD it should be possible to draw out the various hull profiles from the plan (can be traced in) at their correct spacing then loft through them all to get a 3D hull. Slice off the part above the waterline then let CAD work out the volume of what remains. Failing that work out the rough area of each rib below waterline and multiply by distance to the next one and add them all up. Not had my hands on a fibre glass hull but would think they come out about a 1.5 - 2mm thick and are popular for tug boats. So with copper being 3-4 times denser that GF you may be sitting a bit low in the water unless these hulls are balasted? Edited By JasonB on 07/12/2020 12:24:00 |
Ramon Wilson | 07/12/2020 12:47:16 |
![]() 1655 forum posts 617 photos | Thanks Rod - I remember his work as being perhaps a bit too unrealistic for a working model but you couldn't fault his approach nor workmanship. CAD would be a very useful tool Jason as would the readily available software specific for this purpose but unless one is seeking perfect performance from the hull not really necessary in this kind of situation A fibre glass hull for a 'tug' of which there are many available would be far more suitable but may not need ballast depending on the size. The 'Cruiser' hull I referred to in Bobs previous thread was fitted with electric motors but despite having two fair sized 12 volt batteries did require a fair amount of sheet lead ballast. This was chopped into very small pieces and set in epoxy to get the weight as low as possible - Bazyle hit the nail on the head here - top hamper is not desirable at any time. BOB - Here are two pictures that help show the difference of weight to a waterline. This was taken for the ME mag just after the WaW was finished but before the 'official launch'. It has some water in the boiler but not at working level and the water tanks are empty.
This however was taken on the day of launching proper but with the boiler and water tanks full. You can see the difference that made on the waterline. There is no ballast in this vessel. Sorry to rain on your parade but hope that's of more use
Regards - Tug |
Martin Kyte | 07/12/2020 13:25:18 |
![]() 3445 forum posts 62 photos | If you had something to use as a test tank you could rough out a hull from wood and test the displacement. You would also then have a test model to play around with to increase or decrease the displacement. Simple tank with an overflow to catch displaced water, then either weigh the water or measure the volume. It could be done in CAD but if you don't hve the software, the old methods still work. regards Martin |
Former Member | 07/12/2020 13:41:33 |
1085 forum posts | [This posting has been removed] |
Keith Long | 07/12/2020 13:54:15 |
883 forum posts 11 photos | Bob if the tug that you are building is a scale model of a full size actual tug, look up the displacement of the full size vessel (internet search) and divide by the cube of the scale factor that you are building to, that will give you the weight that your model needs to be to float at the design waterline. If your model comes out lighter than that figure then you'll want ballast, if heavier then you might be better trying to loose some of the weight before you go too far. If the model is only slightly heavier than the "scale design" figure then don't worry too much, tugs can benefit from sitting a bit deeper to make sure that the propeller has enough water to "bite" on. Too much weight and then you're building a submarine! |
Buffer | 07/12/2020 14:25:06 |
430 forum posts 171 photos | I started out training as a naval architect and I can tell you that you will need an awful lot of work to try and work that out. Far more than I could tell you on this by typing. Simpson rule is one way of doing it having measured the areas of all the frames. Personally I would not even try to do it but ballast it afterwards to get it to float level where you want it.
