Chris TickTock | 05/07/2020 16:28:50 |
622 forum posts 46 photos | Hi, I am in the process of converting my scroll saw and the blade holders currently are M4 cap headed socket screws marked 8.8 which is I think high tensile alloy steel. It would be an advantage to replace the cap headed screws with finger tightening screws such as thumb or butterfly. My issue is that yes I can find stainless screws to my requirements but not strong steel. Easy to find cap headed screws so is there a way to convert a normal cap headed to convert to thumb or even better butterfly. I have found one site offering really strong durable M4 butterfly bolts but i suspect I could fall foul of certain shortcomings from our overseas manufacturers in terms of quality. Any suggestions welcome Chris |
JasonB | 05/07/2020 16:34:18 |
![]() 25215 forum posts 3105 photos 1 articles | Saw a slot across a cap head screw, saw/file up a pleasing shaped head from steel sheet and silver solder into the slot another option is to take some steel bar, turn down and thread one end to the size you need and then saw off leaving sufficient to form a head. How hold by thread and turn the hean to an oval or round shape. mill the two sides flat and you have a thumb screw Edited By JasonB on 05/07/2020 16:37:52 |
Ian Parkin | 05/07/2020 16:34:56 |
![]() 1174 forum posts 303 photos | Chris so you want to convert a blade locking screw that you use an allen key for to a finger lock? use a m4 bolt as the post and use a m4 wing nut on it to use as the lock...if the wing nut or bolt wears out ...replace it...? |
Martin Kyte | 05/07/2020 16:41:35 |
![]() 3445 forum posts 62 photos | I would suggest you make a key. Retain the cap heads and make a key similar to a clock key with a suitable sized piece of hex from a cut down allen key driven into the pipe. Create a suitable holder on the saw for the key. A block with a hole in would be the simplest. You can make the key as wide as you like for ease and as long as you like for access. regards Martin Edited By Martin Kyte on 05/07/2020 16:43:03 |
Chris TickTock | 05/07/2020 16:43:45 |
622 forum posts 46 photos | Thanks Guys, The M4 bolt is basically pinching together a piece of steel with the far end threaded. Would a simple and effective solution also be to do what Ian states adding a butterfly nut to the steel bolt but use a strong loctite that stays in place such as retaining compound 680? Chris
Edited By Chris TickTock on 05/07/2020 16:44:29 |
Chris TickTock | 05/07/2020 16:46:13 |
622 forum posts 46 photos | Posted by Martin Kyte on 05/07/2020 16:41:35:
I would suggest you make a key. Retain the cap heads and make a key similar to a clock key with a suitable sized piece of hex from a cut down allen key driven into the pipe. Create a suitable holder on the saw for the key. A block with a hole in would be the simplest. You can make the key as wide as you like for ease and as long as you like for access. regards Martin Edited By Martin Kyte on 05/07/2020 16:43:03 Like it Martin, something I had not yet thought of. Chris |
Martin Cargill | 05/07/2020 16:49:58 |
203 forum posts | Cross drill the head of the cap screws and drive a small roll pin through it to make a handle. You can put a larger roll pin over either end of the original roll pin in order to make the handle a little larger.
Martin |
Ian Parkin | 05/07/2020 16:53:38 |
![]() 1174 forum posts 303 photos | Chris just run a m4 bolt into the thread after putting a wing nut on the bolt then use the wing nut to tighten it up the nut does the same job as the bolt head |
JasonB | 05/07/2020 16:54:02 |
![]() 25215 forum posts 3105 photos 1 articles | Whatever mods you do strength of the screw won't really come into it as your finger and thumb will never apply as much force as an allen key would unless you are built like Popeye. Just buying a Tee headed allen key would be another option and give the same effect as Martin's suggestion. |
Ian Parkin | 05/07/2020 17:02:20 |
![]() 1174 forum posts 303 photos | The thing about my suggestion is that you dont wear out the female thread in your equipment the bolt shaft is replaceable when it wears out as is the wing nut |
Chris TickTock | 05/07/2020 18:02:53 |
622 forum posts 46 photos | Posted by Ian Parkin on 05/07/2020 17:02:20:
The thing about my suggestion is that you dont wear out the female thread in your equipment the bolt shaft is replaceable when it wears out as is the wing nut Yes and this is probably the most pragmatic. Can I get M4 butterflies in strong steel? For this type of application is carbon steel essential? Chris |
Ian Parkin | 05/07/2020 18:10:36 |
![]() 1174 forum posts 303 photos | Chris if it lasts even 6 months replace the screw or the nut a bag of 10 wing nuts will last a lifetime...guaranteed |
JasonB | 05/07/2020 18:19:40 |
![]() 25215 forum posts 3105 photos 1 articles | Posted by Chris TickTock on 05/07/2020 18:02:53:
