Dr_GMJN | 03/11/2020 21:46:55 |
![]() 1602 forum posts | All, I've just been doing a light re-furb on the ML7. I've eliminated most of the wear on the slides, converted to "wide guide", and the saddle is now adjusted to move freely along the entire length. I've also replaced the saddle and cross-slide gibs, and fitted the Arc needle bearing sets to the cross and top slides, both of which now work very smoothly with no apparent play (at least when moved by hand). The only test I've done so far is running a finger gauge across a faceplate, using the cross slide. I'm getting about 0.0005" reading from O/D to centre, which reduces to something negligible over the kinds of diameters I'm working on. I'll do the bed twist check using the dumbell machining test on a 1" diameter x 4" long bar next. The bed was levelled previously using using a DTI against a bar in the chuck and tightenting down while getting zero movement. I put two centres in the spindle and tailstock, and brought them together with some 0.005" shim material between them, and it didn't move significantly, I then tried attaching a finger gauge to a magnetic base on the faceplate, with the lever positioned on the inside of the tailstock taper; I'm getting about a 0.010" runout there when the faceplate is turned. Does this indicate that the tailstock needs adjusting - if so, what's the best method? Any other checks/adjustments I could do? Thanks all. |
Hopper | 03/11/2020 23:16:27 |
![]() 7881 forum posts 397 photos | Try again with a steel ruler. Shim might be too flexible. Best way to set tailstock is by turning a test piece between centres and measuring for taper over a 4 to 6 inch length. With wear on the inner vertical bed surfaces you can get variation in different positions though. So for critical long jobs check for taper before getting close to final cut and adjust to suit. Dial indicator readings can suffer from flex in the mounting and stand when rotated so turning test is more definitive. |
Pete Rimmer | 03/11/2020 23:34:25 |
1486 forum posts 105 photos | Posted by Dr_GMJN on 03/11/2020 21:46:55:
I then tried attaching a finger gauge to a magnetic base on the faceplate, with the lever positioned on the inside of the tailstock taper; I'm getting about a 0.010" runout there when the faceplate is turned. Does this indicate that the tailstock needs adjusting - if so, what's the best method? This is a poor method of testing. The self-weight of the assembly will cause the reading to change as you turn the faceplate. 10 thou is about the expected amount of sag so your tailstock could well be spot on but the dial moves because it's the stem of the DTI stand that's bending. |
Dr_GMJN | 04/11/2020 07:07:22 |
![]() 1602 forum posts | Thanks both. |
Dr_GMJN | 07/11/2020 18:10:24 |
![]() 1602 forum posts | All, When looking through some previous forum posts, I found and saved a check sheet from a Boxford lathe that someone posted a while ago. I apologise to whoever posted it because I can't find the thread now. Anyway, I've done some further checks on my ML7 with a Myford test bar, based on the sheet, and the results are in purple ink: |
Oldiron | 07/11/2020 18:23:49 |
1193 forum posts 59 photos | Ok now you are ready to start some small projects and see how things go. Many great pieces have been made on lathes much worse than yours. Maybe revisit the Morse taper if it proves to be a problem. Do not try for perfection you will be running round in circles forever. regards |
Dave Halford | 07/11/2020 19:40:00 |
2536 forum posts 24 photos | Your results don't say +ve or -ve for 7 &11, could be nose up or down. Does holding a bar in the 3 jaw (a newish one) give a similar result |
Dr_GMJN | 07/11/2020 21:48:41 |
![]() 1602 forum posts | Posted by Dave Halford on 07/11/2020 19:40:00:
I’m assuming #9, #10, #11 & #12 mean move the dial gauge with the saddle along the item - the previous tests indicate the required movement with arrows. I’ve only got a very old 3 jaw chuck. Thanks. |
Dr_GMJN | 07/11/2020 21:53:28 |
![]() 1602 forum posts | Posted by Oldiron on 07/11/2020 18:23:49:
Thanks, Actually I just completed my first M.E. Project, and obviously I‘ve learned a lot about practical use of the lathe and mill. I wanted to take the opportunity before my second project to get my equipment the best I can get it. The ML7 is old, and obviously a bit worn. I’ve corrected the most annoying thing (bed wear), and am now trying to establish where I am with it, and adjusting it to be as smooth as possible while retaining accuracy.