BOB BLACKSHAW | 07/12/2020 15:47:20 |
501 forum posts 132 photos | Thanks for the replies on this,it seems that a lot more thought is needed as a lot of work could be wasted. Tug .the steam launch looks fantastic, a question when you planked the hull did you rebate the edge for the next plank to fit on. I have no wood working skills so that why I was looking at a metal hull. Bob |
SillyOldDuffer | 07/12/2020 16:15:24 |
10668 forum posts 2415 photos | Posted by Buffer on 07/12/2020 14:25:06:
Bob's concern is that it might not float at all! What's needed is:
The boat will float provided the volume of water displaced by the hull weighs more than the boat. As calculating the volume of a curved hull is hard work, I suggest estimating the volume by comparing it roughly to the size of a thin walled plastic kitchen jug, which is about 500ml. Imagine the empty hull. how many jugs could be squeezed in to the space? Assuming the boat was box shaped: 30" x 7.6" x 6" is 0.762m x 0.193m x 0.147m which is 0,0216 cubic metres. As 1 cubic metre of water weighs 1000kg, the box shaped boat would support a maximum weight of 21.6kg (47.6lbs) That's the maximum possible, and as a sanity check the jug estimate should be less than that. Assuming the boat was triangular in cross-section, deck 7.6", with keel 6" below, and 30" long, then 0.0144sqm x 0.762m = 0.011 cubic metres, which is a maximum weight of 10.9kg As your real boat has pointy ends, and probably has a full bellied mid-section, I guess it's displacement will be roughly between the two, say 16kg (35lbs) with no freeboard. Reducing weight by 25% suggests the maximum weight of the vessel should be less than 12kg (26lbs) Jug guessing should produce a better estimate. Re Copper vs Fibreglass, it's the weight that matters, not the density. Although Copper is denser than Fibreglass, you would likely use less of it because the hull could can be made thinner. Being used to wood, many people found it difficult to accept Iron ships could float. Actually, they floated better than wooden ships because iron is stronger, and much less of it was needed to make a satisfactory hull. Mild-steel is even better, and warships often used high-tensile steels to save weight, allowing more armour or higher speeds. Can you guestimate how much copper sheet will be used and weigh it. Copper's not a problem provided it's well within the overall weight limit. The easiest way to get an accurate result is to CAD model the hull because the computer calculates volumes and areas as an aside. Another way is to create the impression of the hull in clay and fill it to the desired safe water line with water. Each litre amounts to 1kg of weight. Next issue is stability. To avoid capsizing, heavy weights like the engine, boiler and batteries etch should all be blow the waterline. Everything above the waterline, like the bridge, funnel & masts should be kept light. Shouldn't be difficult because that's how the original was built. Full size shipwrights have to go an extra step. It's undesirable for all the weight in a ship to be too low because it results in violent rolling and everyone gets sick! By lifting the weight the ship becomes stiffer and rolls less. But not too high, because it risks capsize. Difference between the centre of gravity and the centre of buoyancy. Look up metacentric height if it's of interest. Probably doesn't matter how much a model rolls, and maybe the original had all the weight low down. Tug boats weren't built for crew comfort! Hope the sums are right - don't forget I'm terrible at maths... Dave |
BOB BLACKSHAW | 07/12/2020 17:55:30 |
501 forum posts 132 photos | Thanks Dave for your interest , I shall weigh the amount the hull will weigh in the morning including engine and boiler water etc, I'm finding this interesting Bob |
Ramon Wilson | 07/12/2020 18:55:59 |
![]() 1655 forum posts 617 photos | Well I'm pleased to see you confirm my thinking on displacement in some way Dave 16 swg copper is what Bob intended to use - compare that to 1/16 balsa or even plywood strip of the same section and the weight difference is substantial. 'Build' two identical hulls one using copper and one using balsa - they will both displace the same if the total weight is equal but the balsa one can have far more weight added to bring down to the same water line as the copper one. What weighs more - a ton of lead or a ton of feathers - springs to mind. The lighter the hull is made the more it can be loaded for a given displacement /waterline. Bob, I put the two pics up for nothing more than to show the difference a slight increase in weight can create to a waterline. The model was serialised in ME and also a full build log was on MEM here which describes all the wood processes. Though you obviously have a desire to make it yourself, personally, if I were you, I would look into obtaining a fibre glass hull and fitting that out with your steam plant. You will still have an awful lot of very enjoyable work to do to accomplish that.
Regards - Tug |
SillyOldDuffer | 07/12/2020 21:12:35 |
10668 forum posts 2415 photos | Posted by Ramon Wilson on 07/12/2020 18:55:59:
Well I'm pleased to see you confirm my thinking on displacement in some way Dave 16 swg copper is what Bob intended to use - compare that to 1/16 balsa or even plywood strip of the same section and the weight difference is substantial. 'Build' two identical hulls one using copper and one using balsa - they will both displace the same if the total weight is equal but the balsa one can have far more weight added to bring down to the same water line as the copper one. What weighs more - a ton of lead or a ton of feathers - springs to mind. ...Regards - Tug We're in violent agreement Tug! Of course you're right, ¹⁄₁₆" balsa is lighter than 16swg copper. But the copper is stronger, potentially making it possible to reduce frames, keel and machinery supports. I'll do the sums later - weight of a 16swg copper box will indicate if it's a big problem or not. Ought to say I've never built a model boat and have no idea how practical it is to work copper into a hull shape. I guess it's more skilled than balsa or fibreglass. Over to the experts for practical boat building! Dave
