milling machine which one ?
Derek cottiss21/05/2020 14:00:04
36 forum posts
Well ive got a small garage containing a boxford lathe and pillar drill .Ive allways had access to a mill (bridgeport) but unfortunately thats come to an end
So what do i buy Bridgeports far too big sadly so maybe a warco vmc or similar AMAT and SYIL ans AMADEAL are available locally but no feedback .
S/H Tom senior or similar maybe ?
Do a lot of airgun work restoration rebuild ect
budget 2 to 3 grand (less if poss
Any suggestions help advice please
Brian H21/05/2020 15:43:13
2312 forum posts
112 photos
Hello Derek, I'm assuming that a vertical mill would be more use to you.
The Tom Seniors are nice machines but the 'S' type vertical heads command a premium price and of course, being second hand, the quality is not certain.
I have no personal experience but the Sieg range of machines from ARC always seem to get a good write up and their latest machine falls within you budget.
If you find a machine and want to know the history and technical details without bias then go to;
There are often machines for sale on there.
old mart21/05/2020 17:10:14
4655 forum posts
304 photos
I would look at what ARC have going at the moment, they also list the footprint which is good. If you have a choice go for one with an R8 spindle fitting. Your budget is pretty good, add at least 50% onto the machine price for tooling.
terry callaghan21/05/2020 17:21:30
237 forum posts
10 photos
Hi, having sold my Tom senior s type a few years back, I remember that moving the knee up and down was a bit of hard work at times. I needed a milling machine again earlier this year. Space is limited, I found that old British mills mainly sole by dealers had a fair bit of play in them. I looked at mini mills, but the bed size allowing for clamping was too small. In the end a warco super major turned up for sale. Locally. I did not wish to go Chinese, but took a look. Powered z axis and bed was nice. For the money £700 I thing it was a good buy. From what I have found out older warco machines are better then the newer ones.
Andy Shepherdson26/05/2020 14:06:38
34 forum posts
Hi all, I’m new to these small machines and with retirement looming on the horizon I am looking to kit out a home workshop.
I’m not intending to build anything huge, so a small hobby machine should be fine, plus I don’t have room for a Bridgeport.
Looking at the various Chinese machines they are all very similar. Is anyone make better than others. Looking to spend around £1200 on a mill.
Thanks Andy
Dave Halford26/05/2020 18:52:19
2536 forum posts
24 photos
Plenty of recent discussions on here already
SillyOldDuffer26/05/2020 20:50:31
10668 forum posts
2415 photos
Posted by Andy Shepherdson on 26/05/2020 14:06:38:
Thanks Andy
The machines are more-or-less made to the same design, but details vary. They're made down to a price, mostly OK, but some rough examples escape. Probably matters more who you buy from because the game is more about what happens if you get a poor example than identifying wonderfulness. There's a hint that some suppliers do better than others in terms of quality, but - as far as I know - all the main UK vendors refund or replace if they send out a dud.
ArcEuroTrade have an unblemished reputation : I bought all my machines from Warco. They all worked out-of-the box and they all benefited from minor tweaking. I have no complaints. Axminster are more expensive, but offer an extended warranty. Best avoided I think is ordering direct from China, or from the continent, or from the sort of temporary online seller who might be selling factory seconds.
Unless the intention is to specialise in small work, good advice is to buy the biggest machine you can manage (space and money!)
With hindsight I spent far too long dithering about which of the rather similar machines I should buy. Now I think it was a waste of time : any one of them would have done. For what it's worth I have a Warco WM18, which has done all I've asked of it. It's the biggest mill have I space for!
Get stuck in and enjoy.
Pete.26/05/2020 21:29:08
910 forum posts
303 photos
Your budget is 3k.
Get yourself the latest belt drive sieg x2 from arc euro, 700 quid, I just saved you 2300 of your budget.
Edited By Pete. on 26/05/2020 21:30:19
Andy Shepherdson26/05/2020 22:10:13
34 forum posts
Posted by SillyOldDuffer on 26/05/2020 20:50:31:
Thanks Andy
Thanks for the information, Arc are only 3 miles away from me so that’s another plus for them. Looks like I just need to part with the money and stop dithering
Andy
The Novice Engineer26/05/2020 22:42:36
85 forum posts
72 photos
From my experience go for the biggest you can fit /afford.
My first mill was Warco WM14 size/style. It was great for doing small steam engines but I started doing bigger and bigger projects and ran into issues with the table not having suffient travel or being able to fit the parts under the head . The final straw .. burning out the motor after being too impatient taking too big a cut.
