Bantam thread cutting set-up?
Rob Thomas 409/08/2020 14:38:05
16 forum posts
7 photos
David George 109/08/2020 14:51:29
2110 forum posts
565 photos
What a shame it is sooooo rusty. Never mind it will clean up and it can be put back in to service with a lot of hard work.
David
Emgee09/08/2020 16:19:30
2610 forum posts
312 photos
Lot of work there, OK if you have plenty of spare time and a lot of cleaning materials.
Emgee
Baz09/08/2020 16:39:31
1033 forum posts
Must be me being thick as usual but all I see is a picture of a Bantam 800, is there a question or some statement of some sort to go with it.
Nick Wheeler09/08/2020 16:53:36
1227 forum posts
101 photos
Posted by David George 1 on 09/08/2020 14:51:29:
Is it? 1/2hr with some degreaser and fine Scotchbrite, and another few minutes lubricating it should make it both usable and tidy looking.
Rob Thomas 409/08/2020 17:50:54
16 forum posts
7 photos
Sorry Gentlemen, not familiar with the posting method on this forum, pushed the wrong button!
The bed way valleys are quite pitted but the bearing surfaces appear OK and the Eagle gearbox was badly mashed and some of the cog teeth needed dressing with a file. I've got the feed drive to work but it's noisy at high revs.
My question is when setting up for screw cutting do the driver and driven cogs run on different cogs of the compound idler(120T/127T). I appologise, I'm finding the user manual quite difficult to understand.
Edited By Rob Thomas 4 on 09/08/2020 17:56:29
DC31k09/08/2020 19:03:59
1186 forum posts
11 photos
Posted by Rob Thomas 4 on 09/08/2020 17:50:54:
I am assuming it is a native imperial machine (i.e. 4tpi leadscrew).
When screwcutting imperial threads, you use only one of the 120/127 pair. It is used only as an idler gear so does not change the ratio. Thus either one of the two is OK to use.
When screwcutting metric threads, you need to use both gears as a compound gear. This provides the necessary imperial to metric conversion factor.
Howard Lewis09/08/2020 19:24:58
7227 forum posts
21 photos
If the Leadscrew is Imperial pitch, for Imperial threads, it does not matter whether you use the 120, or the 127 as an Idle.
Ditto, if the Ladscrew is Metric.pitch.
BUT
If the Leadscrew is Imperial pitch and you wish to cut a Metric thread, then you will need to drive
Mandrel /Tumbler reverse to 120T / 127T to Gearbox Say 8 tpi, so 3.175 mm x 120/127 = 3
If the Leadscrew is Metric and you wish to cut an Imperial thread,
Mandrel/Tumbler Reverse to 127, 120T to Gearbox 3 x 127 / 120 + 3.175 mm ( 0.125 = 8 tpi )
In each case the Driver and Driven gears need to be chosen to suit the ratio chosen in the Norton gearbox, for the required thread pitch.
HTH
Emgee09/08/2020 19:53:05
2610 forum posts
312 photos
Rob
Blimey, you cleaned that up pretty quickly !!!
Did the gear selector chart on the gearbox cover clean up OK so it is all readable ?
If it did you can see the gear selector positions which will suit the threads and feed rates in that band.
Emgee
Pete Rimmer09/08/2020 22:24:42
1486 forum posts
105 photos
You say it's an Eagle that makes it a Metric machine. You use the compound for inch thread, but use the 127 as an idler for metric I believe.
