Member postings for Brian Rutter
Here is a list of all the postings Brian Rutter has made in our forums. Click on a thread name to jump to the thread.
Thread: The Engineers Emporium Henry (Heinric) Stirling Engine
16/11/2020 08:51:09
Here is a video of the common cylinder linkage in slow motion, starting to get my head around it.
https://www.youtube.com/watch?v=m1cIWtB7boA
I think I could manage a seperate power cylinder but that would be my limit.
Toodlepip
16/11/2020 07:28:03
Plans and castings appear to be available from AJREEVE https://www.ajreeves.com/heinrici.html
I like the configuartion ( but not the price of castings) and I am looking for a home for couple of displacer cylinders about this size.
Toodlepip
Edited By Brian Rutter on 16/11/2020 07:32:36
15/11/2020 17:29:37
Chris,
I think you are misspelling the name try googling HEINRICI (with an i at the end) and you will have a lot more success.wink
They look nice, it may be a good project, I will give it some thought.
Toodlepip
Thread: Uri Tuchman
04/10/2020 08:24:59
I follow this guy he makes tools to make machines to make anything.
His latest post "Homemade Gear Cutting Indexer" is worth a look
https://www.youtube.com/watch?v=0GPm4odtna4&t=177s
or if you want to see others here is his channel.
https://www.youtube.com/channel/UCHsqqRjziUaMwZgQZHw-n1w
Thread: Astrolabes and Other ancient Instruments
04/10/2020 07:55:56
Have a look at this beautiful Astrolabe and watch it being made by hand.
I follow this guy and do not know how to describe him ; Engineer, Artist, Engraver.
He makes tools by hand to make machines to make anything and he is fun.
https://youtu.be/8U7ED6k5NLg
Edited By Brian Rutter on 04/10/2020 08:00:14
Thread: endoscope / inspection camera
02/10/2020 06:32:21
Another variation on a theme.
Search for "Wifi Inspection Camera" in E-bay and you will get a variety of gadgets for around £20.
5.0M cameras up to 10m of cable etc etc,
These can stream photos or videos wirelessly to computers or phones.
Toodlepip
Thread: Hello from Bonnie Scotland
29/09/2020 19:41:08
Tom,
Welcome from another financially challenged steam enthusiast.
My own compromise are Stirling Engines, with a bit of imagination they can be mistaken for the steam variety but with the lower pressures involved, materials and equipment can be less of a financial burden.
I need to build stuff - to do that I need a lathe - idea build a lathe.
That's my problems sorted for a couple of years, Good Luck with yours.
Toodlepip
Thread: Coping with deafness
08/08/2020 14:43:40
My mum is elderly, not very mobile, rather stubborn and when she takes her hearing aids out to sleep is completely deaf.
Door bells and telephone systems are taken care of but a couple of near misses with fires prompted made me look for additional safeguards for her.
I have initiated a system using the Local councils Telecare Alarm system.
In the event of a fire and a fire alarm is activated it connects to an alarm panel in mums house which automatically notifies the council control room, who then inform the fire brigade. While you are waiting for the fire brigade to arrive the control room can send out a patrol, or telephone a neighbour or a member of the family (me). The exact sequence of events can be agreed with the local control room.
The fire alarms connect by bluetooth to the alarm panel and the panel connects to the control room using using mobile phone technology, so it is a completely wireless system that takes 20 minutes to instal, is maintained by the council who check it out a couple of times a year.
It makes me sleep easier.
Thread: Horse Rasp on Aluminium
15/07/2020 15:31:38
Why a horse rasp? - A woodworking rasp is a quarter of the price,
I have been using the same ones for five years on aluminium and they have never clogged.
Toodlepip
Thread: Hello from Teesside
03/07/2020 18:57:36
Hi Geoff,
Welcome, I am a newcomer to the forum myself but have lived in Middlesbrough (TS1) all my life.
The Alba looks like a nice project, I have seen a couple of restorations on the forum and they look more than worth while. Look forward to seeing your progress.
