Bridge port Milling machine
Scott Headington | 17/09/2020 17:50:49 |
3 forum posts | Hi Guys, Thank you for letting me join the forum as a new member. I have recently bought a Bridgeport Milling machine, J head, variable pulley model. On inspection the previous owner/ or owner before that had cut all the wires going to the control box by the knee. I have managed to trace wires back to the main control box via continuity testing. The fault I am having at the moment is when I turn on the machine then turn on the toggle switch ( far left) on the control box, the contactors come on, then when I press the green button the contactor disengages. I know this is wrong because it should be the reverse of what I just said. I have tried all different combinations with wires going to different places on the control box but I just seem to be coming up against a brick wall with this. Has anyone out there got a wiring diagram of the control box so I can get it up and running please?? |
Oldiron | 17/09/2020 18:36:59 |
1193 forum posts 59 photos | Have you tried looking on Vintage Machinery.org They have a vast collection of manuals on most machines including Bridgeport. The manuals are all free to download although I think you can make a donation if you wish. regards |
Bazyle | 17/09/2020 18:43:08 |
![]() 6956 forum posts 229 photos | Nice to see you Scott, |
Chris Evans 6 | 17/09/2020 19:31:50 |
![]() 2156 forum posts | I do have a manual for my Bridgeport. What year is your machine ? ( the serial number contains the date code) Lots of wiring changes over the years. |
Scott Headington | 19/09/2020 17:50:21 |
3 forum posts | Hi Chris, The serial no on my Bridgeport is 358130481W. Does this tell you what model it is and year of manufacture? |
Oldiron | 19/09/2020 18:19:54 |
1193 forum posts 59 photos | You need the actual machine number from the knee casting then look up at at lathes.co.uk or globalmachinebrokers.com The number on the head will not work. regards |
noel shelley | 19/09/2020 18:43:40 |
2308 forum posts 33 photos | Welcome ! I have a wiring diagram that may be right, it is a poor copy. The control circuits seem to be from a 415v to 110v transformer. It sound as though the push button is n/c rather than n/o and operating it drops the contactors. send me a pm and I will try to help. Noel |
David George 1 | 20/09/2020 07:47:09 |
![]() 2110 forum posts 565 photos | Hi Scott I have a copy of the handbook in PDF format which has a wiring diagram at the end I will send a message with my email so you can send me an email with handbook attached. David |
Scott Headington | 20/09/2020 09:09:10 |
3 forum posts | David, ok that would be great as I'm at my wits end with it. I just want to get it up and running. Cheers |
David George 1 | 20/09/2020 12:38:48 |
![]() 2110 forum posts 565 photos | Scott have a look at the top of this page there us a little mail symbol inbox just click it to receive messages when logged in. David |