Yes and this is probably the most pragmatic. Can I get M4 butterflies in strong steel? For this type of application is carbon steel essential? Chris As I said above you will be hard pushed to strip an M4 wing nut using finder and thumb, if you are going to tighten it with pliers then maybe in which case whey change from allen key |
Chris TickTock | 05/07/2020 18:25:39 |
622 forum posts 46 photos | Posted by JasonB on 05/07/2020 18:19:40:
Yes and this is probably the most pragmatic. Can I get M4 butterflies in strong steel? For this type of application is carbon steel essential? Chris As I said above you will be hard pushed to strip an M4 wing nut using finder and thumb, if you are going to tighten it with pliers then maybe in which case whey change from allen key I have just looked up the tensile and yield strength of A4-80 stainless v 88 steel and surprisingly not a heap of difference. I note it is easy to find more steel components in the states...we should support our steel industry but I had better watch it I'm becoming political. Thanks Guys..problem sorted. Chris |
Robert Atkinson 2 | 05/07/2020 19:07:03 |
![]() 1891 forum posts 37 photos | You can get moulded cps specfically to turn cap screws into "knobs" https://uk.rs-online.com/web/p/knobs/0771667/ Other suppliers do them too. Robert G8RPI. |
Michael Gilligan | 06/07/2020 08:23:36 |
![]() 23121 forum posts 1360 photos | < deleted as irrelevant > MichaelG. Edited By Michael Gilligan on 06/07/2020 08:25:45 |
ega | 06/07/2020 11:09:38 |
2805 forum posts 219 photos | Posted by Robert Atkinson 2 on 05/07/2020 19:07:03:
You can get moulded cps specfically to turn cap screws into "knobs" https://uk.rs-online.com/web/p/knobs/0771667/ Other suppliers do them too. Robert G8RPI. Thanks for the link. The economically-minded can easily make them, of course, and brass seems convenient for its relative softness. |
SillyOldDuffer | 06/07/2020 12:12:29 |
10668 forum posts 2415 photos | Posted by Chris TickTock on 05/07/2020 18:25:39:
... Chris ... ... I note it is easy to find more steel components in the states...we should support our steel industry but I had better watch it I'm becoming political. ... Chris Nothing wrong with being patriotic but never ignore uncomfortable realities! One is that Brits would have to buy an enormous amount of steel to make a difference. In 2019, the UK made 7,200,000 metric tons of steel, about a million tons more than Holland, and slightly less than Egypt. At 87.9MT the USA was the fourth largest producer of steel in 2019 after Japan (99.3MT), India (111.2MT), and China who made a whopping 996.3 million tons, about half the worlds' steel (1869.9M) To put that in context, China made more steel in the last 3 years than the entire UK steel industry since the industrial revolution. Bringing British Steel up to Chinese levels would need every man, woman and child in the UK to buy about 16 tons each year forever, and they'd have to buy it whatever the cost. Producing that quantity of steel in the UK would require massive investment of money and land in steelworks, and seaports. It would very difficult to mass produce steel competitively because today most of the Iron Ore, Scrap and Coal has to be imported. Not much coal or iron ore left underground in the UK. Patriotism isn't the reason more steel products are available in the USA. It's simply there's a bigger market for them, partly 330Million people vs 67M, partly because of what they manufacture. In general, big markets result in more choice and lower costs, and the USA is big. British steel is unattractive to model makers for another reason. Like many other steel producing countries, Britain has shifted away from mass production of cheap carbon-steels into making high-quality alloy steels for specialised purposes. One example is railway lines where the steel must be strong, reliable, weldable and extremely wear resistant. Likewise special steels for lightweight bridges, pressure and corrosion resistant chemical plant, turbines, oil rigs and other highly demanding applications. These steels are expensive, high-quality and mostly useless in a home workshop. Supporting local industry and services may be good politics but always check the reality - emotional decisions are often expensive mistakes. I'm divorced! Dave
Chris TickTock | 06/07/2020 13:03:40 |
622 forum posts 46 photos | Posted by SillyOldDuffer on 06/07/2020 12:12:29:
Informative stuff Dave, thanks for the post. Chris |
Perko7 | 06/07/2020 13:18:22 |
452 forum posts 35 photos | Using a suitably long bolt, thread a butterfly nut onto the end until just fully engaged, silver solder in position, then cut off the head. I've used that process to make metric hex-head bolts in various sizes not available commercially. For most model engineering uses you will strip the thread before you break the silver solder bond. |
