Method of joining for chuck key?
How would they have, how should I??
Chris V28/05/2020 11:42:58
313 forum posts
42 photos
I have been admiring this chuck key and as I need a couple thought it would make a nice project sometime. Thinking about joining the steel stem to the brass handle I had thought of turning and reaming tapers but seeing the small end at the top of the handle I think from my limited knowledge this would not be particularly efficient at griping, the taper being too steep.
Bearing in mind its a key so needs to be secure how do you suggest they might have fixed it originally?
Chris.
Martin Connelly28/05/2020 11:44:45
2549 forum posts
235 photos
Is it pinned through from the side?
Martin C
Chris V28/05/2020 11:48:10
313 forum posts
42 photos
Thanks Martin, I meant to add that was my thought first but I see no evidence of a pin...
Simon Collier28/05/2020 12:02:38
525 forum posts
65 photos
Total guess, but knurled and driven on?
Chris V28/05/2020 12:29:45
313 forum posts
42 photos
Hmm well that might work ok but for something of obvious quality I would expect something more certain to secure.
Similarly I suppose the end of the shaft could be peined into a countersink and then finished off flush, but again I thin there must be a better engineers solution?
Chris.
Robert Atkinson 228/05/2020 12:51:19
1891 forum posts
37 photos
The part of of the shaft inside the handle may be square, splined or similar (or even threaded) with small round post at the end that was peened over.
An X-ray would reveal a lot, how friendly is your dentist?
Robert G8RPI.
Kiwi Bloke28/05/2020 12:52:01
912 forum posts
Tapered, square-section shaft and hole, round shaft end peened over, to hold it in?
Martin Kyte28/05/2020 13:05:35
3445 forum posts
62 photos
Whats wrong with using soft solder? I would do a taper fit, tin the steel and wipe with wire wool and sweat the two pieces together.
regards Martin
Swarf, Mostly!28/05/2020 13:22:52
753 forum posts
80 photos
At least one well-known brand of padlock uses a brass pin through the brass body to secure the assembly of its 'innards'. The brass pin is driven in and then filed and linished flush on both flanks of the body. If this is done properly, 'you can't see the join'! (I and my fellow pupils actually had to assemble such a padlock as part of a 'Locksmithing Acquaint Course' several years ago. )
You could use the same technique but polish the handle rather than settling for a linished finish.
Of course, the shaft of the key would need to be a good fit in the handle and the pin should be the same grade of brass as the handle so that their colours match.
Best regards,
Swarf, Mostly!
Nick Clarke 328/05/2020 13:32:51
1607 forum posts
69 photos
The brass crosspin sounds good, but you could also draw the shaft into the handle with a cheesehead screw in a close fitting shallow counterbore and linish down the head flush when tight.
Shaft to be keyed, squared, tapered or loctited to taste as well if desired.
Gary Wooding28/05/2020 13:33:36
1074 forum posts
290 photos
What's wrong with threading it and using Loctite?
Martin Connelly28/05/2020 13:38:34
2549 forum posts
235 photos
Robert, I suspect your X ray suggestion is a bit tongue in cheek, however I think you need a bit more oomph for the X-ray than you get from dentists' or even hospital machines. The ones used for metal parts in industry are hidden in bunkers with big heavy sliding doors and sand in the gap of concrete cavity walls. They also use long exposure times compared to x raying body tissues. I think there are some suitable NDT companies based in airports for obvious reasons so your idea would work if you could get friendly with one of their employees. Otherwise pipe manufacturers who do their own NDT may be a good bet, I know of at least one with X ray facilities.
Martin C
John Haine28/05/2020 13:39:40
5563 forum posts
322 photos
Posted by Robert Atkinson 2 on 28/05/2020 12:51:19:
Robert G8RPI.
If my dentist has an x-ray machine that would image through solid brass I'm not going back!
Kiwi Bloke28/05/2020 13:40:04
912 forum posts
Robert Atkinson beat me! Dental X-rays won't penetrate - they are too low energy. Also, I think you'd need higher energy photons than general medical diagnostic X-ray gear provides. You could try your local radiotherapy centre, perhaps. You'd need an energy where the attenuation coefficients of Fe and Cu/Sn were sufficiently different to allow them to be distinguished. I once had a cello put through a hospital CT scanner - that was interesting, but another story!
Chris V28/05/2020 13:56:54
313 forum posts
42 photos
Brilliant!
I had in my mind dismissed a brass cross pin as not strong enough but as several of you seem to think that would be ok I think that would be my preferred method. Of course a steel cross pin could look nice too, matching the top of the shaft, but clearly that's not how this particular example was made.
Should the cross pin also be tapered, I don't suppose you can buy imperial brass taper pins..or can you?
Chris.
Nigel Bennett28/05/2020 14:01:24
500 forum posts
31 photos
We used to make carriage door handles at work by casting the brass around a steel spindle with suitable chunks chewed out of it to provide a positive drive and location. The pattern was "handle plus spindle"; the pattern was removed and a steel spindle carefully positioned and aligned in the mould. Very simple bearings on most older carriage door locks; just a 3/4"BSW thread to provide axial and radial bearing surfaces.
To veer off-topic slightly, the handles on the BR Mk.3 doors were interesting; initially they were stainless steel, threaded 3/4"BSW, but they suffered misalignment problems. Later ones were fitted with plain journal bearings attached to the lock. Fitting the lock-plus-handle assembly involved first wangling the handle through the hole in the door, before securing the lock on the inside of the door with screws. Early handles - a lever type - suffered from twisting, due to the massive inertia caused by the handles whipping when the door slammed. (It is a rack-and-pinion arrangement which gives a positive visual clue to the door not being latched shut.) We had to change the material to a heat-treated grade normally used for turbine blades. The balanced dickie-bow type on Mk.2 and earlier stock didn't suffer from the problem, and a lower-spec stainless could be used.
And don't ask me about providing inside handles to slam door locks on Mk.3 stock...
old mart28/05/2020 14:05:43
4655 forum posts
304 photos
Threading and using Loctite as recommended by GW would work, it would take more than the strength of the hands to break the bond. 270 would do.
Chris V28/05/2020 14:08:00
313 forum posts
42 photos
Thanks Nigel B, casting the brass onto the shaft seems like that could well have been the way this key was made, I like it, but won't try that at home!
Cheers
Chris.
Chris V28/05/2020 14:19:06
313 forum posts
42 photos
Or for that matter the tapered parts and soft solder, though I'd personally prefer a cross pin, not that Ive tried that before!
Mick B128/05/2020 14:45:11
2444 forum posts
139 photos
It's genuinely pretty, but as a lathe chuck key it seems to me to have a number of drawbacks:-
It's short, with limited leverage
It's heavy. If anybody starts the lathe with it in the 'ole, it'll make that much better a ballistic projectile.
It's not well balanced - I think it might feel awkward in use.
It's soft - after a year or two's regular use, it might look as if it's been chewed by a steel puppy with carbide teeth.
But hey, if you like it... laugh