Toodlepip
Thread: Brian's Twin Beam Stirling Engine
28/06/2020 09:00:35
Posted by Mick B1 on 28/06/2020 08:42:50:
Is that your own design, or adapted/modified from some established pattern? Amazing either way.
Made it up as I went along - but originally inspired by engines by Gary Knight on YouTube.
Edited By Brian Rutter on 28/06/2020 09:00:58
28/06/2020 08:28:26
This was my first effort at building an engine.
Mainly built with recycled materials.
Displacer Cylinder, Power Cylinder, Smoke Stack, Pressure Lines, Platform Support Columns are all made from recycled copper pipe.
Handrail is 4mm copper brake pipe I salvaged from the local MOT testing center.
Flywheel is made up of 3 layers of Laminate flooring with lead flashing on the outside rim.
Displacer is balsa wood covered in Aluminium foil.
Power cylinders are 22mm copper with pistons cast from 2 part epoxy using copper pipe as mould.
Cladding to the Water Jackets recylced coffee stirers from Costa Coffee - timber operating floor- lollipop sticks
The construction of the power train is basically the same as that shown in my other post - Brian's Horizontal Stirling Engine
Flywheel Bearings are 8mm from a fidgit spinner.
Most of the linkages, parallel motions etc are made from 4mm Bamboo from the £1 Shop.
Edited By Brian Rutter on 28/06/2020 08:58:52
Thread: Help with lathe operation would be much appeciated.
27/06/2020 16:42:24
Many thanks to all responders.
Everything is now as it should be.
Toodlepip
Thread: Brian's Horizontal Stirling Engine
26/06/2020 10:38:08
Proof Of Concept Only - a bit more work to do and a better video to follow.
Toodlepip
Edited By Brian Rutter on 26/06/2020 10:38:37
26/06/2020 09:08:41
Then added a firebox
Edited By Brian Rutter on 26/06/2020 09:12:56
26/06/2020 09:00:51
Due to the coronovirus lock down, I was limited to materials in my shed.
The displacer conrod is 1/8" brass. This is fine for vertical enginess but in the horizontal configuration it is not too clever.
I added a slider to limit the vertical movement
Edited By Brian Rutter on 26/06/2020 09:27:54
Edited By Brian Rutter on 26/06/2020 09:28:41
25/06/2020 15:31:21
It was at this point I had to chose either water cooled or air cooled.
Mistake Number 1
I went for the air cooled variety.
Mistake Number 2
Circumferential fins are very wasteful of materials so I chose longitudinal fins that I could cut from scraps of copper pipe.
Trying to solder these fins on was a bit of a nightmare way beyond my skill sets. The first few were OK but with the later ones, every one I tried to solder the previous few desoldered and fell off.
It took forever and turned out to be the worst soldering I have done for a long time.
Up until this point I was intending to have a nice shiny copper engine, the gronky soldering made change my mind to a painted model.
25/06/2020 10:49:39
Of course I would like to build a steel flywheel but I can't. So I had to make do with a wooden one.
For reference it is a 200mm (8" diameter wheel made from HDF laminate flooring with 3mm of lead on the outside of the rim.
THe wheel runs on two 8mm bearings from fidgit spinner and the conrod is 4mm diameter bamboo.
24/06/2020 16:05:49
When Mum is not looking, cut about 20mm off the bottom of her steradent tube.
This will be a nice fit into aa piece of 28mm copper pipe.
Fill the tube with two part epoxy glue, forming a recess for the connection to the con-rod.
The piston should be a good fit in the cylinder, if you close the outlet from the cylinder with your hand the piston should not move. When you open the outlet of the cylinder the piston should slowly slide down the cylinder under its own weieght.
24/06/2020 15:34:32
The thermal joint flanges are out of 3mm Aluminium Sheet
The thermal break is nothing more than a couple of layers of HDF laminate flooring.
Up until this point everything came out of the "really useful box of stuff" the exeption being the 2.1\2" end cap on the hot end.
Everything here is soft soldered apart from the end cap which is fixed with Gun Gum exhaust repair paste.