I replaced it with a Major Gear Head Mill / Drill. R8 quill . Good work envelope and more power for getting the jobs done. If I was going to change I would look at a similar size machine but with a Dovetail column and inverter speed control.
AND .... what ever you pay for the Mill , you will spend the same again [or more !] on tooling , vices, rotary table clamping kit .......
Just my two penny worth
Steve
Edited By The Novice Engineer on 26/05/2020 22:45:09
Nick Clarke 327/05/2020 09:35:28
1607 forum posts
69 photos
Posted by The Novice Engineer on 26/05/2020 22:42:36:
+1 for both these points and check just how much space you need for the table to travel to its extremes - the 'envelope' can be surprisingly large!
Bazyle27/05/2020 13:01:33
6956 forum posts
229 photos
BUT you don't need to buy all the tooling on day one so spend everything on the machine. You can buy an add on tool next month but you can't buy an add on 6 inches of mill table.
It was pointed out last week on a similar thread that I hadn't realized how much tooling prices had risen which was true but you still only need one collet (not a set) and one HSS slot drill (not carbide, not a set, not 3 flute) on day one. You never need a clamping set nor even a vice initially.
Derek cottiss27/05/2020 22:30:28
36 forum posts
Cormak zx74sb1 mills any good ?
Anadeal ama45 mill and good ?
Derek cottiss29/05/2020 17:23:20
36 forum posts
Posted by Brian H on 21/05/2020 15:43:13:
cheers for that who are ARC ? any links ?
Steviegtr29/05/2020 17:57:44
2668 forum posts
352 photos
Look at top right of this page. arc eurotrade
Steve.
Derek cottiss29/05/2020 22:31:54
36 forum posts
Posted by Steviegtr on 29/05/2020 17:57:44:
Steve.
thank you
looks like they dont supply anything big enough
Pete.29/05/2020 22:55:05
910 forum posts
303 photos
How big do you need to work on air gun parts?
Hopper30/05/2020 06:16:41
7881 forum posts
397 photos
I'm pretty impressed by a mate's Sieg SX3. Big enough for him to build a 9cylinder rotary engine about a foot in diameter when assembled. Plenty big enough for vintage motorcycle parts too. Would be good for gunsmithing I should think, unless you need to mill the full length of a barrel for some reason, in which case you are into Bridgeport territory and commensurate prices.
Howard Lewis30/05/2020 07:27:38
7227 forum posts
21 photos
Having decided upon a machine (If possible, a little larger than you first anticipate ) The budget needs to cover some extra items.
You will need some tooling with the machine, whatever you buy.
You will need a vice (Buy a good one. A flimsy vice will spoil accuracy, at least.) It needs to be an appropriate size for the machine. Tilting Vices can be useful, but are less rigid, and can be bought as and when the need arises.
A Clamping kit may eventually prove useful, depending on what you do.
You will need a proper chuck to hold cutters, NOT a drill chuck. My choice would be the ER system.
Depending on what you want to do, you might need more than one size. ER25 will cover upto 16 mm, so may be a good starting point.
You will need End Mills, probably Slot Drills of various sizes, possibly one or more Face Mills..
You will certainly need twist Drills and either Spotting or Centre drills.
You are likely, eventually to want to cut threads, so you will need Taps and Dies. Again, you may well end up with several sets covering different thread types (Metric, posibly BSW, BSF, or even BA )
If, in the future, you want to produce regularly spaced holes, curved surfaces, or cut gears, you will need a Dividing Head or Rotary Table, preferably with a Tailstock.
You will need measuring equipment.
A digital Calliper would be a starting point, plus, possibly a Plunger Clock, and Finger Clock, maybe with a Magnetic Base. Later, you may decide to buy individual Micrometers, maybe even a Bore Set.
A six inch steel rule will be useful, if only for rough setting up.
Things like a n Edge Finder, or a Wiggler, and a Centre finder, are low cost accessories which make life easier.
You don't need to buy everything at once.
Buy the basics first of all, and add extras, as you see the need arising.
HTH
Derek cottiss30/05/2020 15:21:43
36 forum posts
Posted by Howard Lewis on 30/05/2020 07:27:38:
HTH
most of the bits and pieces i need are in my workshop allready as i have had access to a bridgeport . sadly space for a bridgeport isnt available hence the question re the other machines
