Here is a list of all the postings Rob Thomas 4 has made in our forums. Click on a thread name to jump to the thread.
Thread: Email woes |
21/06/2023 21:22:33 |
Thanks for the replies................. Hello Vic, I'm aware of the phrase................ "If you pay for a service then you are the customer, if you don't have to pay then you become the product" I just can't seem to get the email spam filters to work effectively for me. |
21/06/2023 17:34:43 |
Please can anyone offer advice on how to obtain a personal internet domain name, I've had my fill of "hotmail"? Thanks, Rob |
Thread: Blocked Drain |
21/02/2022 10:59:47 |
Hello Vic, I have the same fitting at my house. I think the sleeve forms the water trap to prevent foul smells to atmosphere. Regards, Rob |
Thread: Colchester Bantam Lathe |
09/08/2021 09:45:44 |
"I've been down this road and agree about the instability of a "Bantam" on the move and I thought the controls a little too low for comfort so I fitted these rollers when restoring mine. They are 50mm box section with 22mm bearings as wheels. |
Thread: Lathe cover |
15/07/2021 09:40:51 |
I've used this treatment (ACF 50) on my precious motorbike and lathe over winter in a marine environment to good effect. A bit pricey, but then most things which are good are seldom cheap! www.acf-50.co.uk Regards, Rob. |
Thread: Colchester MK1 Bantam |
23/12/2020 17:35:19 |
20/12/2020 13:17:29 |
Grateful thanks for your replies. Rob |
19/12/2020 17:04:02 |
Please can anyone enlighten me on how to adjust the point at which the tailstock ejects a Morse taper fitting when the barrel is wound back? At present, mine ejects at about 1/4" projection of the barrel, I'd like it to be below the zero point. Regards, Rob |
Thread: Colchester Bantam MK1 Milling Attachment Query |
27/10/2020 13:24:52 |
Many thanks for that info, I'm very grateful. Rob |
26/10/2020 17:07:11 |
Good evening all, Has anyone fitted a Myford type milling attachment to a Mk1 Bantam? If so, I'd really appreciate some photos and hints on "how to". Rob. |
Thread: Bantam Gamet Dials |
24/08/2020 20:11:17 |
I'm very grateful for the link, DC31K Regards, Rob |
24/08/2020 19:09:34 |
Please can any one suggest a (chemically or otherwise) method of enhansing the visibility of the micro graduations on the cross slide dials of my recently partially restored Mk1 Bantam?
Edited By Rob Thomas 4 on 24/08/2020 19:12:15 |
Thread: QCTP Query |
14/08/2020 11:18:01 |
Ive recently purchased a new BXA sliding gib type tooolpost for my Bantam and would like to know the purpose of a Allen socket screw in only one of the sliding gibs, even the supplier is uncertain of it's purpose.Can anyone enlighten me, please? It is into a blind threaded hole. Regards, Rob |
Thread: Bantam thread cutting set-up? |
09/08/2020 17:50:54 |
Sorry Gentlemen, not familiar with the posting method on this forum, pushed the wrong button! Here's my lockdown efforts, my first lathe. The bed way valleys are quite pitted but the bearing surfaces appear OK and the Eagle gearbox was badly mashed and some of the cog teeth needed dressing with a file. I've got the feed drive to work but it's noisy at high revs. My question is when setting up for screw cutting do the driver and driven cogs run on different cogs of the compound idler(120T/127T). I appologise, I'm finding the user manual quite difficult to understand. Edited By Rob Thomas 4 on 09/08/2020 17:56:29 |
09/08/2020 14:38:05 |
Thread: Yet Another Mystery Object |
24/07/2020 12:46:36 |
Could it be for measuring the level of the remaining liquid in the bottom of a liquid (oil) tank? Regards, Rob |
