Here is a list of all the postings Andy Shepherdson has made in our forums. Click on a thread name to jump to the thread.
Thread: Warco WM 290v |
21/09/2023 18:55:19 |
Checked this afternoon, and it’s working as it should. Checked with the guy that bought my Chester and he says that is set at around 0.0015” per rev. In the 4 years i owned it I never changed the gears and got use to how it was. Got to get use to faster production. Thanks Jason |
21/09/2023 11:18:27 |
Hope the photos help. I'm going to run the lathe at 1000rpm and see how long it takes to travel an inch. Just incase it's my perception
Edited By JasonB on 21/09/2023 11:21:41 |
21/09/2023 11:17:21 |
Edited By JasonB on 21/09/2023 11:21:57 |
20/09/2023 20:22:48 |
One other point, the gear chart with the lathe doesn’t give a lower feed per rev than 0.0025”. Has anyone found a way to slow the feed down.
20/09/2023 19:38:41 |
Yes, yes and yes. I will have to check again tomorrow. Certain I’ve got something wrong but can’t see what. |
20/09/2023 19:17:35 |
Recently bought a used WM290V. Trying to set the feed and I can’t seem to get a fine feed. Setting up as the finest feed as the diagram it should give 0.0025” per rev. In use it is quite course and I have checked the gear setup twice and I’m confident it’s correct. I can’t see anyway of getting a finer feed, am I missing something. |
Thread: Warco VMC or GH Universal |
14/06/2021 21:27:36 |
Posted by old mart on 13/06/2021 18:07:43:
A 5" vise would be the best choice, 6" is more for Bridgeport size machines. At the museum, we have a choice of an ARC 5", 125mm vise for the larger jobs, or 100mm Bison which get used most frequently. Both mills are of similar size to your new Warco. If I was looking for a good value vise, I would give the ARC 130-040-03500 one top priority, it is 100mm jaws opening 122mm. Their next size up in this type is a very big jump. Edited By old mart on 13/06/2021 18:15:19 Edited By old mart on 13/06/2021 18:23:12 i opted for a 5” vice in the end, comes with a swivel base that I doubt I’ll use but it’s there if needed.
13/06/2021 10:17:05 |
Collected the mill teamster day and it now installed in the workshop. |
08/06/2021 21:14:53 |
Well if have bought a VMC with 3 axis DRO power traverse. I will pick it up on Sunday.
Andy |
30/05/2021 10:06:38 |
Posted by John Hinkley on 28/05/2021 17:29:14:
I have a biased view, I suppose, as the owner of a VMC machine. I can see where Bill is coming from when he says about the axis travel on the GH universal being superior, but I have to wonder how often you would need to use all that airspace. Only you can answer that one For myself, I have found the VMC can do all I ask of it - and more. Over my 6 year's ownership, I've added a DRO on the three axes, a digital readout on the quill feed and power feed to the X-axis (brilliant addition, by the way) and fitted an uprated 3-phase motor and associated VFD . The latter I wouldn't be without both, for ease of use and the improved finish it affords. I specifically didn't want a geared head machine when I ordered mine, mainly due to the perceived noise concerns. I'd previously had a two-speed bench mill which munched its way through gears like there was no tomorrow. But that's a personal choice, again. The VMC appears to have a much beefier column that the GH as far as I can tell from the pictures, so that would sway my choice in itself. I see that both are out of stock at the moment, so you've got time to make up your mind. A visit to the showroom might help with your decision as well. You've no profile so I can't tell whether you are close enough to warrant a visit or not. As has been said so many times before when these "choices" threads come up, it's horses for courses- what do you want to do with it - will it fit your workshop - will I need something bigger as soon as I get it? At the end of the day, it's your money and your choice. If it was me, I'd choose the VMC again. Its only drawback that I've found so far is the sometimes limited Y-axis travel - but even then, some adventurous work holding can usually provide a solution. Whatever you eventually buy, have fun with it an enjoy it for a very long time. John
Thanks for the detailed reply. I like you think the VMC looks beefier, I note your comments on noise. A quick search confirms a few comments on th GH being noisy. It looks like a VMC it is, just leaves R8 it MT. Thanks to all for the replies. Andy |
28/05/2021 13:08:59 |
I did have a look but couldnt find much in the way of the pros and cons of both. Andy |
28/05/2021 11:44:27 |
I currently have a Warco WM14, it does most of what i need but at times im close to its limitations. I am thinking of a Warco VMC or GH universal, whats the for and against for both. I am sure i have read the GH is noisy due to the gear drive. Thanks in advance, Andy |
Thread: Squareness gauge |
27/01/2021 15:46:59 |
€3500 plus carriage and another €58 for a cardboard storage box. Ouch |
26/01/2021 20:28:18 |
Posted by old mart on 26/01/2021 18:40:22:
The Kunz Square Check 350 looks like a winner, but how much will it cost? I’m thinking £2000 ish |
26/01/2021 16:39:14 |
Posted by DC31k on 26/01/2021 16:17:31:
Posted by old mart on 26/01/2021 15:44:10:
...it could be checked at the desired top and bottom heights and adjusted to be true at those points. You are correct, providing that squareness is needed to be checked in only one place. On YT, both OxTools and Stefan Gotteswinter have shown versions that do this. On the other hand, if you need to sweep from top to bottom checking squareness, then the height gauge may not be good enough. https://ecatalog.mitutoyo.com/Square-Master-Series-311-SquarenessStraightness-Instrument-C1825.aspx https://www.kunz-precision.ch/en/products/squareness/SQUARE-check
I have just sent an email to Kunz, looks just the job. Thanks |
26/01/2021 14:42:05 |
Work related so sorry. The object in the photo is called an Indi Square and we use it to check the squareness of a part relative to its mounting surface. I need another one and contacting tool suppliers they have both offered height gauge but i doubt it will be that accurate. We calibrate the Indi square to 2 tenths over it 12" travel. Any ideas anyone, |
Thread: Bench grinder wheel wobble |
22/07/2020 20:55:10 |
I do like the idea Harold Halls, Thanks Micky T |
21/07/2020 21:00:33 |
I’ve just turned up a 3” x 1/2” disc. Fitted on the grinder with a 8mm wide diamond wheel and without frying it only runs out about 10 thou. Thanks for the replies |
20/07/2020 20:20:00 |
I’ve got a good quality 8” bench grinder that I can swap grinding wheels for polishing mops and put the grinding wheel back on and it runs true. My old 6” Aldi special is a different story. I fancy putting a CBN and diamond wheel on it. The supplied washers seem part of the problem, has anyone managed to method to get the wheels to run true.
Andy |
Thread: What geen grinding wheels for tools |
05/07/2020 10:26:58 |
Looking at buying a 6” diamond wheel, what’s most versatile. A bevel wheel or flat. Thanks |
