Drilling then Tapping in Drill Press
Iain Marshall 104/12/2020 23:13:34
11 forum posts
Guys,
Just getting started with metalworking.
I have a bench drill,vice, some taps / dies etc.
Drilled a nice perpendicular hole in some Alu bar, tapping size for M4. So far so good.
Installed the spring loaded tapping guide into chuck for tapping hole with handle & M4 tap.
Problem is I now have to drop the table down as the setup is too long.
This means I have to mess about having to centre on the hole again.
Any tips for this situation?
I did manage to tap the hole successfully, M4 bolt fitted well, but would like to find a better process.
Thanks
Iain
Simon Williams 304/12/2020 23:51:24
728 forum posts
90 photos
A common, and annoying, situation.
Several ideas for work-rounds.
Ditch the tap guide, clamp the tap in the drill chuck and turn that. The chuck key make a nice tommy bar.
Ditch the tap guide, clamp the tap in the drill chuck and tap under power. (Not without its perils!!!!!)
Ditch the tap guide, don't clamp the tap in the chuck, just hold it loosely so it is held upright. Grind a square on the shank of the tap and fit your tap wrench to the middle of the tap not the usual square on the top end. You need three hands or a quill lock to make this work!
If your drill press has a morse taper, ditch the drill chuck, and hold the tap guide in a morse taper collet held in the spindle. This needs the quill of the spindle to be drilled lengthways as per a vertical milling machine so you can close the collet.
For a drill press without a hollow spindle, make a tap guide on a morse taper. As far as I know there isn't such a thing available commercially, but it's a nice little project.
Attacking the problem from the other end, so to speak, invest in the requisite sizes of long drills so as to make the set-up for drilling the holes equivalent length to the later tap plus guide set-up.
Buy a vertical mill with a dovetail column. This isn't quite as radical as it sounds, it's an entirely logical progression in developing the capability of your workshop. No my wife didn't accept this logic either.
I expect there are other ideas will be along shortly.
Bst rgds Simon
Andrew Johnston05/12/2020 00:06:23
7061 forum posts
719 photos
If it's not worth setting up a tapping head then I use two methods. One, just put the tap in the drill chuck and make a few turns by hand to start the tap. As a first choice I tend to use spiral flute taps so a few turns gives a couple of turns of a full thread. After that finish the thread by hand away from the machine. Two, just tap the whole thread by hand away from the machine. For free hand tapping I tend to use normal taper taps as they are easier to start nearer the vertical than spiral flute taps. After a turn or so I'll check that the tap is perpendicular to the surface from two directions and then continue turning. To some extent the tap is self-aligning when tapping by hand.
Hopper05/12/2020 00:50:30
7881 forum posts
397 photos
To help with Andrew's method, you can make a tapping guide by drilling a hole the same diameter as the tap in a piece of thick metal and lay that on top of the job to guide the tap.
Or in the drill press toss the spring loaded guide and use a short point held in the chuck. If you don't have a lathe you can make a point by spinning a piece of round bar in the drill and using a file on it.
JasonB05/12/2020 06:59:02
As said in the tapping guide thread I don't use the sprung ones and this is one reason why, the simple bit of rod with a point one end and tapered hole the other is a lot shorter. Few stub drills also help but more so in the larger sizes rather than 3.3mm. Wrench on the shank of the tap also acts as a slipper clutch so less chance of tap damage
not done it yet05/12/2020 07:05:12
7517 forum posts
20 photos
Bearing in mind that drills have bearings which are designed to resist axial loads, not radial ones. Depends on the quality of the drill, of course, but many a drill has been reduced in accuracy simply by using a small wire brush and using the drill like an angle grinder. As it is only for alignment, a short filed wire nail is likely a good enough item for the purpose.
Michael Gilligan05/12/2020 08:59:05
23121 forum posts
1360 photos
Posted by not done it yet on 05/12/2020 07:05:12:
Interesting concept ^^^
only’ is not a word that I would normally expect to use in connection with alignment.
larry phelan 105/12/2020 10:04:18
1346 forum posts
15 photos
Agree with Hopper, this is the method I use all the time. Not worth the bother of setting up gimmiics unless there is much tapping to be done. I bought a tapping head years ago for a job that required hundreds of holes, worked fine but I have seldom used it since.
It,s now one of those things which will "come in handy some day "
Anyone else got things like that ?cheeky
Michael Gilligan05/12/2020 10:35:52
23121 forum posts
1360 photos
Iain
Before it gets lost in the wider discussion ...
May I just give you kudos for approaching this exercise so sensibly.
MichaelG. yes
Ian P05/12/2020 10:36:53
2747 forum posts
123 photos
As others have said ditch the spring loaded widget and use the chuck.
