Chris TickTock | 15/07/2020 13:27:31 |
622 forum posts 46 photos | Hi Guys, On the web I have found sites stating a horse rasp can be used for aluminium for really rough smoothing out. Is this the case and does anyone do so and if so do they recommend chalk, WD40, paraffin or anything else to stop the teeth clogging. Chris
Michael Gilligan | 15/07/2020 13:54:03 |
![]() 23121 forum posts 1360 photos | Perhaps you could do a comparative test, Chris ... and share your findings for our benefit MichaelG. |
Brian Rutter | 15/07/2020 15:31:38 |
![]() 25 forum posts 24 photos | Why a horse rasp? - A woodworking rasp is a quarter of the price, I have been using the same ones for five years on aluminium and they have never clogged. Toodlepip |
Lee Rogers | 15/07/2020 15:39:26 |
![]() 203 forum posts | I think what you need is a millenicut file . It will remove metal fast but will also produce very fine finish on the edges of sheet metal esp aluminium. I can remember my father using one on aircraft skins.
Chris TickTock | 15/07/2020 16:42:45 |
622 forum posts 46 photos | Posted by Lee Rogers on 15/07/2020 15:39:26:
Thanks Lee (and everyone) yes it looks like a millenicut file is the tool required. One ordered thanks guys. Note they are advertised as not clogging so that answers that question as well. |
Brian H | 15/07/2020 16:57:06 |
![]() 2312 forum posts 112 photos | Much used in the aircraft industry. Be sure to wear some stout gloves if not used to these things. Fresh out of college and in my first job, I came home in the evening with a series of semi-circular cuts on the palm of my left hand. Brian |
Chris TickTock | 15/07/2020 17:07:16 |
622 forum posts 46 photos | Posted by Brian H on 15/07/2020 16:57:06:
Much used in the aircraft industry. Be sure to wear some stout gloves if not used to these things. Fresh out of college and in my first job, I came home in the evening with a series of semi-circular cuts on the palm of my left hand. Brian noted Brian thanks |
Ian P | 17/07/2020 21:13:36 |
![]() 2747 forum posts 123 photos | Posted by Chris TickTock on 15/07/2020 13:27:31:
Chris, You said you found some information on a website so whilst I am probably a bit late mentioning this to you but shock-horror, not everything you read on the internet true! Sorry if its come as a surprise to you. Ian P Edited By Ian P on 17/07/2020 21:14:11 |
Bill Pudney | 17/07/2020 21:50:41 |
622 forum posts 24 photos | Yep Millenicut files are the ones you want. I have a selection from my apprenticeship in the 60s. With careful use and storage they are still good. They will clog but the al.alloy needs to be the soft sticky kind, rather than the harder tempers, and yes beware of the left hand pain, we used to wrap the last couple of inches with masking tape, but probably a stout glove is better. best of luck!! cheers Bill |
JohnF | 17/07/2020 22:26:21 |
![]() 1243 forum posts 202 photos | Dreadnought or Millenicut, have never used a horse rasp but I think the tooth form would not work well ? Dreadnought are capable of removing material very efficiently, Millenicut give a finer finish. Regards John |