Dave Halford | 08/11/2020 15:20:53 |
2536 forum posts 24 photos | Posted by Dr_GMJN on 07/11/2020 21:48:41:
I’m assuming #9, #10, #11 & #12 mean move the dial gauge with the saddle along the item - the previous tests indicate the required movement with arrows. I’ve only got a very old 3 jaw chuck. Thanks. As a double check does trapping a 12" rule vertically between the two centres give a lean toward the tailstock? Then try machining a point on scrap rod sticking out as much as you can in the three jaw and try the test again. |
Howard Lewis | 08/11/2020 17:03:04 |
7227 forum posts 21 photos | With regard to the Faceplate, IF absolute accuracy bis essential for the job in hand, it can be skimmed to clean up all the way across. It should be satisfactory for subsequent jobs, assuming that the Faceplate locates in exactly the same place again (Depends on the accuracy on the fit between the Faceplate register and that on the Mandrel, and the torque applied to the Faceplate when fitting. After that you are into micron chasing territory. Bear in mind that commercially produced parts are machined to be within a tolerance, so may not all be exactly the same, but sufficiently accurate for one part to be able to replace another without making the assembly unfit for purpose. Exceptionjs to this are lapped fits, such as Fuel Injection Pump Plungers and their Rotors, or Injector Needles and Bodies. But here, we are dealing with pressures of upto 1500 bar, and the need to minimise leakage of a low viscosity fluid. Horses for Courses! (Especially if you are doing sub contract work for NASA! ) Howard |
Dr_GMJN | 08/11/2020 17:31:44 |
![]() 1602 forum posts | Dave, the 12” ruler test doesn’t deflect either way. I don’t want to tighten it too much, or else I could damage the points. Howard, Unfortunately the faceplate cross-face test consistently gives 0.0005” error - convex. But this is over the full 3.5” radius. I’m only dealing with things at the most a couple of inches in diameter for facing in the lathe - this equates to about 0.00014” or 3.5 microns of dome, so I doubt it’s worth trying to correct for a model steam engine. Are you suggesting I skim the faceplates on the lathe? If so I suppose I’d be making them domed too? I think I mentioned that was was like a farmers welly, the other fairly good. Thanks both. |
Dave Halford | 08/11/2020 18:13:48 |
2536 forum posts 24 photos | You rmeasurements show 15 thou slope in both 1 and 7, you can see that with the naked eye if you put the points together, the rule should make that even more obvious. It doesn't take much pressure (like you would finger tighten a nut) and the points are harder than the rule. If there really is no movement in the rule then that 15thou is a lie so look to the other end, what you mounted the dial gauge on must be dropping. |
Dr_GMJN | 08/11/2020 19:47:30 |
![]() 1602 forum posts | Posted by Dave Halford on 08/11/2020 18:13:48:
You rmeasurements show 15 thou slope in both 1 and 7, you can see that with the naked eye if you put the points together, the rule should make that even more obvious. It doesn't take much pressure (like you would finger tighten a nut) and the points are harder than the rule. If there really is no movement in the rule then that 15thou is a lie so look to the other end, what you mounted the dial gauge on must be dropping. Dave, All, |
Hopper | 08/11/2020 22:55:23 |
![]() 7881 forum posts 397 photos | Nothing at all to worry about. See my post on the other thread on alignment you posted on. |
Dr_GMJN | 08/11/2020 23:05:06 |
![]() 1602 forum posts | Posted by Hopper on 08/11/2020 22:55:23:
Nothing at all to worry about. See my post on the other thread on alignment you posted on. Thanks, understood, but please see my reply on the other thread, ie for a beginner, with an old lathe, its natural to doubt its accuracy due to wear, and unknown history, and to want to get it as good as it can be. That's all I'm trying to do here. I'm fine with it - after all its capabilities undoubtedly exceed mine, but I want it to be as good as I can get it. I think I'm there with it now. BTW I really appreciate your knowledge and advice - after the improvements you outlined on the forum and in your articles, my ML7 has been improved massively in terms of feel and useability. I would never have contemplated modifying a lathe in such away without some guidance and encouragement. |
Hopper | 09/11/2020 05:29:59 |
![]() 7881 forum posts 397 photos | Posted by Dr_GMJN on 08/11/2020 19:47:30:
You're welcome. Glad you are getting there. It's a learning experience thats for sure. The above misalignment looks odd, although I prefer putting a razor blade or thin ruler in there rather than purely visual. But it could possibly be a poorly made centre or centres. Try rotating each centre half a turn, one a time, and see how alignment changes or remains same. Also make sure tailstock clamp lever and the barrel lock lever also are firmly applied before making the test. Could be bed wear althoough the couple thou you had should not make a huge visible difference like that. Check the tailstock barrel is sitting level to the bed by mounting a dial gauge on the carriage and running it along the top of the extended, and locked, tailstock barrel. If not, first suspect would be swarf or burrs on the tailstock base or the horizontal adjustment faces there in.
Edited By Hopper on 09/11/2020 05:32:25 |
Dr_GMJN | 09/11/2020 16:39:17 |
![]() 1602 forum posts | Thanks Hopper. |
Dr_GMJN | 09/11/2020 18:58:11 |
![]() 1602 forum posts | So on to the next, and hopefully last issue. |
mechman48 | 09/11/2020 19:50:08 |
![]() 2947 forum posts 468 photos | Motor / belt resonance ?. as you are that close I wouldn't look for perfection, If I was machining something that far out from the chuck I would definately be supporting with live centre in tail stock. IIRC usual recommendation for stick out from chuck, unsupported, is 2 - 3 x stock diameter max. George. |