I am fortunate in having a VFD on my Fobco. I set it up so the lowest frequency is 4Hz at which speed it has little torque but I use it for tapping (with the tap in the chuck) from M2 upwards. (I have fingertip reverse switch) I frequently tap scores of 1/4" and 3/8" UNC in 10mm ali plates not clamped down so it aligns itself to the tap.
Ian P
Hopper05/12/2020 10:51:18
7881 forum posts
397 photos
Actually, most modern drills, especially the cheap Chinese junk that is almost universal today, use standard ball bearings that in reality stand up better to radial loads than they do axial. The old quality drill presses used roller thrust bearings as well to take the axial loads. Not common any more. And still not harmed by radial loads anyway.
So file away and wire brush away without fear.
Dave S05/12/2020 21:51:48
433 forum posts
95 photos
There is no need for a spring loaded tapping centre. The quill moves.
Bung a pointy or female centre in the chuck to guide the “free” end of the tap
for M4 you can turn the tap with one hand whilst pulling the quill down to support the back of the quill.
I regularly tap down to M1.6 using this technique.
For M5 and up (M4 if you are careful) a cordless drill makes a good tapping head.
Because it is doing the turning you can use both hands to make sure it’s guided square.
Iain Marshall 105/12/2020 22:09:54
11 forum posts
Thanks for all the helpful replies, I'm very grateful.
I like the idea of putting the tap in the chuck and turning by hand, possibly with the rod out of the tapping guide as well, as suggested by Jason & Hopper. thumbs up
A few good ideas suggested. I will try them out & report back.
I hope to get a mini mill at some point, don't know if that will solve the headroom problem though. My drill press is a old Draper one my Dad had.
Iain
Howard Lewis06/12/2020 15:56:22
7227 forum posts
21 photos
The two essentials are:
1 ) Keeping the Tap square to the work
2 ) Not subjecting the Tap to bending. Taps may be strong in torsion, but definitely not in bending!
So use a Male / Female Tap Guide in the chuck, and rotate by hand, preferably with a Tap Wrench, or grip in the chuck, and by pull the spindle round by hand, following down with the feed handle.
The only time that I tap under power is with a spiral flute tap.
not done it yet06/12/2020 20:27:33
7517 forum posts
20 photos
Howard is spot on with that one. If only the very minimum of threads in the workpiece one may get away with it but as the tap will be aligned by the first couple of threads cut (after which it will continue in that same direction) deeper threads will be successively cutting more on one side of the hole than the other, if initially mis-aligned
The tap will eventually break, or jam, unless it manages to emerge from the hole before breaking, but leaving a mis-aligned threaded hole for the subsequent fixing.  Taps are for cutting threads, not drilling🙂 .
Edited By not done it yet on 06/12/2020 20:32:44
Iain Marshall 106/12/2020 20:43:29
11 forum posts
NDIY,
Keeping the drill & tap square to the work was my primary objective in this exercise.
I succeeded, despite some faff with having to adjust table height.
I'm a bit confused though about the need, or otherwise, of keeping the vice secured to the table.
Iain.
Nicholas Farr06/12/2020 21:21:52
3988 forum posts
1799 photos
Hi, although you should keep the tap square, they will tolerate a little out of squareness, but may be a pain getting studs/bolts in without faffing about with corresponding holes.
Regards Nick.
Michael Gilligan06/12/2020 21:47:43
23121 forum posts
1360 photos
Posted by Iain Marshall 1 on 06/12/2020 20:43:29:
The vice [or whatever] should be secured to the table when drilling ... This is for safety.
[ exceptions ‘prove the rule’ but let’s not go there ]
With the machine un-powered, it’s entirely optional and, in the present example, probably depends upon how likely you are to accidentally nudge the vice and break the tap.
Vic07/12/2020 00:18:09
3453 forum posts
23 photos
I do nearly all of my drilling and tapping on the milling machine using a spring loaded tapping guide most of the time. Of course it’s easy to raise and lower the table to suit without losing registration. Sometimes if Z height is tight I use a small dowel with a point on the end instead as a guide.
Hopper07/12/2020 01:06:04
7881 forum posts
397 photos
When I use the aforementioned short point for tapping in the drill press, I put a bungee cord on one handle of the drill press to pull the quill downwards so two hands can be used for tapping.
And I have the vice bolted down securely so the the hole does not move out of line with the drill spindle. It all stays nice and straight.
As Michael said, bolted down vice is essential at all times when drilling, for safety. Even a 2mm drill bit can grab into the job and fling a loose vice across the workshop, with disastrous results for whatever gets in its way, whether the family jewels or the freshly chromed petrol tank of your restored Brough Superior.
To get around the clumsiness of drilling small holes in precise locations etc the vice can be loosely bolted to the drill table so it can be moved around into the desired position by hand but if the drill grabs, the bolts will prevent take-off.
